I'm trying to implement a digital down-conversion using the Xilinx DDC core on an FPGA. I have a question about generating the CFIR coefficients from Matlab when you want a decimation rate of 2 (or more) from the CFIR. Matlab won't allow you to directly generate the coefficients in xilinx format using the command 'coewrite(HCfir)' because it is a multi-rate filter object (not sure what the problem is with that). Let's say I tell the Xilinx Coregen that I want a 20-tap symmetric CFIR with R=2. How are the coefficients in the .coe file ordered? Are the first 10 coefficients for the higher sampling rate input and the second 10 for after decimation? Also is there a work around to get Matlab to just generate the coefficients for me using coewrite?
Generating the coefficients for a Xilinx CFIR in Matlab
Started by ●October 25, 2006
