Does anyone here possibly have detailed information on Texas Instruments implementation of the LPC algorithm for speech compression? I am in the process of writing an LPC-T1 and LPC-10 encoder/decoder library in C# and I have Andy Fingerhut's LPC-10 code (which is in C, converted from Fortran). From the data manuals I have, LPC-10 has 53 bits per frame plus a sync frame. TI LPC has 49 bits (no sync) plus a 'repeat' bit. The other bit differences are in the coefficient lookup tables sizes it appears. I have several of the TI TMS5XXX series datasheets on my website at... http://www.gamearchive.com/General/Data_Sheets/ Before I go into severe specifics, I just wanted to know if anyone here might be willing to help me with this topic or had more info.. thanks
LPC-10 vs. Texas Instruments LPC
Started by ●October 20, 2006
Reply by ●October 20, 20062006-10-20
mhavoc wrote:> Does anyone here possibly have detailed information on Texas > Instruments implementation of the LPC algorithm for speech compression? > I am in the process of writing an LPC-T1 and LPC-10 encoder/decoder > library in C# and I have Andy Fingerhut's LPC-10 code (which is in C, > converted from Fortran). From the data manuals I have, LPC-10 has 53 > bits per frame plus a sync frame. TI LPC has 49 bits (no sync) plus a > 'repeat' bit. The other bit differences are in the coefficient lookup > tables sizes it appears. > > I have several of the TI TMS5XXX series datasheets on my website at... > > http://www.gamearchive.com/General/Data_Sheets/ > > Before I go into severe specifics, I just wanted to know if anyone here > might be willing to help me with this topic or had more info..A quick comparison shows not much in common, except for the basic scheme of using LPC. The quantisation of every parameter is different. There seems to be no special unvoiced processing in the TI LPC. Steve
Reply by ●October 21, 20062006-10-21
I just found Phil's HawkVoice library last night after searching the comp.dsp archives and I think that even tho it doesn't appear to support the TI LPC, it is at least a better starting ground than reworking Andy Fingerhuts code. I'm wrapping Phil's api into a C# class now and will run some sound wav's through the LPC encoder he has and see what it generates through a TI chip (most likely it won't work). I have all the TI lookup tables for the coefficients so I should be able to extend Phil's code to output native TI speech packets along with the TI enhancement of 'repeat' packets. I have to admit, I really don't know anything about speech synthesis but am coming at this for more of a specific need from left field and I can code in C and C#. :-) I will be sure to send anything I do to Phil in case he would like to include it in HawkVoice in case some other obscure person might need this functionality. If anyone has any random suggestions or tips on working with the TI LPC, let em fly, I will keep watch on this thread. You can also email me directly through the contact link at any of the following websites... http://www.gamearchive.com http://www.ipsnd.net http://level7.askey.org thanks... jess Steve Underwood wrote:> mhavoc wrote: > > Does anyone here possibly have detailed information on Texas > > Instruments implementation of the LPC algorithm for speech compression? > > I am in the process of writing an LPC-T1 and LPC-10 encoder/decoder > > library in C# and I have Andy Fingerhut's LPC-10 code (which is in C, > > converted from Fortran). From the data manuals I have, LPC-10 has 53 > > bits per frame plus a sync frame. TI LPC has 49 bits (no sync) plus a > > 'repeat' bit. The other bit differences are in the coefficient lookup > > tables sizes it appears. > > > > I have several of the TI TMS5XXX series datasheets on my website at... > > > > http://www.gamearchive.com/General/Data_Sheets/ > > > > Before I go into severe specifics, I just wanted to know if anyone here > > might be willing to help me with this topic or had more info.. > > A quick comparison shows not much in common, except for the basic scheme > of using LPC. The quantisation of every parameter is different. There > seems to be no special unvoiced processing in the TI LPC. > > Steve
