I wont to calulate the derivative of the function f(x,y)=sin(x)*cos(y) in [0,6.28]x[0,6.28] (or any other function). I make the fft of f I make the product of the coefficient for the frequency,and calculate the inverse fft but there are strange oscillation in the derivative in the contour of the domain. I think i don't understand the allocation of the fourier coefficient(real and imaginay) inthe array. What's the right allocation?
Derivative of 2d function with fftw
Started by ●October 15, 2006
Reply by ●October 15, 20062006-10-15
charvellano wrote:> I wont to calulate the derivative of the function f(x,y)=sin(x)*cos(y) in > [0,6.28]x[0,6.28] (or any other function). > > I make the fft of f > I make the product of the coefficient for the frequency,and calculate the > inverse fft but there are strange oscillation in the derivative in the > contour of the domain. > I think i don't understand the allocation of the fourier coefficient(real > and imaginay) inthe array. What's the right allocation?I suspect that you are making a common error. When you take the derivative, you multiply the amplitude by the frequency. Because of aliasing, however, you have a choice of how you assign the frequencies, and you want the choice that has equal numbers of positive and negative frequencies in order to minimize the slope of the trigonometric interpolation. It is easier to explain in 1d. Suppose you have a DFT of length N. By inspecting the DFT definition, you could think of the N outputs as corresponding to (angular) frequencies 2*pi * [0:N-1] / T, in Matlab notation, where T is your total sampling time N*dt (dt = sampling interval). Then, you would take the derivative by multiplying the amplitudes by these frequencies (times i). This is wrong, however. Because of aliasing, you can take the coefficients [0:N-1] and add any integer multiple of N to them, so you have a choice of frequencies. The best choice, for Fourier differentiation and trigonometric interpolation, is to write them as [ [0:N/2-1], [-N/2:-1] ] (i.e. shift the second half by -N to make it negative). (Actually, the N/2 (Nyquist element) should be handled specially: half of its amplitude should be "assigned" to N/2 and the othe half to -N/2; from the point of view of differentiation, this implies N/2 term of the derivative is simply set to zero.) This choice of frequencies has several nice properties: it corresponds to a trigonometric interpolation with minimal mean-square slope, and it also interpolates real inputs to real outputs. Probably, you are using the [0:N-1] choice, which leads to erroneous high-frequency terms. Regards, Steven G. Johnson
this is my code in MATLAB(derivative with respect to the variable x of a funcion), i think it's ok with the product of frequencies, but the are always oscillation at the contour of domain,where's the error? xmin=0; ymin=0; M=200; N=200; dx=6.28/M; dy=6.28/N; x=linspace(0,6.2832,M); y=linspace(0,6.2832,N); %%ASSEGNO LA FUNZIONE%%%%%%%%% for j=1:M for j2=1:N funz(j,j2)=sin(xmin+j*dx-dx)*cos(ymin+j2*dy-dy)+cos(xmin+j*dx-dx)*sin(ymin+j2*dy-dy); end end fftw('planner','measure') funzfft=fft2(funz); for j=1:M/2 prod(j)=i*(j-1) ; end for j=M/2+1:M prod(j)=-prod(M-j+1); end for j=1:M/2 for j2=1:N h(j,j2)=funzfft(j,j2)*prod(j); end end for j=(M/2+1):M for j2=1:N h(j,j2)=funzfft(j,j2)*prod(j); end end deriv=real(ifft2(h));
charvellano wrote:> this is my code in MATLAB(derivative with respect to the variable x of a > funcion), i think it's ok with the product of frequencies, but the are > always oscillation at the contour of domain,where's the error? > > xmin=0; > ymin=0; > M=200; > N=200; > dx=6.28/M; > dy=6.28/N; > x=linspace(0,6.2832,M); > y=linspace(0,6.2832,N); >Hello Charvellano, I'm not a MATLAB guy, but one of the things to be careful about is having a whole number of periods in the sample space. Otherwise the leackage will show up as high frequencies, and this may be leading to your problem. I.e. it brings out the aliasing mentioned by Stephen. For example with just 5 points you would use points at 0,72,144,216, and 288 degrees. Not use 0,90,180,270,360 So try using a better value (more precise) for 2 pi and make sure the highest point is (N-1)/N * 2pi. Also try working with a 1-D case until it works properly. IHTH, Clay
Reply by ●October 16, 20062006-10-16
charvellano wrote:> for j=1:M/2 > prod(j)=i*(j-1) ; > end > for j=M/2+1:M > prod(j)=-prod(M-j+1); > endThis is wrong. Try: prod = [ i*[0:M/2-1], 0, i*[-M/2+1:-1] ]; which matches what I suggested (for the derivative along 1 dimension of length M). (If you don't see the difference, try printing out the result of your expression for M=16 compared to my expression...you have an off-by-1 error.)
> >This is wrong. Try: > >prod = [ i*[0:M/2-1], 0, i*[-M/2+1:-1] ]; >I made the changes but there are always these oscillations.. See the images of the derivative of f(x,y)=sin(x) (i know there is only a variable but it's perfect to see the oscillations) http://utenti.lycos.it/fragarghy/sinx2.jpg http://utenti.lycos.it/fragarghy/sinx.jpg It's seems the function is the correct derivative cos(x), but the oscillations..I plot also the primitive function sin(x) and it's perfect I notice that if i put the code for j=1:M/2 prod(j)=2*i*(j-1) ; end for j=M/2+1:M prod(j)=prod(M-j+1); end everything is ok, in the sense that the oscillations disappear, but i don't know why, becouse i think the product of frequencies is non matematically correct.
On 2006-10-16 17:11:56 -0300, "charvellano" <francesco_gargano@yahoo.it> said:> >> >> This is wrong. Try: >> >> prod = [ i*[0:M/2-1], 0, i*[-M/2+1:-1] ]; >> > > > I made the changes but there are always these oscillations.. > See the images of the derivative of f(x,y)=sin(x) (i know there is only a > variable but it's perfect to see the oscillations) > http://utenti.lycos.it/fragarghy/sinx2.jpg > http://utenti.lycos.it/fragarghy/sinx.jpg > > It's seems the function is the correct derivative cos(x), but the > oscillations..I plot also the primitive function sin(x) and it's perfect > > I notice that if i put the code > for j=1:M/2 > prod(j)=2*i*(j-1) ; end > for j=M/2+1:M > prod(j)=prod(M-j+1); end > > everything is ok, in the sense that the oscillations disappear, but i > don't know why, becouse i think the product of frequencies is non > matematically correct.The operational calculus for the real line is not the same as the operational calculus for the period indices. It is a minor algeraic exercise to figure out the Fourier transform pair for the forward difference. The multiplier you are looking for will be of the nature of exp( - 2 pi i k / N ) - 1 where i is the imaginary unit (often j for those who prefer i for current), k is a "frequency" index and N is the size of the finite discrete Fourier transform.
Gordon Sande wrote:> The operational calculus for the real line is not the same as the > operational calculus for the period indices. It is a minor algeraic > exercise to figure out the Fourier transform pair for the forward > difference. > > The multiplier you are looking for will be of the nature of > > exp( - 2 pi i k / N ) - 1 > > where i is the imaginary unit (often j for those who prefer i for current), > k is a "frequency" index and N is the size of the finite discrete Fourier > transform.Hi Gordon, despite your experience in DSP, I'm inclined to disagree with your advice. The formula you gave is equivalent to doing a first-order finite-difference approximation for the derivative. If this is what you want, you should just do it in the time-domain where it is O(N). The advantage of doing the derivative by multiplying the DFT by i*k (appropriately aliased), i.e. differentiating the trigonometric interpolation polynomial, is that it can achieve "spectral accuracy" for smooth functions (i.e. for a sampled version of a smooth function, the error in the derivative decreases at least exponentially fast with the density of sample points), and is much more accurate even if your function is only a few times differentiable. The formula you give is only first-order accurate regardless of how smooth the function is. This difference in accuracy is almost the whole point of doing FFT-based differentiation (e.g. in spectral methods for PDEs). Regards, Steven G. Johnson PS. Regarding the "ripples" the poster keeps seeing: maybe this is just a Gibb's phenomenon, of course, especially if the poster has a discontinuous image (in which case he should think hard about whether FFT-based differentiation is appropriate). It seemed prudent to eliminate the blatant bugs first, however.
stevenj@alum.mit.edu wrote:> The advantage of doing the derivative by multiplying the DFT by i*k > (appropriately aliased), i.e. differentiating the trigonometric > interpolation polynomial, is that it can achieve "spectral accuracy" > for smooth functions (i.e. for a sampled version of a smooth function, > the error in the derivative decreases at least exponentially fast with > the density of sample points), and is much more accurate even if your > function is only a few times differentiable.I should mention that this smoothness must include the periodic boundaries; if you have non-periodic data, all bets are off. That's why FFT differentiation is most useful in spectral methods for PDEs with periodic or related boundary conditions. (And Gauss himself first developed an FFT in the context of periodic astronomical observations that he wanted to interpolate.) Steven
Reply by ●October 17, 20062006-10-17
On 2006-10-16 23:11:28 -0300, stevenj@alum.mit.edu said:> Gordon Sande wrote: >> The operational calculus for the real line is not the same as the >> operational calculus for the period indices. It is a minor algeraic >> exercise to figure out the Fourier transform pair for the forward >> difference. >> >> The multiplier you are looking for will be of the nature of >> >> exp( - 2 pi i k / N ) - 1 >> >> where i is the imaginary unit (often j for those who prefer i for current), >> k is a "frequency" index and N is the size of the finite discrete Fourier >> transform. > > Hi Gordon, despite your experience in DSP, I'm inclined to disagree > with your advice. > > The formula you gave is equivalent to doing a first-order > finite-difference approximation for the derivative. If this is what > you want, you should just do it in the time-domain where it is O(N).Given that I said it was the forward difference it is hardly surprising that it is the forward difference.> The advantage of doing the derivative by multiplying the DFT by i*k > (appropriately aliased), i.e. differentiating the trigonometric > interpolation polynomial, is that it can achieve "spectral accuracy" > for smooth functions (i.e. for a sampled version of a smooth function, > the error in the derivative decreases at least exponentially fast with > the density of sample points), and is much more accurate even if your > function is only a few times differentiable. The formula you give is > only first-order accurate regardless of how smooth the function is. > This difference in accuracy is almost the whole point of doing > FFT-based differentiation (e.g. in spectral methods for PDEs).If you want to use some other difference approximation then it is a straightforward algebraic exercise to determine what the Fourier transform pair will be. The result will be more complicated but of the same general form as the first order term will always be there. The point is that while the real continuous operational calculus has many similarities to the operational calculus of the discrete periodic operational calculus the two situations are not the same. The modifications to go from one to the other are usually not profound but are not absent. The original poster wanted to to from one to the other without modification and compounded it by ignoring the most obvious difference, that of aliasing. The advantage of doing the forward difference as an exercise is that it shows how the algebra does the aliasing "automatically". Once past the tutorial aspects it is then time to worry about issues of whether a first order approximation is what is appropriate. The impression I got from the original posting was that this was an attempt at seeing the operational calculus in operation and not one of worrying about the details of optimizing some calculation. It seemed to be a case of wanting to walk before attempting to run.> Regards, > Steven G. Johnson > > PS. Regarding the "ripples" the poster keeps seeing: maybe this is just > a Gibb's phenomenon, of course, especially if the poster has a > discontinuous image (in which case he should think hard about whether > FFT-based differentiation is appropriate). It seemed prudent to > eliminate the blatant bugs first, however.
