Hi, I am working on hw, and to find out the result I need to assume that the power spectrum density of a RP X(t) is always positive. Is it always true? Thanks
power spectrum density is always positive?
Started by ●September 26, 2006
Reply by ●September 26, 20062006-09-26
VijaKhara said the following on 26/09/2006 20:32:> Hi, > I am working on hw, and to find out the result I need to assume that > the power spectrum density of a RP X(t) is always positive. Is it > always true?Yes. Although I guess it's possible that rounding errors in calculations could lead to unintended negative values (in which case it's probably best to set -ve values to zero). -- Oli
Reply by ●September 27, 20062006-09-27
"VijaKhara" <VijaKhara@gmail.com> writes:> Hi, > I am working on hw, and to find out the result I need to assume that > the power spectrum density of a RP X(t) is always positive. Is it > always true?Hi Vija, Yes. I've tried to find a good proof but the only one I've come across (from both [schwartz] and [hayes]) is not really satisfying to me. Their proof stems from the fact that the PSD is equivalent to the expected value of the magnitude squared of the DFT of a section of the signal in the limit as that section's extent approaches infinity. Since the magnitude squared is always positive, so is the PSD. --Randy @book{schwartz, title = "Signal Processing: Discrete Spectral Analysis, Detection, and Estimation", author = "{Mischa~Schwartz and Leonard~Shaw}", publisher = "McGraw-Hill", year = "1975"} @BOOK{hayes, title = "{Statistical Digital Signal Processing and Modeling}", author = "{Monson~H.~Hayes}", publisher = "Wiley", year = "1996"} -- % Randy Yates % "Midnight, on the water... %% Fuquay-Varina, NC % I saw... the ocean's daughter." %%% 919-577-9882 % 'Can't Get It Out Of My Head' %%%% <yates@ieee.org> % *El Dorado*, Electric Light Orchestra http://home.earthlink.net/~yatescr
"VijaKhara" <VijaKhara@gmail.com> wrote in message news:1159299165.516373.60620@m73g2000cwd.googlegroups.com...> Hi, > I am working on hw, and to find out the result I need to assume that > the power spectrum density of a RP X(t) is always positive. Is it > always true? > > Thanks >If you square something the result is always positive. M. -- Posted via a free Usenet account from http://www.teranews.com
Randy Yates wrote:> "VijaKhara" <VijaKhara@gmail.com> writes: > >> Hi, >> I am working on hw, and to find out the result I need to assume that >> the power spectrum density of a RP X(t) is always positive. Is it >> always true? > > Hi Vija, > > Yes. I've tried to find a good proof but the only one I've > come across (from both [schwartz] and [hayes]) is not > really satisfying to me. > > Their proof stems from the fact that the PSD is equivalent > to the expected value of the magnitude squared of the DFT of > a section of the signal in the limit as that section's extent > approaches infinity. Since the magnitude squared is always > positive, so is the PSD. > > --RandyIn what way is "its the sum of some squares, so it can't go negative" unsatisfying? Are you concerned that is doesn't cover the possibility of the things you are squaring being complex? It seems to me another way of looking at this is heating and cooling. If the PSD could be negative, wouldn't that mean the signal could cool things down if it were appropriately filtered? While not exactly a proof, the notion that could happen seems absurd. Steve
On Wed, 27 Sep 2006 11:45:13 +0800, Steve Underwood <steveu@dis.org> wrote:>Randy Yates wrote: >> "VijaKhara" <VijaKhara@gmail.com> writes: >> >>> Hi, >>> I am working on hw, and to find out the result I need to assume that >>> the power spectrum density of a RP X(t) is always positive. Is it >>> always true? >> >> Hi Vija, >> >> Yes. I've tried to find a good proof but the only one I've >> come across (from both [schwartz] and [hayes]) is not >> really satisfying to me. >> >> Their proof stems from the fact that the PSD is equivalent >> to the expected value of the magnitude squared of the DFT of >> a section of the signal in the limit as that section's extent >> approaches infinity. Since the magnitude squared is always >> positive, so is the PSD. >> >> --Randy > >In what way is "its the sum of some squares, so it can't go negative" >unsatisfying? Are you concerned that is doesn't cover the possibility of >the things you are squaring being complex?One also needs to remember that when things are complex the calculation involves a transpose so the result is sum of two squares.
Hey theoreticians and hot air enthusiasts -
Duh. Key word is POWER. Can power be negative?
Tsk.
> Hi,
> always true?
> Thanks
VijaKhara skrev:> Hi, > I am working on hw, and to find out the result I need to assume that > the power spectrum density of a RP X(t) is always positive. Is it > always true?The PSD is (formally) 'non-negative', which is slightly different from 'positive'. The definition of the PSD is achieved through Parseval's identity to be P = sum |X(k)|^2 where |X(k)|^2 is the k'th coefficient of the PSD. Be aware that you have to use the unitary DFT or FT to get this to work, i.e. all the scaling coefficients need to be in all the correct places. If you are working on a theoretical justification, don't bring in the autocorrelation of x(t) since it has nothing to do with the *definition* of the PSD, it only describes and *estimator* for the PSD. As others already have commented, numerical errors might cause a vanishing coeffcient to pop out on the negative side. Rune
Major Misunderstanding said the following on 27/09/2006 04:20:> "VijaKhara" <VijaKhara@gmail.com> wrote in message > news:1159299165.516373.60620@m73g2000cwd.googlegroups.com... >> Hi, >> I am working on hw, and to find out the result I need to assume that >> the power spectrum density of a RP X(t) is always positive. Is it >> always true? >> >> Thanks >> > If you square something the result is always positive. >Except if it's complex. But that's OK, because PSD is really defined as magnitude squared, which is absolutely definitely always positive. -- Oli
Bill wrote:> Hey theoreticians and hot air enthusiasts -> Duh. Key word is POWER. Can power be negative?In the sense of the question, maybe not. Consider, though, instantaneous power (I times V) into a reactive load. Power can be a vector, and sometimes goes in the opposite direction. On the other hand, probability can never be negative. -- glen
