Hello, I presently working with a DSK6713 from Spectrum digital. The internal memory of the TMS320C6713 seems to be complicated. Does anyone know if the entire internal memory (256 Ko) could be use as SRAM ? Or if just 192 Ko could be use as SRAM ? Think
C6713 memory
Started by ●June 10, 2004
Reply by ●June 10, 20042004-06-10
The entire 256k bytes can be used as SRAM. If you can fit all of your program/data into 256k bytes then that is the recommended configuration. If you're going to be putting program/data into external RAM then you will want to use part of the internal RAM as L2 cache. Brad "seb" <germain1_fr@yahoo.fr> wrote in message news:23925133.0406101146.361ec516@posting.google.com...> Hello, > > I presently working with a DSK6713 from Spectrum digital. The internal > memory of the TMS320C6713 seems to be complicated. > > Does anyone know if the entire internal memory (256 Ko) could be use > as SRAM ? > Or if just 192 Ko could be use as SRAM ? > > Think
