Let's say I have an embedded system with a small amount of RAM and I want to make an FFT of sampled data. But I don't need to make the FFT of the whole frequency range. Is there some kind of shortcut one can make to achieve this and save RAM? And let's say that the system isn't fast enough to make the FFT on the fly on the samples.
How to make FFT when having small amount of RAM?
Started by ●October 17, 2006
Reply by ●October 17, 20062006-10-17
Gelber wrote:> Let's say I have an embedded system with a small amount of RAM and I want to > make an FFT of sampled data. But I don't need to make the FFT of the whole > frequency range. Is there some kind of shortcut one can make to achieve this > and save RAM? > > > And let's say that the system isn't fast enough to make the FFT on the fly > on the samples. >1. What exactly are you trying to accomplish? Perhaps there are some better ways then the FFT. 2. The FFT of the size N takes 2N of memory at least. If you insist on the use of the FFT, the only way to reduce the memory load is to decimate your signal. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Gelber wrote:> Let's say I have an embedded system with a small amount of RAM and I want to > make an FFT of sampled data. But I don't need to make the FFT of the whole > frequency range. Is there some kind of shortcut one can make to achieve this > and save RAM?Just use the DFT (or DTFT) formula directly for the output bins that you want. For K outputs and N inputs, this has O(N K) complexity, which isn't too bad for small K. Moreover, if you are reading your inputs on the fly, you don't actually need to store all N inputs at once; the storage is only O(K). (There is also Goertzel's algorithm, which has similar complexity but saves a few operations over the straightforward DTFT formula, at the price of worse accuracy. In general these O(N K) formulas are less accurate than an FFT, unless you do something fancy like Kahan summation. But the rms errors aren't too bad, growing as O(N^0.5) for the DTFT and O(N^1.5) for Goertzel if I remember correctly.) Steven
Gelber wrote:> Let's say I have an embedded system with a small amount of RAM and I want to > make an FFT of sampled data. But I don't need to make the FFT of the whole > frequency range. Is there some kind of shortcut one can make to achieve this > and save RAM? > > > > And let's say that the system isn't fast enough to make the FFT on the fly > on the samples. >If the frequencies of interest are continuous, you may want to use what is sometimes known as a "zoom fft". Basically, tune to the center of the band of interest, low pass filter, decimate, and then perform the FFT at the decimated rate. By using multirate filtering, you can get very good space and cpu efficiency. -- Mark Borgerding 3dB Labs, Inc Innovate. Develop. Deliver.
Yes I concur. ZOOM FFT can analyze a narrow frequency band while still taking the advantage of fast transform. Step 1: select your center frequency f0 Step 2: multiply the data by sin(f0) and cos(f0) Step 3: Apply decimation filter so the data is reduced Step 4: Apply FFT with small size, say N = 64
On Tue, 17 Oct 2006 15:58:25 +0200, "Gelber" <gelb@nospam.com> wrote:>Let's say I have an embedded system with a small amount of RAM and I want to >make an FFT of sampled data. But I don't need to make the FFT of the whole >frequency range. Is there some kind of shortcut one can make to achieve this >and save RAM? > > > >And let's say that the system isn't fast enough to make the FFT on the fly >on the samples.Depending on how many output samples (bins) you want, you could compute the DFT for just the bins of interest. You'll need an input buffer of length N, and an output buffer of only the length needed. Of course, you could prune an FFT to do the same thing, but I think the memory saving may not be as big. Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
I have an idea. Could I do it like this? If I sample 100 samples at say 10 kHz, multiply them with a window function and then zero pad them with 900 zeros. Then I make an FFT of the band in interest. I repeat this 10 times and accumulate the bins (100 bins). Would I get a frequenzy resolution of 10 Hz with this method? If not I maybe try the zoom FFT procedure. I want to be able to make a sound analyzer tool with an ATMEL Atmega16 microcontroller connected with a graphical display presenting the frequency components. "Eric Jacobsen" <eric.jacobsen@ieee.org> skrev i meddelandet news:7e9aj29vtkgaf3ltb5to06minrful1pmdn@4ax.com...> On Tue, 17 Oct 2006 15:58:25 +0200, "Gelber" <gelb@nospam.com> wrote: > > >Let's say I have an embedded system with a small amount of RAM and I wantto> >make an FFT of sampled data. But I don't need to make the FFT of thewhole> >frequency range. Is there some kind of shortcut one can make to achievethis> >and save RAM? > > > > > > > >And let's say that the system isn't fast enough to make the FFT on thefly> >on the samples. > > Depending on how many output samples (bins) you want, you could > compute the DFT for just the bins of interest. You'll need an input > buffer of length N, and an output buffer of only the length needed. > > Of course, you could prune an FFT to do the same thing, but I think > the memory saving may not be as big. > > Eric Jacobsen > Minister of Algorithms, Intel Corp. > My opinions may not be Intel's opinions. > http://www.ericjacobsen.org
Gelber wrote:> Let's say I have an embedded system with a small amount of RAM and I want to > make an FFT of sampled data. But I don't need to make the FFT of the whole > frequency range. Is there some kind of shortcut one can make to achieve this > and save RAM?Another technique, called the Chirp Z transform, may be of use. The technique can compute the z transform of N points on the unit circle. Unlilke the FFT, the N points can be any number and can reside at any interval in the band. -V
Gery wrote:> I have an idea. > > > > Could I do it like this? If I sample 100 samples at say 10 kHz, multiply > them with a window function and then zero pad them with 900 zeros. Then I > make an FFT of the band in interest. I repeat this 10 times and accumulate > the bins (100 bins). Would I get a frequenzy resolution of 10 Hz with this > method? > > > > If not I maybe try the zoom FFT procedure. >Nope. The zero padding merely interpolates between the 10 Hz points; it doesn't reveal any input frequency content between them. Averaging improves the SNR but does not change the resolution. FWIW, I was confronted with a very similar problem about a year ago. After poking around a bit and asking the group I wound up doing a zoom FFT with a mixer, two stage decimating LPF, and a small complex FFT. John
Vladimir Vassilevsky wrote:>> 2. The FFT of the size N takes 2N of memory at least. If you insist on > the use of the FFT, the only way to reduce the memory load is to > decimate your signal. >You can reorder the computations in an FFT so that a size N FFT only uses the amount of memory required to hold the complex input or complex output (ie. number of samples times the number of bits to represent a complex sample). Look for "in-place FFT algorithm".
