Hi, Is there a way to generate simulated phase noise samples starting from a arbitrary phase noise specification table that is given as pairs of [offset (kHz), mask (dBc/Hz)] for offsets such as 1 kHz, 10 kHz, ... upto 10 MHz + the integrated phase noise (in degrees) over a frequency range (say 1 kHz - 10 MHz) ? I would greatly appreciate if you can provide any references to papers that would get me started. Thanks, Vijay.
generating phase noise in software.
Started by ●October 14, 2006
