I have a doubt with respect to the standard deviation of an N point signal. I have a book on statistics that says average deviation of an N point signal is the sum of the (difference between sample value and mean) divided by N. and that sum of the squares of the difference between sample value and mean divided by N gives the variance of the signal and the root of this gives standard deviation. Why is this squaring required? Sum of the squares of the deviation from mean gives the power of the current sample deviation and when we add all these powers up, and divide by total number of samples, we get the variance, root of which gives standard deviation, in other words, we're taking the root of the average deviation "power" of the signal to get the deviation or fluctuation of the signal from the mean value, How is this different from "adding all the (sample value - mean) values and dividing by the total number of samples? Why can't we just add all the sample deviation amplitudes and divide by N ? Why should we find the sample deviation power and then divide by N and take root ? Isn't it the same thing? Thanks a lot, With Regards, Joel
Standard Deviation
Started by ●October 24, 2006
Reply by ●October 24, 20062006-10-24
"Joel" <joelagnel@gmail.com> wrote in message news:1161671304.854671.253000@m7g2000cwm.googlegroups.com...>I have a doubt with respect to the standard deviation of an N point > signal. > > I have a book on statistics that says average deviation of an N point > signal > is the sum of the (difference between sample value and mean) divided by > N. > and that sum of the squares of the difference between sample value and > mean > divided by N gives the variance of the signal and the root of this > gives standard > deviation. > > Why is this squaring required? > > Sum of the squares of the deviation from mean gives the power of the > current > sample deviation and when we add all these powers up, and divide by > total number > of samples, we get the variance, root of which gives standard > deviation, in > other words, we're taking the root of the average deviation "power" of > the signal > to get the deviation or fluctuation of the signal from the mean value, > > How is this different from "adding all the (sample value - mean) values > and dividing > by the total number of samples? > > Why can't we just add all the sample deviation amplitudes and divide by > N ? > Why should we find the sample deviation power and then divide by N and > take root ? > Isn't it the same thing?No, it isn't. One is the sum of the deviations which will be both positive and negative. I'm not sure why that isn't equal to the mean. And, if the mean is zero then it would be zero. On the other hand, squaring the values gives all positive results and there will be a nonzero average. Fred
Joel wrote:> I have a doubt with respect to the standard deviation of an N point > signal.> I have a book on statistics that says average deviation of> an N point signal is the sum of the (difference between sample > value and mean) divided by N. and that sum of the squares of > the difference between sample value and mean> divided by N gives the variance of the signal and the root of this > gives standard deviation.> Why is this squaring required?The sum of the deviations from the mean will be zero. There are some statistics that use the average absolute value of the deviation from the mean, but that is rare. One reason for squaring is that the result is an analytical function, where absolute value is not. Median is much more common than absolute deviation, though somewhat harder to calculate. -- glen
Fred Marshall wrote:> "Joel" <joelagnel@gmail.com> wrote in message > news:1161671304.854671.253000@m7g2000cwm.googlegroups.com... > >>I have a doubt with respect to the standard deviation of an N point >>signal. >> >>I have a book on statistics that says average deviation of an N point >>signal >>is the sum of the (difference between sample value and mean) divided by >>N. >>and that sum of the squares of the difference between sample value and >>mean >>divided by N gives the variance of the signal and the root of this >>gives standard >>deviation. >> >>Why is this squaring required? >> >>Sum of the squares of the deviation from mean gives the power of the >>current >>sample deviation and when we add all these powers up, and divide by >>total number >>of samples, we get the variance, root of which gives standard >>deviation, in >>other words, we're taking the root of the average deviation "power" of >>the signal >>to get the deviation or fluctuation of the signal from the mean value, >> >>How is this different from "adding all the (sample value - mean) values >>and dividing >>by the total number of samples? >> >>Why can't we just add all the sample deviation amplitudes and divide by >>N ? >>Why should we find the sample deviation power and then divide by N and >>take root ? >>Isn't it the same thing? > > > No, it isn't. > > One is the sum of the deviations which will be both positive and negative. > I'm not sure why that isn't equal to the mean. And, if the mean is zero > then it would be zero. > > On the other hand, squaring the values gives all positive results and there > will be a nonzero average. > > Fred > > > >And even when the 'average deviation' is defined to be the average of the absolute values of the differences, this does not give the same numerical result as taking the square root of the average of the squares of the differences. Joel can check this with a short numerical example. Regards, John
Thanks a lot, that really helped. One thing, the book im reading says when 2 noise signals enter an electronic circuit, to get the resultant signal, we calculate the power of the 2 signals, add them and then take root to get the amplitudes. Why can't we just add the voltages of the 2 signals at any point of time to get the resultant signal. Regards, Joel
and to find the standard deviation, as you, said, a simple addition of the deviations from the mean will cancel them out so we go for squaring, why can't we just take the absolute value of all the deviation and add them without squaring. Thank you Joel
Joel wrote:> Thanks a lot, that really helped. > > One thing, the book im reading says when 2 noise signals enter an > electronic circuit, to get the resultant signal, we calculate the power > of the 2 signals, add them and then take root to get the amplitudes. > > Why can't we just add the voltages of the 2 signals at any point of > time to get the resultant signal. > > Regards, > > Joel >Joel, if the noise sources are independent, there will be no particular phase relationship between the various frequency components. Doing an addition would be useful only if all the components were in phase. However, we can add the two signal POWERS and then convert the total to a voltage.
Joel wrote:> and to find the standard deviation, as you, said, a simple addition > of the deviations from the mean will cancel them out so we go for > squaring, why can't we just take the absolute value of all the > deviation and add them without squaring.Hello Joel, your question is a good one, and is not asked often enough. Take a step back and look at what you are trying to do: you have some data, which you think is centered around a mean value, with some additional errors. One mathematical model for this situation is x_k = m + e_k, 1 <= k <= N, where x_k is your data, m is the mean value and e_k are random variables that follow some distribution. Usually you assume the e_k independent and identically distributed (the acronym is i.i.d.). From the data x_k you want to estimate m (called the "location" of the data), and you want to quantify how good the estimate is by determining how wide the data is spread about the location (called the "scale" or "dispersion" of the data). The assumption that the e_k are i.i.d. Gaussian distributed, e_k ~ N(0, s^2), and therefore x_k ~ N(m, s^2), with deviation s, is very common. In this case, there are optimal procedures to estimate m and s from the data x_k. They are the arithmetic mean and the (biased) sample deviation (SD), respectively. They are optimal in the sense that they yield the most accurate estimate given the size of the data set. Sometimes, instead of the biased SD, the unbiased SD is computed. The two differ only by a constant factor of sqrt(N/(N-1)). However, what happens if the errors are _not_ iid Gaussian? For example, what happens if the errors have larger tail probabilites? One very important special case is the possibility of gross outliers. If you consider a data set which is an instance of the Gaussian process, except for one error (perhaps a measurement error), which on a plot lies "far away" from the main bulk of the data - something *very* unlikely if the data really were Gaussian. It is immediate from the definition of the arithmetic mean and the SD that such an outlier has unbounded influence: if the outlier goes towards +/- infinity, so do the estimates. For this reason, so called "robust" statistical methods have been studied, which perform well in the Gaussian case, but where the influence of outliers is bounded. Examples are the median as an estimate for the mean, and the median absolute deviation from the median (abbreviated MAD) for the deviation. They tolerate a large percentage of outliers at the cost of efficiency. Another case is where the distribution of the errors is known, and not Gaussian. For example, if the errors are iid uniform. Again, one aims to find the optimal (as above) estimator. It turns out that the (scaled) standard absolute deviation (SAD) is the optimal estimator for two-sided exponentially distributed errors (I think, I might be wrong about the exact distribution). Such estimators are called M-estimators for Maximum likelihood: they aim to be optimal (with respect to maximizing the likelihood function). The SAD also has the property that it is more robust against slight deviation from Gaussian errors than the SD. This fact was known already known to some astronomer (whose name I always forget), who pushed the SAD instead of the SD for astronomical observations, where the error distributions are known to deviate from Gaussian. So, you see that your question is justified, and that knowing the answer is fundamental to knowing how to correctly apply these statistical methods. Regards, Andor
Joel wrote:> I have a doubt with respect to the standard deviation of an N point > signal. > > I have a book on statistics that says average deviation of an N point > signal > is the sum of the (difference between sample value and mean) divided by > N. > and that sum of the squares of the difference between sample value and > mean > divided by N gives the variance of the signal and the root of this > gives standard > deviation. > > Why is this squaring required?Because it makes the math easy. This is a good thing, because if you step away from the standard deviation as a measure of 'goodness' then you step away from solving problems analytically, and are left groping in the dark with simulations.> > Sum of the squares of the deviation from mean gives the power of the > current > sample deviation and when we add all these powers up, and divide by > total number > of samples, we get the variance, root of which gives standard > deviation, in > other words, we're taking the root of the average deviation "power" of > the signal > to get the deviation or fluctuation of the signal from the mean value, > > How is this different from "adding all the (sample value - mean) values > and dividing > by the total number of samples?1/N * sum over N of (sample value - mean) = (1/N sum over N of sample value) - mean = mean - mean = 0. Always. Identically. Very boring.> > Why can't we just add all the sample deviation amplitudes and divide by > N ? > Why should we find the sample deviation power and then divide by N and > take root ? > Isn't it the same thing?I suggest you take some of your "why nots" and work them out on paper, to see what results you get. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Posting from Google? See http://cfaj.freeshell.org/google/ "Applied Control Theory for Embedded Systems" came out in April. See details at http://www.wescottdesign.com/actfes/actfes.html
Joel wrote:> Thanks a lot, that really helped. > > One thing, the book im reading says when 2 noise signals enter an > electronic circuit, to get the resultant signal, we calculate the power > of the 2 signals, add them and then take root to get the amplitudes.Not quite. To get the power of the composite, you add the powers of the components only if they are "orthogonal". Random noise signals, by their random nature, are orthogonal. So by the way, are sin(x) and cos(x), and sin(x) and sin(kx) where k ~= 1.> Why can't we just add the voltages of the 2 signals at any point of > time to get the resultant signal.The sum of the voltages *is* the the voltage signal. We don't normally know much about noise beyond its statistical properties, and we deal with noise *power*. Power is proportional to the square of voltage. If you think about it, you'll see that that makes those puzzling squaring operations agree with what's real. Let's take some examples. In both, we add two known (not just statistically characterized) signals and examine the result. 1. v1 = Vsin(wt); v2 = Vcos(wt). p1 = V^2*sin^2(wt)/R; p2 = V^2*cos^2(wt)/R p1 + p2 = V^2*[sin^2(wt) + cos^2(wt)]/R = V^2/R Those are instantaneous powers, and we need to integrate over a complete cycle then divide by the period to get the average, but since our sum is constant, we needn't bother in this case. Now consider v3 = v1 + v2 = sin(wt) + cos(wt) = sqrt(2)*sin(wt + pi/4). The instantaneous power is v3^2/R, and the average power is 1 2*pi 1 --- * integral (v3^2 dt) * ---. Work it out to get -- tada! -- V^2/R 2*pi 0 R The signals are orthogonal, so the sum of the powers is the power of the sum of the voltages. 2. v1 = Vsin(wt); v2 = Vsin(wt). p1 = V^2*sin^2(wt)/R; p2 = V^2*sin^2(wt)/R p1 + p2 = V^2*[sin^2(wt) + sin^2(wt)]/R = V^2/R, as before. Now consider v3 = v1 + v2 = sin(wt) + sin(wt) = 2*sin(wt) I leave you to show that the power of the combined signal is 2*v^2/R. The signals are not orthogonal, so the sum of the powers is not the power of the sum of the voltages. To summarize, the square of a composite signal is always proportional to its power. The sum of its component signal's powers is not always the composite signal's power. In a very direct way, that is the basis for the Fourier transform. Jerry -- "The rights of the best of men are secured only as the rights of the vilest and most abhorrent are protected." - Chief Justice Charles Evans Hughes, 1927 ���������������������������������������������������������������������
