hey....I would like to know something about length 64 Walsh codes that are applied in CDMA 2000 1xEVDO....plz help....what is the difference between Walsh codes and PN sequences. Thanks TD
Walsh codes in CDMA
Started by ●September 21, 2006
Reply by ●September 21, 20062006-09-21
koolguyuf wrote:> hey....I would like to know something about length 64 Walsh codes that > are applied in CDMA 2000 1xEVDO....plz help....what is the difference > between Walsh codes and PN sequences. > > Thanks > TD >The codes in a given set of Walsh codes are mutually orthogonal. The codes in a given set of 5-bit PN sequences are guaranteed to _not_ be mutually orthogonal -- at least if you're talking about PN sequences generated by linear shift-and-xor. A _long_ PN sequence can be _almost_ orthogonal with other PN sequences, and with shifted values of itself, but it's never going to be _exactly_ orthogonal. PN sequences are cool for spread spectrum because they're going to be orthogonal to everything but another PN sequence of the same length, and almost orthogonal to that unless you have the secret decoder ring combination. They're a pain because it takes a long time to synchronize up to them, and they have to be generated, etc., etc. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Posting from Google? See http://cfaj.freeshell.org/google/ "Applied Control Theory for Embedded Systems" came out in April. See details at http://www.wescottdesign.com/actfes/actfes.html
koolguyuf wrote:> hey....I would like to know something about length 64 Walsh codes that > are applied in CDMA 2000 1xEVDO....plz help....Not sure about CDMA2000 however the Walsh system of the length 64 was used in the deceased IS-95.> what is the difference > between Walsh codes and PN sequences.There is nothing in common. Those are the absolutely different things used for absolutely different purposes. VLV
koolguyuf wrote:> hey....I would like to know something about length 64 Walsh codes that > are applied in CDMA 2000 1xEVDO....plz help....what is the difference > between Walsh codes and PN sequences. > > Thanks > TDThe transmitter modulates multiplies the channels (pilot, traffic, etc) with different Walsh codes. The codes are perfectly orthogonal to each other. The length is variable (not fixed at 64). The entire transmission, containing a sum of multiple channels separated by Walsh codes, is multiplied by a 32768-chip PN sequence. Each tower has a unique PN code offset so that multiple towers can use the same frequency. John
Reply by ●September 22, 20062006-09-22
"Vladimir Vassilevsky" <antispam_bogus@hotmail.com> wrote in message news:8LGQg.7092$Ij.4415@newssvr14.news.prodigy.com...>> what is the difference >> between Walsh codes and PN sequences. > > There is nothing in common. Those are the absolutely different things used > for absolutely different purposes.Well, I wouldn't like to make such strong statements as nothing in common. One bit is the same in each Walsh code, and if we drop that, there is a fixed permutation that will map the remaining bits of each Walsh code (except the +++....+ code) into a different cyclic shift of a PN sequence. Conversely, there is a fixed permutation that can be applied to each cyclic shift of a PN sequence to get the different Walsh codes (except for the extra bit that is the same for all Walsh codes, and of course, we don't get the ++++....+ sequence). In particular, if we wish to compute the all the cross-correlation values of a sequence x with a PN sequence, the easiest way to do this is to apply the fixed permutation to x and compute the Hadamard transform of the permuted x. A fast Hadamard transform algorithm is even more efficient than a fast Fourier transform algorithm since it needs O(N log N) additions and subtractions and NO multiplications, and was, in fact, used for telemetry data from the Mariner 9 mission to Mars about 35 years ago. See, for example, Chapter 14 of the MacWilliams and Sloane book "Theory of Error-Correcting Codes" --Dilip Sarwate
Dilip V. Sarwate wrote:> > Well, I wouldn't like to make such strong statements as nothing in > common. One bit is the same in each Walsh code, and if we drop > that, there is a fixed permutation that will map the remaining bits > of each Walsh code (except the +++....+ code) into a different > cyclic shift of a PN sequence.Very interesting. I didn't know about this property. Walsh and PN seem to belong to the different classes...> See, for example, > Chapter 14 of the MacWilliams and Sloane book "Theory of > Error-Correcting Codes"Certainly. I need to read this book. VLV
Reply by ●October 9, 20062006-10-09
johns@3db-labs.com wrote:> koolguyuf wrote: > > hey....I would like to know something about length 64 Walsh codes that > > are applied in CDMA 2000 1xEVDO....plz help....what is the difference > > between Walsh codes and PN sequences. > > > > Thanks > > TD > > The transmitter modulates multiplies the channels (pilot, traffic, etc) > with different Walsh codes. The codes are perfectly orthogonal to each > other. The length is variable (not fixed at 64). > > The entire transmission, containing a sum of multiple channels > separated by Walsh codes, is multiplied by a 32768-chip PN sequence. > Each tower has a unique PN code offset so that multiple towers can use > the same frequency. > > JohnHey John, Thanks for the reply. I assume that you are talking about the forward link, i.e from the Base Station to the mobiles ---- what happens on the reverse link then --- if every mobile uses the same frequency (as in CDMA) do each of the mobiles in a particular sector have a unique PN sequence ? Thanks, TD
koolguyuf wrote:> johns@3db-labs.com wrote: > > koolguyuf wrote: > > > hey....I would like to know something about length 64 Walsh codes that > > > are applied in CDMA 2000 1xEVDO....plz help....what is the difference > > > between Walsh codes and PN sequences. > > > > > > Thanks > > > TD > > > > The transmitter modulates multiplies the channels (pilot, traffic, etc) > > with different Walsh codes. The codes are perfectly orthogonal to each > > other. The length is variable (not fixed at 64). > > > > The entire transmission, containing a sum of multiple channels > > separated by Walsh codes, is multiplied by a 32768-chip PN sequence. > > Each tower has a unique PN code offset so that multiple towers can use > > the same frequency. > > > > John > > > Hey John, > > Thanks for the reply. I assume that you are talking about the forward > link, i.e from the Base Station to the mobiles ---- what happens on the > reverse link then --- if every mobile uses the same frequency (as in > CDMA) do each of the mobiles in a particular sector have a unique PN > sequence ? > > Thanks, > TDAffirmative. The mobiles operate on different Walsh channels. John
Reply by ●October 10, 20062006-10-10
good replies by greats indeed, walsh codes are used in synchronous CDMA or synchronous MC-CDMA or synchronous TFL-CDMA or synchronous MC-DS CDMA, and when synchronous walsh codes offer perfect orthogonality, in the sense complete zero Cross correlation. and its design is quite easy, its based on quadrant division method (i mean to say you can construct any walsh for that matter on paper within seconds) PN sequences are having near to zero Cross correlation. as told above these two are used for completely different purpose. regards particle (filter) reddy
johns@3db-labs.com wrote:> koolguyuf wrote: > > johns@3db-labs.com wrote: > > > koolguyuf wrote: > > > > hey....I would like to know something about length 64 Walsh codes that > > > > are applied in CDMA 2000 1xEVDO....plz help....what is the difference > > > > between Walsh codes and PN sequences. > > > > > > > > Thanks > > > > TD > > > > > > The transmitter modulates multiplies the channels (pilot, traffic, etc) > > > with different Walsh codes. The codes are perfectly orthogonal to each > > > other. The length is variable (not fixed at 64). > > > > > > The entire transmission, containing a sum of multiple channels > > > separated by Walsh codes, is multiplied by a 32768-chip PN sequence. > > > Each tower has a unique PN code offset so that multiple towers can use > > > the same frequency. > > > > > > John > > > > > > Hey John, > > > > Thanks for the reply. I assume that you are talking about the forward > > link, i.e from the Base Station to the mobiles ---- what happens on the > > reverse link then --- if every mobile uses the same frequency (as in > > CDMA) do each of the mobiles in a particular sector have a unique PN > > sequence ? > > > > Thanks, > > TD > > Affirmative. The mobiles operate on different Walsh channels. > > JohnHi John, Thanks for the help .I have one more question. I would like to know the mathematical/physical/intuitive significance of an erasure threshold in the decoder of a communication system. I am working in the simulation of a reverse link channel in the cdma 2000 system. Thanks,
