Hello, I've been hearing more about Labview's ability to develop applications for ADI's Blackfin and was wondering just how easy it is. If anyone has some experience using Labview with the Blackfin I would like to hear your opinions. I like the ability to run the Labview code on the DSP but was wondering about the interface, I assume that Labview has the ability to use ADI's emulators to interface with the DSP, am I correct? Also, how fast does Labview code run on a Blackfin, how much overhead is associated with Labview coding? I always thought that to be the best performance from a DSP you should use C language or Assembly language. thanks, joe
Working with the Blackfin and Labview
Started by ●September 7, 2006
Reply by ●September 8, 20062006-09-08
hi lindula, my friend learnt how to interface labview with adsp completely from tutorials and webinars available on analog.com website. i hope they should be very much usefull to you and also check www.techonline.com for the same, they also have some tutorials on this. regards particle filter jjlindula@hotmail.com wrote:> Hello, I've been hearing more about Labview's ability to develop > applications for ADI's Blackfin and was wondering just how easy it is. > If anyone has some experience using Labview with the Blackfin I would > like to hear your opinions. I like the ability to run the Labview code > on the DSP but was wondering about the interface, I assume that Labview > has the ability to use ADI's emulators to interface with the DSP, am I > correct? Also, how fast does Labview code run on a Blackfin, how much > overhead is associated with Labview coding? I always thought that to be > the best performance from a DSP you should use C language or Assembly > language. > > thanks, > joe
