Hi, I biult a two channel adaptive noise cancelling system. I used one microphone as a primary microphone, and the second one as noise microphone and picked up noise signal only. However, I found that this noise microphone also picks up a certain amount of speech, and introduce significant speech distortion after ANC. Can anybody give me some suggestions how to decrease this speech distortion? From both hardware and signal processing algorithms? Thanks a lot!
Started by ●October 6, 2006
Reply by ●October 6, 20062006-10-06
"Jing" <jing.deng@gmail.com> wrote in message news:XZqdnYypOuTj6rvYnZ2dnUVZ_sKdnZ2d@giganews.com...> Hi, > > I biult a two channel adaptive noise cancelling system. I used one > microphone as a primary microphone, and the second one as noise microphone > and picked up noise signal only. However, I found that this noise > microphone also picks up a certain amount of speech, and introduce > significant speech distortion after ANC. Can anybody give me some > suggestions how to decrease this speech distortion? From both hardware and > signal processing algorithms? Thanks a lot!This is one of the problems with the classical Widrow approach. You need to keep the microphones together and perhaps even have an array of mics. Then you are into the realms of Beamforming etc. M. -- Posted via a free Usenet account from http://www.teranews.com
Hi, But if I place two microphones together, I mean, very close to each other, general beamforming won't work well for this case. As distance between two microphones is very important for noise reduction. Did I get you correctly? Thanks.> >This is one of the problems with the classical Widrow approach. You needto>keep the microphones together and perhaps even have an array of mics.Then>you are into the realms of Beamforming etc. > > >M. > > > >-- >Posted via a free Usenet account from http://www.teranews.com > >
"Jing" <jing.deng@gmail.com> wrote in message news:CJidnUH7U7l-ebvYnZ2dnUVZ_sGdnZ2d@giganews.com...> > Hi, > > But if I place two microphones together, I mean, very close to each other, > > general beamforming won't work well for this case. As distance between two > microphones is very important for noise reduction. Did I get you > correctly? > Thanks. > > > > >This is one of the problems with the classical Widrow approach. You need > to > >keep the microphones together and perhaps even have an array of mics. > Then > >you are into the realms of Beamforming etc. > > > > > >M. > > > > > > > >-- > >Posted via a free Usenet account from http://www.teranews.com > > > > > >When you put them together there is a slight difference in interpretation. You may need a voice activity detector for instance and update during noise periods only.(otherwise freeze the weights). Look for papers on hearing aid adaptive noise cancellation. I don't believe the distance is as crucial as people make out though too close is not a good idea. Let's say the distance between the ears of an average human. There is a large literature on this - what is your application? M. -- Posted via a free Usenet account from http://www.teranews.com
