Hi, I am modelling the physical layer of an 802.11 transmitter (to implement it into an FPGA). At this moment I want to design the digital filter responsible of pulse shaping (before the DAC). My doubts are: 1. FIR or IIR filter?, why?. 2. For each option (FIR or IIR) there are different types of filters (FIR: Raised_cos_Barlett, Raised_cos_Blackmann, etc, ... or IIR: Butterworth, Chebyshev, Bessel, ...) so, which should I choose?, why?. I enclose the requisites of the standard: The "transmit spectrum mask" , is defined as: ---------------------------------------------------------------------------------------- The transmitted spectral products shall be less than -30 dBr (dB relative to the SINx/x peak) for fc-22Mhz <f < fc-11Mhz; and fc+11Mhz <f< fc+22Mhz; and shall be less than -50 dBr for f<fc-22Mhz; and f>fc+22Mhz where fc is the channel center frequency. -------------------------------------------------------------------------------------------- Regards. Jajo
Design of a Filter
Started by ●October 19, 2006
