I try to use GEL function to access actual target DSP board and add options to Code Composer Studio's GEL menu. I just copy the code from examples: menuitem "Application Control" dialog Loada(loadxParma "Load") { processingLoad = loadxParma; } slider Gaina(0, 10 ,1, 1, gainyParma) { gain = gainyParma; } Of course, I define two integer variable processingLoad and gain in .c file. I find that, GEL function work well at most time, However, sometimes, in several DSP/BIOS application, it doesn't work and give a error report that is "cannot store to rvalue ". What's the problem with it? Thanks a lot!
Problem about using GEL function to access actual target DSP board
Started by ●September 29, 2006
