Wanted: Freeverb 2.0 source code
Started by Jesper B. Kristensen June 11, 2004
"Jon Harris" <goldentully@hotmail.com> wrote in message news:<2j8u18Fuutp6U1@uni-berlin.de>...
> The algorithm coding is relatively simple, but tuning all the various delay > lengths for a relatively smooth sound is the part where having the Freeverb > source is nice. One could spend hours tweaking those parameters to come up with > something decent, so if someone has already done this, it's nice to take > advantage of that. > > BTW, I had the source and e-mailed directly to Jesper. >
Hi Jon. Would you mind to send it to me as well? TIA. JaaC
Assuming your e-mail is valid, you should have it be now.
"Jaime Andres Aranguren Cardona" <jaime.aranguren@ieee.org> wrote in message
news:14a86f87.0406151518.457647ed@posting.google.com...
> > The algorithm coding is relatively simple, but tuning all the various delay > > lengths for a relatively smooth sound is the part where having the Freeverb > > source is nice. One could spend hours tweaking those parameters to come up
with
> > something decent, so if someone has already done this, it's nice to take > > advantage of that. > > > > BTW, I had the source and e-mailed directly to Jesper. > > > > Hi Jon. > > Would you mind to send it to me as well? > > TIA. > > JaaC
Any chance you could post the source, or email it to me too (remove
the underscore) - I haven't much coding experience, but those initial
settings would make the task a lot less daunting. I presume there's a
lot of prime numbers involved in the delays?
On Tue, 15 Jun 2004 11:45:42 -0700, "Jon Harris"
<goldentully@hotmail.com> wrote:
>The algorithm coding is relatively simple, but tuning all the various delay >lengths for a relatively smooth sound is the part where having the Freeverb >source is nice. One could spend hours tweaking those parameters to come up with >something decent, so if someone has already done this, it's nice to take >advantage of that. > >BTW, I had the source and e-mailed directly to Jesper.
Tony (remove the "_" to reply by email)
I agree that re-inventing the wheel doesn't make much sense.
As a rule of thumb, for reverbs based on comb and allpass filters it's
important that the spacing is mutually relatively prime - this will
minimize all resonances that might occur due to repeating patterns in
the delay configuration.
In most musical applications, good ears are crucial to developing and
tuning a particular algorithm. It's a bit like building an instrument:
90% of it come from knowledge and skill, the rest depends on good (and
trained) ears. But it's these 10% that really make the difference
between good and excellent.
--smb
Martin Eisenberg wrote:
> Quidquid latine dictum sit, altum viditur
Qui tacet consentit. :-) --smb
"Jesper Kristensen" <jbk@NOSPAMsnaps.dk> wrote in message
news:40cf78f9$0$22829$cc9e4d1f@news.dial.pipex.com...
> > Unfortunately I still haven't been able to find the source that is used in > the Freeverb VST plugin I found at > http://www.sonicspot.com/freeverb/freeverb.html. That version has additional > parameters such as high/low frequency damping and others that are not in the > sources I have found so far, but maybe the source was never made publicly > available for this particular version.
I haven't seen that myself. I just put single-pole LP filters in the feedback loops, adjusting the cut-off frequency to change HF damping.
> Anyway, I think I have found a bug in the Freeverb implementation - or maybe > this bug is what makes it sound good. In any case, it looks like the allpass > filters are not implemented correctly, as they don't have a flat magnitude > response but have comb-filter behaviour instead.
Interesting. I never used the code itself. I just used the tuning values and implemented by own all-pass and comb filters, testing each individually to verify correct response. But I thought that I compared my version to the plug-in and that it sounded the same, which would indicate that the binary really does use a correct all-pass. But I could be wrong about that as I didn't do any detailed analysis and it was a while ago. Try it both ways and see which one is better!
"Jon Harris" <goldentully@hotmail.com> wrote in message news:<2j9l9hFv6hs0U1@uni-berlin.de>...
> Assuming your e-mail is valid, you should have it be now. >
I got it. Thanks, Jon. JaaC
