Hello for everybody!!!!!!!!!!!!! I write a program for FHT(Hartley) and i wtite a flat top, hanning and hamming window function everything is ok here. Im analysing 2 signal of 60 Hz both. v=sin(2pif) i=sin(2pif-theta_i) theta=theta_v-theta_i if theta_i is between 0-27 degrees and theta_v=0 there�s no problem theta= angle between 0-27 but if theta_i is for example 28 or more (theta_v = 0) theta=-152, i dont know what happend, Can anyone help me? Im gonna appreciate. Tahnks!!!!!!!!!
Phase is affected by windowing?
Started by ●October 5, 2006
Reply by ●October 5, 20062006-10-05
On Oct 5, 5:50 pm, "Salvadorr" <salpi...@hotmail.com> wrote:> Hello for everybody!!!!!!!!!!!!! > > I write a program for FHT(Hartley) and i wtite a flat top, hanning and > hamming window function everything is ok here. Im analysing 2 signal of 60 > Hz both. > > v=3Dsin(2pif) > i=3Dsin(2pif-theta_i) > theta=3Dtheta_v-theta_i > > if theta_i is between 0-27 degrees and theta_v=3D0 there=B4s no problem t=heta=3D> angle between 0-27 but if theta_i is for example 28 or more (theta_v =3D=0)> theta=3D-152, i dont know what happend, Can anyone help me?Note that 28 + 152 =3D 180 degrees of phase. This is the type of difference that using an atan() instead of an atan2() function can produce.
Reply by ●October 6, 20062006-10-06
Salvadorr skrev:> I write a program for FHT(Hartley) and i wtite a flat top, hanning and > hamming window function everything is ok here. Im analysing 2 signal of 60 > Hz both. > > v=3Dsin(2pif) > i=3Dsin(2pif-theta_i) > theta=3Dtheta_v-theta_i > > if theta_i is between 0-27 degrees and theta_v=3D0 there=B4s no problem t=heta=3D> angle between 0-27 but if theta_i is for example 28 or more (theta_v =3D=0)> theta=3D-152, i dont know what happend, Can anyone help me?What you write here mixes radians and degrees. You do, of course, convert from degrees to radians in you computations? Rune
