Gordon Sande wrote:> If you want to use some other difference approximation then it is a > straightforward algebraic exercise to determine what the Fourier > transform pair will be. The result will be more complicated but of the > same general form as the first order term will always be there.No fixed-order finite difference approximation will match Fourier differentiation for accuracy, given a smooth function to be differentiated. Hence the fundamental difference in their formulation.> The point is that while the real continuous operational calculus has many > similarities to the operational calculus of the discrete periodic > operational calculus the two situations are not the same. The modifications > to go from one to the other are usually not profound but are not absent.The point is that the poster asked about the derivative, not the discrete calculus. It's fine to *explicitly* change the subject or recommend a different approach, of course; difference approximations are, naturally, simpler (although there's not much point in doing them by FFTs). What I object to is your implication that there is something inherently *wrong* about using ordinary calculus to do FFT differentiation, when the opposite is the case.> The original poster wanted to to from one to the other without > modification and compounded it by ignoring the most obvious difference, > that of aliasing. The advantage of doing the forward difference as an > exercise is that it shows how the algebra does the aliasing "automatically".It's fine to give exercises, but only when you explain what the point of the exercise is, and don't imply that the answer to exercise A is given by the quite different exercise B. Steven
Derivative of 2d function with fftw
Started by ●October 15, 2006
Reply by ●October 17, 20062006-10-17
Is there a solution to my problem? Your helps (thanks) weren't succesfull. I have no problem with other famous fft (numerical recipes,slower but perfect), but i need to program with fftw.
charvellano wrote:> Is there a solution to my problem? Your helps (thanks) weren't succesfull. > I have no problem with other famous fft (numerical recipes,slower but > perfect), but i need to program with fftw.If you have no problem with Numerical Recipes, then you screwed up in porting your code to Matlab, because Numerical Recipes and Matlab (and FFTW) use exactly the same layout of the frequency components, and compute exactly the same thing. The only possible differences are: a) you are using a different sign convention for the forward/inverse transforms in Numerical Recipes. (The Matlab fft function corresponds to the Numerical Recipes four1 function with isign=-1). This is easy to fix (just flip the sign of i when you multiply the frequencies). b) you are using the real-input FFT from Numerical Recipes, which only computes half the spectrum compared to the full complex FFT (as in Matlab's fft function) and so you didn't have to think about the aliasing of the negative half of the spectrum before. I would suggest debugging the 1d case first, before doing the 2d case. For example, the following should work: N = 50; % number of sample points x = linspace(0,2*pi,N+1); x = x(1:N); % periodic x coordinate (note that 2*pi == 0) f = 1 ./ (2 + cos(x)); % example function to be differentiated k = i * [ 0:N/2-1, 0, -N/2+1:-1]; % frequencies (properly aliased), scaled by 2*pi*i/(N*dx) dfdx = ifft(fft(f) .* k); % the derivative Then, if you compare to the analytical derivative, you see the error is pretty darn small (since this is a smooth function, FFT differentiation is extremely accurate): max(abs(dfdx - sin(x) ./ (2 + cos(x)).^2)) ans = 8.5432e-14 Regards, Steven G. Johnson
Reply by ●October 18, 20062006-10-18
Thanks Mr. Steven, but in 1d case there's no problem, while in 2d there is always the same problem! It's incredible! I compare the amplitude of each mode in 2d with both numerical recipes and fftw. I notice that in the case of funciton sin(x)*cos(y)+sin(y)*cos(y) (correspond to the imaginary part of exp(ix)*exp(iy) the 1-1 fourier mode) the numerical recipes set 0 (more precisely are of order 10^(-14)) all the mode different from 1-1, while fftw not set exactly to 0 these mode. Can be this the problem? I know the layout of mode in 2d or more dimension, but i have problem only coding with fftw. Thanks for your help
"charvellano" <francesco_gargano@yahoo.it> wrote in news:zc2dnXGEcdTFVqjYnZ2dnUVZ_oydnZ2d@giganews.com:> Thanks Mr. Steven, but in 1d case there's no problem, while in 2d > there is always the same problem! It's incredible! I compare the > amplitude of each mode in 2d with both numerical recipes and fftw. I > notice that in the case of funciton sin(x)*cos(y)+sin(y)*cos(y) > (correspond to the imaginary part of exp(ix)*exp(iy) the 1-1 fourier > mode) the numerical recipes set 0 (more precisely are of order > 10^(-14)) all the mode different from 1-1, while fftw not set exactly > to 0 these mode. Can be this the problem? I know the layout of mode in > 2d or more dimension, but i have problem only coding with fftw. Thanks > for your help > > >I haven't looked at the problem in depth, but I advise you to make a thorough pass through your matlab code and make sure you're not doing anything silly, like using the transpose operator, which will take a complex conjugate. -- Scott Reverse name to reply
Reply by ●October 20, 20062006-10-20
i notice the the problem of oscillations is only bound to certain functions. For example for the functionf f(x,y)=sin(x)^2,f(x,y)=cos(x)^2 it'all ok. But for the function f(x,y)=sin(x), f(x,y)=sin(x)*sin(y) there are problems. It's very strange.
charvellano wrote:> i notice the the problem of oscillations is only bound to certain > functions. > For example for the functionf f(x,y)=sin(x)^2,f(x,y)=cos(x)^2 it'all ok. > But for the function f(x,y)=sin(x), f(x,y)=sin(x)*sin(y) there are > problems. It's very strange.Notice that you have a difference between even and odd functions. An even function like sin(x)^2 has a purely real and even DFT, whereas an odd function is purely imaginary and odd. This strongly suggests that you are using the wrong sign for your imaginary part, or that you have the wrong symmetry in your frequencies, or something of that sort. Anyway, rest assured that it is a bug in your code, and ultimately you have to learn how to debug things yourself (remote debugging is offtopic for this newsgroup). Since you have one working code using numerical recipes, and numerical recipes and Matlab or FFTW compute exactly the same thing with exactly the same data layout, you simply have to step through your code line by line and figure out where it begins to differ. Good luck, Steven G. Johnson
stevenj@alum.mit.edu wrote in news:1161362721.191554.44400 @f16g2000cwb.googlegroups.com:> This strongly suggests that > you are using the wrong sign for your imaginary part, or that you have > the wrong symmetry in your frequencies, or something of that sort. >Exactly why I suggested going over the code for transpose operators. A ' will give you a complex conjugate in matlab, while a .' won't. I think this bites everyone in the butt once and only once. -- Scott Reverse name to reply
Reply by ●October 21, 20062006-10-21
