Levinson-Durbin algorithm
Started by stef September 19, 2006
Good morning experties,
I'm using Levinson-durbin algorithm to invert room impulse responses. I
used the MAtLAB code writen by Bob Cain in the following page
http://www.musicdsp.org/showone.php?id=188
The code works well, but I can't understand why it works!
The following equation should be solved : R*hinv = q
Where R is a Toeplitz matrix, hinv the wanted inverse filter and q is a
well known vector.
Can you please help me to understand how this code works!
I will be very gratefull.
Thank you
Stef
I'm I understanding that you are doing something with acoustics here?
What is your objective in inverting this impulse response?
I invite you to join:
* Group name: RealTime_Signal_and_Control
* Group home page:
http://groups.google.com/group/realtime_signal_and_control
* Group email address realtime_signal_and_control@googlegroups.com
stef wrote:
> Good morning experties, > > I'm using Levinson-durbin algorithm to invert room impulse responses. I > used the MAtLAB code writen by Bob Cain in the following page > http://www.musicdsp.org/showone.php?id=188 > The code works well, but I can't understand why it works! > The following equation should be solved : R*hinv = q > Where R is a Toeplitz matrix, hinv the wanted inverse filter and q is a > well known vector. > Can you please help me to understand how this code works! > I will be very gratefull. > > Thank you > Stef
