Hi, i have a problem with my McASP. I don't want use the DSP/BIOS so i configured the McASP with the CSL. On transmit/receive i hope to get an interrupt, but i don't get one. The entries in the config structures are from an other project without the use of CSL. So i think they are correct. But i think my initialisation is bugy !? I hope you can help me. code: #include "mcasp.h" #pragma DATA_SECTION(hMcasp, ".akonv"); volatile MCASP_Handle hMcasp; //*----------------------------------------------------------------------------*/ //* McASP initialization function //* //* port: McASP port //*----------------------------------------------------------------------------*/ void mcasp_init( Uint8 port ) { /* global registers */ MCASP_ConfigGbl cfgMCASPGBL = { /* pin function register */ MCASP_PFUNC_RMK( MCASP_PFUNC_AFSR_MCASP, /* McASP function */ MCASP_PFUNC_AHCLKR_MCASP, /* McASP function */ MCASP_PFUNC_ACLKR_MCASP, /* McASP function */ MCASP_PFUNC_AFSX_MCASP, /* McASP function */ MCASP_PFUNC_AHCLKX_MCASP, /* McASP function */ MCASP_PFUNC_ACLKX_MCASP, /* McASP function */ MCASP_PFUNC_AMUTE_MCASP, /* McASP function */ // MCASP_PFUNC_AXR15_MCASP, /* McASP function */ // MCASP_PFUNC_AXR14_MCASP, /* McASP function */ // MCASP_PFUNC_AXR13_MCASP, /* McASP function */ // MCASP_PFUNC_AXR12_MCASP, /* McASP function */ // MCASP_PFUNC_AXR11_MCASP, /* McASP function */ // MCASP_PFUNC_AXR10_MCASP, /* McASP function */ // MCASP_PFUNC_AXR9_MCASP, /* McASP function */ // MCASP_PFUNC_AXR8_MCASP, /* McASP function */ MCASP_PFUNC_AXR7_MCASP, /* McASP function */ MCASP_PFUNC_AXR6_MCASP, /* McASP function */ MCASP_PFUNC_AXR5_MCASP, /* McASP function */ MCASP_PFUNC_AXR4_GPIO, /* GPIO function: Timer1: TOUT1 */ MCASP_PFUNC_AXR3_MCASP, /* McASP function */ MCASP_PFUNC_AXR2_MCASP, /* McASP function */ MCASP_PFUNC_AXR1_MCASP, /* McASP function */ MCASP_PFUNC_AXR0_MCASP /* McASP function */ ), /* pin direction register */ MCASP_PDIR_RMK( MCASP_PDIR_AFSR_DEFAULT, /* Input: None */ MCASP_PDIR_AHCLKR_IN, /* Input: MCLK */ MCASP_PDIR_ACLKR_DEFAULT, /* Input: None */ MCASP_PDIR_AFSX_OUT, /* Output: LRCLK */ MCASP_PDIR_AHCLKX_IN, /* Input: MCLK */ MCASP_PDIR_ACLKX_OUT, /* Output: BCLK */ MCASP_PDIR_AMUTE_DEFAULT, /* Input: None */ // MCASP_PDIR_AXR15_DEFAULT, /* Input: None */ // MCASP_PDIR_AXR14_DEFAULT, /* Input: None */ // MCASP_PDIR_AXR13_DEFAULT, /* Input: None */ // MCASP_PDIR_AXR12_DEFAULT, /* Input: None */ // MCASP_PDIR_AXR11_DEFAULT, /* Input: None */ // MCASP_PDIR_AXR10_DEFAULT, /* Input: None */ // MCASP_PDIR_AXR9_DEFAULT, /* Input: None */ // MCASP_PDIR_AXR8_DEFAULT, /* Input: None */ MCASP_PDIR_AXR7_OUT, /* Output: D_DATA_OUT */ MCASP_PDIR_AXR6_OUT, /* Output: A_DATA_OUT */ MCASP_PDIR_AXR5_DEFAULT, /* Input: None */ MCASP_PDIR_AXR4_OUT, /* Output: Timer1 */ MCASP_PDIR_AXR3_IN, /* Input: D_DATA_IN2 */ MCASP_PDIR_AXR2_IN, /* Input: D_DATA_IN */ MCASP_PDIR_AXR1_IN, /* Input: A_DATA_IN2 */ MCASP_PDIR_AXR0_IN /* Input: A_DATA_IN */ ), /* DIT mode control register */ MCASP_DITCTL_RMK( MCASP_DITCTL_VB_ZERO, /* valid bit for odd time slots (right subframe) */ MCASP_DITCTL_VA_ZERO, /* valid bit for even time slots (left subframe) */ MCASP_DITCTL_DITEN_TDM /* TDM or Burst mode */ ), /* digital loopback control register */ MCASP_DLBCTL_RMK( MCASP_DLBCTL_MODE_DEFAULT, /* loopback generator mode */ MCASP_DLBCTL_ORD_DEFAULT, /* loopback order */ MCASP_DLBCTL_DLBEN_DISABLE /* loopback disabled */ ), /* audio mute control register */ MCASP_AMUTE_RMK( MCASP_AMUTE_XDMAERR_DISABLE, /* transmit DMA error */ MCASP_AMUTE_RDMAERR_DISABLE, /* receive DMA error */ MCASP_AMUTE_XCKFAIL_DISABLE, /* transmit clock failure */ MCASP_AMUTE_RCKFAIL_DISABLE, /* receive clock failure */ MCASP_AMUTE_XSYNCERR_DISABLE, /* unexpected transmit frame synx error */ MCASP_AMUTE_RSYNCERR_DISABLE, /* unexpected receive frame synx error */ MCASP_AMUTE_XUNDRN_DISABLE, /* transmiter underrun error */ MCASP_AMUTE_ROVRN_DISABLE, /* receiver overrun error */ // MCASP_AMUTE_INSTAT_DEFAULT, /* AMUTEIN pin inactive */ MCASP_AMUTE_INEN_DISABLE, /* AMUTEIN is ignored by AMUTE */ // MCASP_AMUTE_INPOL_ACTHIGH, /* polarity is active high */ MCASP_AMUTE_MUTEN_DISABLE /* AMUTE pin disabled */ ) }; /* receive registers */ MCASP_ConfigRcv cfgMCASPRCV = { /* receive format unit bit mask register */ 0x00FFFFFF, /* masked with value of rpad,rpbit in rfmt */ /* receive bit stream format register */ MCASP_RFMT_RMK( MCASP_RFMT_RDATDLY_0BIT, /* receive bit delay */ MCASP_RFMT_RRVRS_MSBFIRST, /* bitsream is MSB first */ MCASP_RFMT_RPAD_RPBIT, /* pad extra bits with one specified by RPBIT */ MCASP_RFMT_RPBIT_OF(0x23), /* use bit 23 to pad extra bits */ MCASP_RFMT_RSSZ_32BITS, /* slot size ist 32 bits */ MCASP_RFMT_RBUSEL_CFG, /* reads from XRBUF[n] originate on configuration bus */ MCASP_RFMT_RROT_8BITS /* rotate rigth by 8 bit positions */ ), /* receive frame sync control register */ MCASP_AFSRCTL_RMK( MCASP_AFSRCTL_RMOD_OF(0x02), /* 2-slot TDM */ MCASP_AFSRCTL_FRWID_WORD, /* single word */ MCASP_AFSRCTL_FSRM_INTERNAL, /* internally generated receive frame sync */ MCASP_AFSRCTL_FSRP_ACTIVEHIGH /* rising edge indicates the beginning of frame */ ), /* receive clock control register */ MCASP_ACLKRCTL_RMK( MCASP_ACLKRCTL_CLKRP_RISING, /* sample at rising edge of the serial clock */ MCASP_ACLKRCTL_CLKRM_INTERNAL, /* internal receive clock source: sysclock2 */ MCASP_ACLKRCTL_CLKRDIV_OF(0x01) /* divide receive clock by 2 (BCLK: 12,288) */ ), /* receive high-frequency clock control register */ MCASP_AHCLKRCTL_RMK(MCASP_AHCLKRCTL_HCLKRM_EXTERNAL, /* external clock from AHCLKR */ MCASP_AHCLKRCTL_HCLKRP_RISING, /* rising edge */ MCASP_AHCLKRCTL_HCLKRDIV_OF(0x01) /* divide receive clock by 2 (BCLK: 12,288) */ ), /* receive TDM slot register */ 0x00000002, /* TDM time slot 0,1 active */ /* receiver interrupt control register */ MCASP_RINTCTL_RMK( MCASP_RINTCTL_RSTAFRM_ENABLE, /* receive start of frame... */ MCASP_RINTCTL_RDATA_ENABLE, /* receive data ready... */ MCASP_RINTCTL_RLAST_ENABLE, /* receive last slot... */ MCASP_RINTCTL_RDMAERR_ENABLE, /* receive DMA error... */ MCASP_RINTCTL_RCKFAIL_ENABLE, /* receive clock failure... */ MCASP_RINTCTL_RSYNCERR_ENABLE, /* unexpected receive frame sync... */ MCASP_RINTCTL_ROVRN_ENABLE /* receiver overrun... */ /* interrupt does generate a McASP receive interrupt */ ), /* receive clock check control register */ MCASP_RCLKCHK_RMK( MCASP_RCLKCHK_RCNT_DEFAULT, /* */ MCASP_RCLKCHK_RMAX_DEFAULT, /* */ MCASP_RCLKCHK_RMIN_DEFAULT, /* */ MCASP_RCLKCHK_RPS_DIVBY1 /* check prescaler */ ) }; /* transmit registers */ MCASP_ConfigXmt cfgMCASPXMT = { /* transmit format unit bit mask register */ 0x00FFFFFF, /* masked with value of xpad,xpbit in xfmt */ /* transmit bit stream format register */ MCASP_XFMT_RMK( MCASP_XFMT_XDATDLY_0BIT, /* receive bit delay */ MCASP_XFMT_XRVRS_MSBFIRST, /* bitsream is MSB first */ MCASP_XFMT_XPAD_ZERO, /* pad extra bits with zero */ MCASP_XFMT_XPBIT_OF(0x00), /* pad extra bits with zero */ MCASP_XFMT_XSSZ_32BITS, /* slot size ist 32 bits */ MCASP_XFMT_XBUSEL_CFG, /* writes to XRBUF[n] originate from configuration bus */ MCASP_XFMT_XROT_24BITS /* rotate rigth by 24 bit positions */ ), /* transmit frame sync control register */ MCASP_AFSXCTL_RMK( MCASP_AFSXCTL_XMOD_OF(0x02), /* 2-slot TDM */ MCASP_AFSXCTL_FXWID_WORD, /* single word */ MCASP_AFSXCTL_FSXM_INTERNAL, /* internally generated transmit frame sync */ MCASP_AFSXCTL_FSXP_ACTIVELOW /* falling edge indicates the beginning of frame */ ), /* transmit clock control register */ MCASP_ACLKXCTL_RMK( MCASP_ACLKXCTL_CLKXP_FALLING, /* sample at falling edge of the serial clock */ MCASP_ACLKXCTL_ASYNC_SYNC, /* synchronous clock for transmit and receive */ MCASP_ACLKXCTL_CLKXM_INTERNAL, /* internal transmit clock source: sysclock2 */ MCASP_ACLKXCTL_CLKXDIV_OF(0x01) /* divide transmit clock by 2 (BCLK: 12,288) */ ), /* transmit high-frequency clock control register */ MCASP_AHCLKXCTL_RMK(MCASP_AHCLKXCTL_HCLKXM_EXTERNAL, /* external clock from AHCLKX */ MCASP_AHCLKXCTL_HCLKXP_RISING, /* rising edge */ MCASP_AHCLKXCTL_HCLKXDIV_OF(0x01) /* divide transmit clock by 2 (BCLK: 12,288) */ ), /* transmit TDM slot register */ 0x00000002, /* TDM time slot 0,1 active */ /* transmit interrupt control register */ MCASP_XINTCTL_RMK( MCASP_XINTCTL_XSTAFRM_ENABLE, /* transmit start of frame... */ MCASP_XINTCTL_XDATA_ENABLE, /* transmit data ready... */ MCASP_XINTCTL_XLAST_ENABLE, /* transmit last slot... */ MCASP_XINTCTL_XDMAERR_ENABLE, /* transmit DMA error... */ MCASP_XINTCTL_XCKFAIL_ENABLE, /* transmit clock failure... */ MCASP_XINTCTL_XSYNCERR_ENABLE, /* unexpected transmit frame sync... */ MCASP_XINTCTL_XUNDRN_ENABLE /* transmit overrun... */ /* interrupt does generate a McASP transmit interrupt */ ), /* transmit clock check control register */ MCASP_XCLKCHK_RMK( MCASP_XCLKCHK_XCNT_DEFAULT, /* */ MCASP_XCLKCHK_XMAX_DEFAULT, /* */ MCASP_XCLKCHK_XMIN_DEFAULT, /* */ MCASP_XCLKCHK_XCKFAILSW_DISABLE,/* transmit clock failure detect */ MCASP_XCLKCHK_XPS_DIVBY1 /* check prescaler */ ) }; /* serial control registers */ MCASP_ConfigSrctl cfgMCASPSRCTL = { /* serializer control register 0 */ MCASP_SRCTL_RMK( MCASP_SRCTL_DISMOD_LOW, /* drive on pin logic */ MCASP_SRCTL_SRMOD_RCV /* serializer is receiver */ ), /* serializer control register 1 */ MCASP_SRCTL_RMK( MCASP_SRCTL_DISMOD_LOW, /* drive on pin logic */ MCASP_SRCTL_SRMOD_RCV /* serializer is receiver */ ), /* serializer control register 2 */ MCASP_SRCTL_RMK( MCASP_SRCTL_DISMOD_LOW, /* drive on pin logic */ MCASP_SRCTL_SRMOD_RCV /* serializer is receiver */ ), /* serializer control register 3 */ MCASP_SRCTL_RMK( MCASP_SRCTL_DISMOD_LOW, /* drive on pin logic */ MCASP_SRCTL_SRMOD_XMT /* serializer is transmitter */ ), /* serializer control register 4 */ MCASP_SRCTL_RMK( MCASP_SRCTL_DISMOD_LOW, /* drive on pin logic */ MCASP_SRCTL_SRMOD_XMT /* serializer is transmitter */ ), /* serializer control register 5 */ MCASP_SRCTL_RMK( MCASP_SRCTL_DISMOD_LOW, /* drive on pin logic */ MCASP_SRCTL_SRMOD_XMT /* serializer is transmitter */ ), /* serializer control register 6 */ MCASP_SRCTL_RMK( MCASP_SRCTL_DISMOD_LOW, /* drive on pin logic */ MCASP_SRCTL_SRMOD_XMT /* serializer is transmitter */ ), /* serializer control register 7 */ MCASP_SRCTL_RMK( MCASP_SRCTL_DISMOD_LOW, /* drive on pin logic */ MCASP_SRCTL_SRMOD_XMT /* serializer is transmitter */ ) }; if ( port == 0 ) hMcasp = MCASP_open( MCASP_DEV0, MCASP_OPEN_RESET ); else hMcasp = MCASP_open( MCASP_DEV1, MCASP_OPEN_RESET ); if ( hMcasp != INV ) { MCASP_configRcv( hMcasp, &cfgMCASPRCV ); MCASP_configXmt( hMcasp, &cfgMCASPXMT ); MCASP_configSrctl( hMcasp, &cfgMCASPSRCTL ); MCASP_configGbl( hMcasp, &cfgMCASPGBL ); /* enable clocks */ MCASP_enableHclk( hMcasp, MCASP_XMTRCV ); while(!( MCASP_FGETH( hMcasp, GBLCTL, XHCLKRST ))); MCASP_enableClk( hMcasp, MCASP_XMTRCV ); while(!( MCASP_FGETH( hMcasp, GBLCTL, XCLKRST ))); // edma_init(0); /* sets EDMA */ WakeRcvXmt(); /* wake up the serializer (receivers) and state machine */ /* enable frame sync */ MCASP_enableFsync( hMcasp, MCASP_RCVXMT ); while(!(MCASP_FGETH( hMcasp,GBLCTL,RFRST ) & MCASP_FGETH( hMcasp,GBLCTL,XFRST ))); } } //*----------------------------------------------------------------------------*/ //* McASP Wakeup function //* //* wake up the receiver by taking the serializer and state machine out of reset //*----------------------------------------------------------------------------*/ void WakeRcvXmt() { /* enable serializer */ MCASP_enableSers( hMcasp, MCASP_RCVXMT ); while(!(MCASP_FGETH( hMcasp,GBLCTL,RSRCLR ) & MCASP_FGETH( hMcasp,GBLCTL,XSRCLR ))); MCASP_FGETH( hMcasp, GBLCTL, XSRCLR ); // while(MCASP_FGETH( hMcasp, XSTAT, XDATA )); MCASP_enableSm( hMcasp, MCASP_RCVXMT ); while(!(MCASP_FGETH( hMcasp,GBLCTL,RSMRST ) & MCASP_FGETH( hMcasp,GBLCTL,XSMRST ))); MCASP_FGETH( hMcasp, GBLCTL, XSMRST ); }
McASP Initialisation on C6713
Started by ●October 10, 2006
Reply by ●March 30, 20072007-03-30
Hi, i solved the problem with some wait loops. //*----------------------------------------------------------------------------*/ //* McASP initialization function //* //* port: McASP port //*----------------------------------------------------------------------------*/ void mcasp_init( ) { /* global registers */ MCASP_ConfigGbl cfgMCASPGBL = { /* pin function register */ ........... }; hMcasp = MCASP_open( MCASP_DEV1, MCASP_OPEN_RESET ); if ( hMcasp != INV ) { MCASP_configGbl( hMcasp, &cfgMCASPGBL ); MCASP_configRcv( hMcasp, &cfgMCASPRCV ); MCASP_configXmt( hMcasp, &cfgMCASPXMT ); MCASP_configSrctl( hMcasp, &cfgMCASPSRCTL ); /* enable clocks */ MCASP_enableHclk( hMcasp, MCASP_RCVXMT ); while(!( MCASP_FGETH( hMcasp, GBLCTL, XHCLKRST ) && MCASP_FGETH( hMcasp, GBLCTL, RHCLKRST ))); MCASP_enableClk( hMcasp, MCASP_XMTRCV ); while(!( MCASP_FGETH( hMcasp, GBLCTL, XCLKRST ) && MCASP_FGETH( hMcasp, GBLCTL, RCLKRST ))); edma_init( ); /* enable serializer */ MCASP_enableSers( hMcasp, MCASP_RCVXMT ); while(!(MCASP_FGETH( hMcasp,GBLCTL,RSRCLR ) && MCASP_FGETH( hMcasp,GBLCTL,XSRCLR ))); /* enable state machine */ MCASP_enableSm( hMcasp, MCASP_RCVXMT ); while(!(MCASP_FGETH( hMcasp,GBLCTL,RSMRST ) && MCASP_FGETH( hMcasp,GBLCTL,XSMRST ))); /* enable frame sync */ MCASP_enableFsync( hMcasp, MCASP_RCVXMT ); while(!(MCASP_FGETH( hMcasp,GBLCTL,RFRST ) && MCASP_FGETH( hMcasp,GBLCTL,XFRST ))); /* wait for clock synchronise (no clock failure detected) */ while ( MCASP_FGETH( hMcasp, RSTAT, RCKFAIL ) ) { MCASP_RSETH( hMcasp, RSTAT, 0x0000ffff); /* wait one HCLK period (128) */ for ( i = 0; i < 150; i++ ) asm(" nop"); } while ( MCASP_FGETH( hMcasp, XSTAT, XCKFAIL ) ) { MCASP_RSETH( hMcasp, XSTAT, 0x0000ffff); for ( i = 0; i < 150; i++ ) asm(" nop"); } } } And with the following functions i checked the states in debug-mode after the mcasp initialisation and in the main loop. //*----------------------------------------------------------------------------*/ //* State Machine Check Function //* //* check the XSTAT and RSTAT register //* //* this function is only for debug //* //* check: register to check //*----------------------------------------------------------------------------*/ void sm_error( int check ) { /* int error = 0; if ( check & 0x1 ) error = 1; // underrun if ( check & 0x2 ) error = 1; // sync error if ( check & 0x4 ) error = 1; // clock fail if ( check & 0x8 ) error = 1; // tdm slot is even if ( check & 0x10 ) error = 1; // slot is the last in frame if ( check & 0x20 ) error = 1; // data is cp from buf to rsr if ( check & 0x40 ) error = 1; // new frame detected if ( check & 0x80 ) error = 1; // dma error if ( check & 0x100 ) error = 1; // error*/ } //*----------------------------------------------------------------------------*/ //* TDM Sequencer Check Function //* //* check the XSLOT and RSLOT register //* current receive/transmit time slot //* //* this function is only for debug //* //*----------------------------------------------------------------------------*/ void tdm_check( ) { /* int error = 0; rcvcount = MCASP_getRslotcnt( hMcasp ); xmtcount = MCASP_getXslotcnt( hMcasp ); if ( rcvcount != 0x1 ) if ( rcvcount != 0x2 ) error = 1; // Receive time slot 2 is inactive else error = 2; // Receive time slot 1 is inactive if ( xmtcount != 0x1 ) if ( xmtcount != 0x2 ) error = 1; // Transmit time slot 2 is inactive else error = 2; // Transmit time slot 1 is inactive*/ } //*----------------------------------------------------------------------------*/ //* MCASP Check Function //* //* check if clock, hclock, serializer, sm and frame sync is running //* //* this function is only for debug //* //*----------------------------------------------------------------------------*/ void gblctl_check() { /* int error = 0; gblctl = MCASP_getGblctl( hMcasp, MCASP_RCVXMT ); rcvgblctl = MCASP_getGblctl( hMcasp, MCASP_RCV ); xmtgblctl = MCASP_getGblctl( hMcasp, MCASP_XMT ); if( !(gblctl & 0x1) ) error = 1; // clock divider is in reset if( !(gblctl & 0x2) ) error = 1; // hclock divider.. if( !(gblctl & 0x4) ) error = 1; // serializer.. if( !(gblctl & 0x8) ) error = 1; // state machine.. if( !(gblctl & 0x10) ) error = 1; // frame sync..*/ } I hope it helps. Good luck. _____________________________________ Do you know a company who employs DSP engineers? Is it already listed at http://dsprelated.com/employers.php ?
And this are my configs: /* global registers */ MCASP_ConfigGbl cfgMCASPGBL = { /* pin function register */ MCASP_PFUNC_RMK( MCASP_PFUNC_AFSR_MCASP, /* McASP function */ MCASP_PFUNC_AHCLKR_MCASP, /* McASP function */ MCASP_PFUNC_ACLKR_MCASP, /* McASP function */ MCASP_PFUNC_AFSX_MCASP, /* McASP function */ MCASP_PFUNC_AHCLKX_MCASP, /* McASP function */ MCASP_PFUNC_ACLKX_MCASP, /* McASP function */ MCASP_PFUNC_AMUTE_MCASP, /* McASP function */ MCASP_PFUNC_AXR7_MCASP, /* McASP function */ MCASP_PFUNC_AXR6_MCASP, /* McASP function */ MCASP_PFUNC_AXR5_MCASP, /* McASP function */ MCASP_PFUNC_AXR4_GPIO, /* GPIO function: Timer1: TOUT1 */ MCASP_PFUNC_AXR3_MCASP, /* McASP function */ MCASP_PFUNC_AXR2_MCASP, /* McASP function */ MCASP_PFUNC_AXR1_MCASP, /* McASP function */ MCASP_PFUNC_AXR0_MCASP /* McASP function */ ), /* pin direction register */ MCASP_PDIR_RMK( MCASP_PDIR_AFSR_DEFAULT, /* Input: None */ MCASP_PDIR_AHCLKR_IN, /* Input: AUX-CLK */ MCASP_PDIR_ACLKR_DEFAULT, /* Input: None */ MCASP_PDIR_AFSX_OUT, /* Output: LRCLK */ MCASP_PDIR_AHCLKX_IN, /* Input: AUX-CLK */ MCASP_PDIR_ACLKX_OUT, /* Output: BCLK */ MCASP_PDIR_AMUTE_DEFAULT, /* Input: None */ MCASP_PDIR_AXR7_OUT, /* Output: H_DATA_OUT */ MCASP_PDIR_AXR6_OUT, /* Output: D_DATA_OUT */ MCASP_PDIR_AXR5_OUT, /* Input: A_DATA_OUT */ MCASP_PDIR_AXR4_OUT, /* Output: Timer1 */ MCASP_PDIR_AXR3_IN, /* Input: D_DATA_IN2 */ MCASP_PDIR_AXR2_IN, /* Input: D_DATA_IN */ MCASP_PDIR_AXR1_IN, /* Input: A_DATA_IN2 */ MCASP_PDIR_AXR0_IN /* Input: A_DATA_IN */ ), /* DIT mode control register */ MCASP_DITCTL_RMK( MCASP_DITCTL_VB_ZERO, /* valid bit for odd time slots (right subframe) */ MCASP_DITCTL_VA_ZERO, /* valid bit for even time slots (left subframe) */ MCASP_DITCTL_DITEN_TDM /* TDM or Burst mode */ ), /* digital loopback control register */ /* output of the transmit serializers is connected internally to the in put of the receive serializers. */ /* Therefore you can check the receive data against the transmit data */ MCASP_DLBCTL_RMK( MCASP_DLBCTL_MODE_DEFAULT, /* loopback generator mode */ MCASP_DLBCTL_ORD_DEFAULT, /* loopback order */ MCASP_DLBCTL_DLBEN_DISABLE /* loopback disabled */ ), /* audio mute control register */ MCASP_AMUTE_RMK( MCASP_AMUTE_XDMAERR_DISABLE, /* transmit DMA error */ MCASP_AMUTE_RDMAERR_DISABLE, /* receive DMA error */ MCASP_AMUTE_XCKFAIL_DISABLE, /* transmit clock failure */ MCASP_AMUTE_RCKFAIL_DISABLE, /* receive clock failure */ MCASP_AMUTE_XSYNCERR_DISABLE, /* unexpected transmit frame synx error */ MCASP_AMUTE_RSYNCERR_DISABLE, /* unexpected receive frame synx error */ MCASP_AMUTE_XUNDRN_DISABLE, /* transmiter underrun error */ MCASP_AMUTE_ROVRN_DISABLE, /* receiver overrun error */ MCASP_AMUTE_INEN_DISABLE, /* AMUTEIN is ignored by AMUTE */ MCASP_AMUTE_MUTEN_DISABLE /* AMUTE pin disabled */ ) }; /* receive registers */ MCASP_ConfigRcv cfgMCASPRCV = { /* receive format unit bit mask register */ 0x00FFFFFF, /* masked with value of rpad,rpbit in rfmt */ /* receive bit stream format register */ MCASP_RFMT_RMK( MCASP_RFMT_RDATDLY_0BIT, /* receive bit delay */ MCASP_RFMT_RRVRS_MSBFIRST, /* bitsream is MSB first */ MCASP_RFMT_RPAD_RPBIT, /* pad extra bits with one specified by RPBIT */ MCASP_RFMT_RPBIT_OF(0x17), /* use bit 23 to pad extra bits */ MCASP_RFMT_RSSZ_32BITS, /* slot size ist 32 bits */ MCASP_RFMT_RBUSEL_DAT, /* reads from XRBUF[n] originate on configuration bus */ MCASP_RFMT_RROT_8BITS /* rotate rigth by 8 bit positions */ ), /* receive frame sync control register (LRCLK) */ MCASP_AFSRCTL_RMK( MCASP_AFSRCTL_RMOD_OF(0x02), /* 2-slot TDM (of 32) */ MCASP_AFSRCTL_FRWID_WORD, /* single word */ MCASP_AFSRCTL_FSRM_INTERNAL, /* internally generated receive frame sync */ MCASP_AFSRCTL_FSRP_ACTIVEHIGH /* rising edge indicates the beginning of frame */ ), /* receive clock control register (BCLK) */ /* if receive and transmit transmissions are synchron, this register is irrelevant */ MCASP_ACLKRCTL_RMK( MCASP_ACLKRCTL_CLKRP_RISING, /* sample at rising edge of the serial clock */ MCASP_ACLKRCTL_CLKRM_EXTERNAL, /* external receive clock source: AHCLKR */ MCASP_ACLKRCTL_CLKRDIV_OF(0x01) /* divide receive clock by 2 (BCLK: 12,288) */ ), /* receive high-frequency clock control register (MCLK) */ MCASP_AHCLKRCTL_RMK(MCASP_AHCLKRCTL_HCLKRM_EXTERNAL, /* external clock from AHCLKR */ MCASP_AHCLKRCTL_HCLKRP_RISING, /* rising edge */ MCASP_AHCLKRCTL_HCLKRDIV_OF(0x01) /* divide receive clock by 2 (BCLK: 12,288) */ ), /* receive TDM slot register */ 0x00000003, /* TDM time slot 0,1 active */ /* receiver interrupt control register */ MCASP_RINTCTL_RMK( MCASP_RINTCTL_RSTAFRM_DISABLE, /* receive start of frame... */ MCASP_RINTCTL_RDATA_DISABLE, /* receive data ready... */ MCASP_RINTCTL_RLAST_DISABLE, /* receive last slot... */ MCASP_RINTCTL_RDMAERR_DISABLE, /* receive DMA error... */ MCASP_RINTCTL_RCKFAIL_DISABLE, /* receive clock failure... */ MCASP_RINTCTL_RSYNCERR_DISABLE, /* unexpected receive frame sync... */ MCASP_RINTCTL_ROVRN_DISABLE /* receiver overrun... */ /* interrupt does generate a McASP receive interrupt */ ), /* receive clock check control register */ MCASP_RCLKCHK_RMK( MCASP_RCLKCHK_RCNT_DEFAULT, /* */ MCASP_RCLKCHK_RMAX_OF(128), /* */ MCASP_RCLKCHK_RMIN_OF(127), /* */ MCASP_RCLKCHK_RPS_DIVBY1 /* check prescaler */ ) }; /* transmit registers */ MCASP_ConfigXmt cfgMCASPXMT = { /* transmit format unit bit mask register */ 0x00FFFFFF, /* masked with value of xpad,xpbit in xfmt */ /* transmit bit stream format register */ MCASP_XFMT_RMK( MCASP_XFMT_XDATDLY_0BIT, /* receive bit delay */ MCASP_XFMT_XRVRS_MSBFIRST, /* bitsream is MSB first */ MCASP_XFMT_XPAD_ZERO, /* pad extra bits with zero */ MCASP_XFMT_XPBIT_OF(0x00), /* pad extra bits with zero */ MCASP_XFMT_XSSZ_32BITS, /* slot size ist 32 bits */ MCASP_XFMT_XBUSEL_DAT, /* writes to XRBUF[n] originate from configuration bus */ MCASP_XFMT_XROT_24BITS /* rotate rigth by 24 bit positions */ ), /* transmit frame sync control register (LRCLK) */ MCASP_AFSXCTL_RMK( MCASP_AFSXCTL_XMOD_OF(0x02), /* 2-slot TDM (of 32) */ MCASP_AFSXCTL_FXWID_WORD, /* single word */ MCASP_AFSXCTL_FSXM_INTERNAL, /* internally generated transmit frame sync */ MCASP_AFSXCTL_FSXP_ACTIVEHIGH /* falling edge indicates the beginning of frame */ ), /* transmit clock control register (BCLK) */ MCASP_ACLKXCTL_RMK( MCASP_ACLKXCTL_CLKXP_FALLING, /* sample at falling edge of the serial clock */ MCASP_ACLKXCTL_ASYNC_SYNC, /* synchronous clock for transmit and receive */ MCASP_ACLKXCTL_CLKXM_INTERNAL, /* external transmit clock source: AHCLKX */ MCASP_ACLKXCTL_CLKXDIV_OF(0x01) /* divide transmit clock by 2 (BCLK: 12,288) */ ), /* transmit high-frequency clock control register (MCLK) */ MCASP_AHCLKXCTL_RMK(MCASP_AHCLKXCTL_HCLKXM_EXTERNAL, /* external clock from AHCLKX */ MCASP_AHCLKXCTL_HCLKXP_RISING, /* rising edge */ MCASP_AHCLKXCTL_HCLKXDIV_OF(0x01) /* divide transmit clock by 2 (BCLK: 12,288) */ ), /* transmit TDM slot register */ 0x00000003, /* TDM time slot 0,1 active */ /* transmit interrupt control register */ MCASP_XINTCTL_RMK( MCASP_XINTCTL_XSTAFRM_DISABLE, /* transmit start of frame... */ MCASP_XINTCTL_XDATA_DISABLE, /* transmit data ready... */ MCASP_XINTCTL_XLAST_DISABLE, /* transmit last slot... */ MCASP_XINTCTL_XDMAERR_DISABLE, /* transmit DMA error... */ MCASP_XINTCTL_XCKFAIL_DISABLE, /* transmit clock failure... */ MCASP_XINTCTL_XSYNCERR_DISABLE, /* unexpected transmit frame sync... */ MCASP_XINTCTL_XUNDRN_DISABLE /* transmit overrun... */ /* interrupt does generate a McASP transmit interrupt */ ), /* transmit clock check control register */ MCASP_XCLKCHK_RMK( MCASP_XCLKCHK_XCNT_DEFAULT, /* */ MCASP_XCLKCHK_XMAX_OF(128), /* */ MCASP_XCLKCHK_XMIN_OF(127), /* */ MCASP_XCLKCHK_XCKFAILSW_DISABLE,/* transmit clock failure detect */ MCASP_XCLKCHK_XPS_DIVBY1 /* check prescaler */ ) }; /* serial control registers */ MCASP_ConfigSrctl cfgMCASPSRCTL = { /* serializer control register 0 */ MCASP_SRCTL_RMK( MCASP_SRCTL_DISMOD_LOW, /* drive on pin logic */ MCASP_SRCTL_SRMOD_RCV /* serializer is receiver */ ), /* serializer control register 1 */ MCASP_SRCTL_RMK( MCASP_SRCTL_DISMOD_LOW, /* drive on pin logic */ MCASP_SRCTL_SRMOD_RCV /* serializer is receiver */ ), /* serializer control register 2 */ MCASP_SRCTL_RMK( MCASP_SRCTL_DISMOD_LOW, /* drive on pin logic */ MCASP_SRCTL_SRMOD_RCV /* serializer is receiver */ ), /* serializer control register 3 */ MCASP_SRCTL_RMK( MCASP_SRCTL_DISMOD_LOW, /* drive on pin logic */ MCASP_SRCTL_SRMOD_RCV /* serializer is transmitter */ ), /* serializer control register 4 */ MCASP_SRCTL_RMK( MCASP_SRCTL_DISMOD_DEFAULT, /* drive on pin logic */ MCASP_SRCTL_SRMOD_INACTIVE /* serializer is disabled */ ), /* serializer control register 5 */ MCASP_SRCTL_RMK( MCASP_SRCTL_DISMOD_LOW, /* drive on pin logic */ MCASP_SRCTL_SRMOD_XMT /* serializer is disabled */ ), /* serializer control register 6 */ MCASP_SRCTL_RMK( MCASP_SRCTL_DISMOD_LOW, /* drive on pin logic */ MCASP_SRCTL_SRMOD_XMT /* serializer is transmitter */ ), /* serializer control register 7 */ MCASP_SRCTL_RMK( MCASP_SRCTL_DISMOD_LOW, /* drive on pin logic */ MCASP_SRCTL_SRMOD_XMT /* serializer is transmitter */ ) }; _____________________________________ Do you know a company who employs DSP engineers? Is it already listed at http://dsprelated.com/employers.php ?
