Hi, I'm currently trying to find a way to interpolate a 1-dimensional signal using something like B=E9zier interpolation, my main problem being that I don't know exactly what matches to what I want. Basically, the signal that I want to interpolate is a user-created sound envelope in order to modulate a signal with it. Therefore, I consider windowed-sinc interpolation unsuitable due to the riples it would create, as well as spline interpolation, because it makes the curve have to go through the original points and thus you can get the "overshoot" effect that I want to avoid. The user-created envelope has a fixed sampling rate which is the sampling rate of the desired resulting signal divided by a certain ratio, for example 72. The B=E9zier interpolation sounds suitable, however I find that there are two problems with it. The first is that I don't see how to directly obtain equally spaced points, and secondly it seems that it would take an order as high as I have original points, and I absolutly want to avoid that, not even because of the computational cost but because I want my original points to have an influence limited to the very close neighborhood. As hard as I've looked on Google, mostly anything I've found about the B=E9zier interpolation and such applies to 2D vector graphics and 3D, which is also vector graphics, and hardly anything related to 1D signals with a fixed sampling rate. So what I'm looking for is a method for interpolating 1D fixed sampling rate signals into a 1D fixed sampling rate signal which sampling rate would be the original sampling rate mutiplied by a certain factor, the curve would have to go through is original points, to avoid any overshoot/riple effect, and, in order to limit the influence of original points, no point shall need more than 4 original points to be calculated. Thanks in advance
=?iso-8859-1?q?Discrete_B=E9zier_interpolation?=
Started by ●October 13, 2006
Reply by ●October 13, 20062006-10-13
Michel Rouzic wrote:> > Basically, the signal that I want to interpolate is a user-created > sound envelope in order to modulate a signal with it. Therefore, I > consider windowed-sinc interpolation unsuitable due to the riples it > would create, as well as spline interpolation, because it makes the > curve have to go through the original points and thus you can get the > "overshoot" effect that I want to avoid. The user-created envelope has > a fixed sampling rate which is the sampling rate of the desired > resulting signal divided by a certain ratio, for example 72.i dunno how to do Bezier, but it seems to me, if you are not needing to go exactly through the original points, you can use a windowed moving average. essentially a LPF where the impulse response is the window function for smoothing. FWIW, r b-j
Check out Catmull-Rom splines. An example of various splines is at: http://www.cse.unsw.edu.au/~lambert/splines/ -- Marco ________________________ Marc Reinig UCO/Lick Observatory Laboratory for Adaptive Optics "Michel Rouzic" <Michel0528@yahoo.fr> wrote in message news:1160720651.332717.290830@h48g2000cwc.googlegroups.com... Hi, I'm currently trying to find a way to interpolate a 1-dimensional signal using something like B�zier interpolation, my main problem being that I don't know exactly what matches to what I want. Basically, the signal that I want to interpolate is a user-created sound envelope in order to modulate a signal with it. Therefore, I consider windowed-sinc interpolation unsuitable due to the riples it would create, as well as spline interpolation, because it makes the curve have to go through the original points and thus you can get the "overshoot" effect that I want to avoid. The user-created envelope has a fixed sampling rate which is the sampling rate of the desired resulting signal divided by a certain ratio, for example 72. The B�zier interpolation sounds suitable, however I find that there are two problems with it. The first is that I don't see how to directly obtain equally spaced points, and secondly it seems that it would take an order as high as I have original points, and I absolutly want to avoid that, not even because of the computational cost but because I want my original points to have an influence limited to the very close neighborhood. As hard as I've looked on Google, mostly anything I've found about the B�zier interpolation and such applies to 2D vector graphics and 3D, which is also vector graphics, and hardly anything related to 1D signals with a fixed sampling rate. So what I'm looking for is a method for interpolating 1D fixed sampling rate signals into a 1D fixed sampling rate signal which sampling rate would be the original sampling rate mutiplied by a certain factor, the curve would have to go through is original points, to avoid any overshoot/riple effect, and, in order to limit the influence of original points, no point shall need more than 4 original points to be calculated. Thanks in advance
Michel Rouzic wrote:> => Hi, > => I'm currently trying to find a way to interpolate a 1-dimensional > signal using something like B=E9zier interpolation, my main problem > being that I don't know exactly what matches to what I want. > => Basically, the signal that I want to interpolate is a user-created > sound envelope in order to modulate a signal with it. =I'm not understanding your statement of the problem. Are you writing software? Do you want to have the user create a curve interactively on screen? This curve will represent the shape of your sound envelop (which I'm guessing, the software will then playback)? Where does the interpolation part come in? Once the curve is defined - do you want to be able to evaluate the curve at any arbitrary point so that you can display it to the screen and use it for adjusting the gain of the sound signal. Is the problem what sort of user input will be needed to create this curve that represents the envelope? -jim =>Therefore, I > consider windowed-sinc interpolation unsuitable due to the riples it > would create, as well as spline interpolation, because it makes the > curve have to go through the original points and thus you can get the > "overshoot" effect that I want to avoid. The user-created envelope has > a fixed sampling rate which is the sampling rate of the desired > resulting signal divided by a certain ratio, for example 72. > => The B=E9zier interpolation sounds suitable, however I find that there > are two problems with it. The first is that I don't see how to directly=> obtain equally spaced points, and secondly it seems that it would take > an order as high as I have original points, and I absolutly want to > avoid that, not even because of the computational cost but because I > want my original points to have an influence limited to the very close > neighborhood. > => As hard as I've looked on Google, mostly anything I've found about the > B=E9zier interpolation and such applies to 2D vector graphics and 3D, > which is also vector graphics, and hardly anything related to 1D > signals with a fixed sampling rate. > => So what I'm looking for is a method for interpolating 1D fixed sampling=> rate signals into a 1D fixed sampling rate signal which sampling rate > would be the original sampling rate mutiplied by a certain factor, the > curve would have to go through is original points, to avoid any > overshoot/riple effect, and, in order to limit the influence of > original points, no point shall need more than 4 original points to be > calculated. > => Thanks in advance----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =----
jim wrote:> Michel Rouzic wrote: > > > > Hi, > > > > I'm currently trying to find a way to interpolate a 1-dimensional > > signal using something like B=E9zier interpolation, my main problem > > being that I don't know exactly what matches to what I want. > > > > Basically, the signal that I want to interpolate is a user-created > > sound envelope in order to modulate a signal with it. > > I'm not understanding your statement of the problem. Are you writing > software? Do you want to have the user create a curve interactively on > screen? This curve will represent the shape of your sound envelop (which > I'm guessing, the software will then playback)? Where does the > interpolation part come in? Once the curve is defined - do you want to > be able to evaluate the curve at any arbitrary point so that you can > display it to the screen and use it for adjusting the gain of the sound > signal. Is the problem what sort of user input will be needed to create > this curve that represents the envelope?Yes I am writing software. The software is non-interactive. The user input is actually an image, the envelope is defined by the values of one line in the image. That one line is considered an envelope with a certain sampling rate, interpolated to the sampling rate of the signal to modulate. If you're wondering what can be the point of doing this, each line of the user-created image file represents an envelope, each line matching to a different signal, which is either a narrow bandwidth noise or a sine, their bandwidth or frequency being determined by the position of the line in the image, and a few user set parameters. Once every envelope is interpolated and modulated with its matching signal, everything is mixed together into a single signal and written to a sound file.
robert bristow-johnson wrote:> Michel Rouzic wrote: > > > > Basically, the signal that I want to interpolate is a user-created > > sound envelope in order to modulate a signal with it. Therefore, I > > consider windowed-sinc interpolation unsuitable due to the riples it > > would create, as well as spline interpolation, because it makes the > > curve have to go through the original points and thus you can get the > > "overshoot" effect that I want to avoid. The user-created envelope has > > a fixed sampling rate which is the sampling rate of the desired > > resulting signal divided by a certain ratio, for example 72. > > i dunno how to do Bezier, but it seems to me, if you are not needing to > go exactly through the original points, you can use a windowed moving > average. essentially a LPF where the impulse response is the window > function for smoothing.So basically I'd convolve my zero-stuffed signal with a (for example) blackman window? I've already considered that before, as it would get me pretty close to the result, but there's only one problem with it, it should introduce scalopping on sloppy parts of my envelope, and I want to avoid that.
Marc Reinig wrote:> Check out Catmull-Rom splines. An example of various splines is at: > > http://www.cse.unsw.edu.au/~lambert/splines/Great link, thanks a lot, that's what I really needed. From giving every method on this site a try, it seems that the cubic B-spline matches exactly to what I'm looking for. The Catmull-Rom splines go through the original points and therefore aren't suitable. Now that I know this, one problem remains. Apparently the cubic B-spline interpolation is based on putting together cubic B=E9zier segments, so the implementation should be very similar, which means that the problem of calculating directly my equally-spaced remains, and since mostly any documentation online on B=E9zier interpolation is all about 2D or 3D vectorial interpolation, I need help to find out how to do that.
Michel Rouzic wrote:> So what I'm looking for is a method for interpolating 1D fixed > sampling rate signals into a 1D fixed sampling rate signal which > sampling rate would be the original sampling rate mutiplied by a > certain factor, the curve would have to go through is original > points, to avoid any overshoot/riple effect, and, in order to > limit the influence of original points, no point shall need more > than 4 original points to be calculated.Sounds like this paper I found linked somewhere just yesterday is a match: http://adsabs.harvard.edu/abs/1990A&A...239..443S It gives a piecewise cubic interpolator with monotone pieces and a continuous first derivative. Martin -- Quidquid latine scriptum sit, altum viditur.
Reply by ●October 14, 20062006-10-14
Michel Rouzic wrote:> > Yes I am writing software. The software is non-interactive. The user > input is actually an image, the envelope is defined by the values of > one line in the image. That one line is considered an envelope with a > certain sampling rate, interpolated to the sampling rate of the signal > to modulate. >A b-spline typically has the same basis functions as beziers. That is, the b-spline is composed of bezier spans with constrained continuity at the joints. There are pretty much 2 ways you can use your data points to define a continuous b-spline curve that can be evaluated at any point you like. The easiest is to use the data points as the control points for the curve and then when you compute the value of the curve at a between point is just the weighted sum of the points in the immediate neighborhood. For instance, for a cubic b-spline you have the weighted sum of 4 points (2 on each side of the point being evaluated). The calculation can be using the standard cubic polynomial form. This will produce a smooth curve that does not pass thru the points. The coefficients can be the standard b-spline coefficients (bezier) or other forms. What that is doing is creating a curve that passes thru a filtered version of your original points. The filter is just a simple FIR low pass filter. To get your curve to pass thru the data points you would need to first apply the inverse of that FIR and then use the new set of points to create the curve. Technically the inverse needs to be an IRR filter applied in both directions. But it can also be done with another FIR that is a truncated version of the IRR's. Doing it that way means the curve won't pass perfectly thru the points but can be very close and usually results in a smoother curve. -jim> If you're wondering what can be the point of doing this, each line of > the user-created image file represents an envelope, each line matching > to a different signal, which is either a narrow bandwidth noise or a > sine, their bandwidth or frequency being determined by the position of > the line in the image, and a few user set parameters. Once every > envelope is interpolated and modulated with its matching signal, > everything is mixed together into a single signal and written to a > sound file.----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =----
