Hi, I'm trying to understand some Rake receiver structures for WCDMA and I'm having trouble with the interpolation stuff. Assuming down conversion to base band has been done, I think one possible way of doing a Rake is to: 1. sample at twice chip rate 2. RRC filter 3. Interpolate 4. Do timing adjust corresponding to tap delay 5. Decimate to chip rate 6. De-spread Steps 4 through 6 would be done for each Rake finger. My question is if one could do the RRC filtering and interpolation in one step, as in one single filter? Normally there's a low-pass filter after an interpolator and I thought the RRC filter could replace this low-pass filter. I this correct? Thanks in advance, /Fred
Started by ●September 26, 2006
