(This post regards compiling and linking to the FFTW library on Windows. Apologies if this is off-topic here.) I'm attempting to link an application to the FFTW .lib and .dll. I can build and run a raw c++ sample application perfectly, as follows: // testapp.cpp #include "fftw3.h" int main() { const unsigned int INPUT_SIZE 100; double* input = (double*)fftw_malloc(sizeof(double)*INPUT_SIZE); fftw_complex* output = (fftw_complex*)fftw_malloc(sizeof(fftw_complex) * INPUT_SIZE); fftw_plan plan = fftw_plan_dft_r2c_1d(INPUT_SIZE, input, output, FFTW_ESTIMATE | FFTW_UNALIGNED); for (unsigned int ir = 0; ir != N; ++ir) // fill input vector fftw_execute(plan); fftw_destroy_plan(plan); fftw_free(input); fftw_free(output); } build & link: cl.exe /c testapp.cpp link.exe /OUT:testapp.exe libfftw3-3.lib testapp.obj However, when I move the application to the .NET CLR (that is, compile with /clr), the app crashes with a System.TypeLoadException: Unhandled Exception: System.TypeLoadException: Could not load type fftw_plan_s from assembly qpFFT, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null. at main() Note that this is the same exact code. The only exception is adding '/clr' to the compile options. Is anyone familiar with using FFTW in a managed setting? I'd rather just use the first example, but, unfortunately, I'm trying to integrate it into an application that makes heavy use of the managed extensions. Thanks, Ryan
Using FFTW 3 DLL w/ CLR
Started by ●October 5, 2006
Reply by ●October 5, 20062006-10-05
rfr...@gmail.com wrote:> (This post regards compiling and linking to the FFTW library on > Windows. Apologies if this is off-topic here.) >Murphy's law....found it about 1 min after I posted this...some kind of versioning issue with new MS compilers: http://groups.google.com/group/microsoft.public.dotnet.languages.vc/browse_thread/thread/4d925c645c2ae163/f1b3c0a880685491?lnk=st&q=clr+dll+TypeLoadException&rnum=2&hl=en#f1b3c0a880685491
