L. M. wrote:> The threshold of FM demodulator is for every type of demodulator > implementation.A kind of.> To demodulate an FM signal you need to differentiate the > phase over time.This is not right. The task is to measure the frequency. You don't have to differentiate the phase to do that.> > At low SNR the trajectory of the phase can cross the origin (zero amplitude) > on the wrong side (due to noise). This create a click. The threshold is the > SNR where this phenomena start occurring often.Don't mix the details of the implementation with the fundamental problems.> > Here is a simple example. In a sampled signal if the phase is going from 0 > to 45 degree in two steps 0, 22.5 and 45 degree. Let assume that the SNR is > very low and the path from 0 to 45 degree cross the origin at the middle > step and it is interpreted as 202.5 degree. This will result in a click > (large amplitude spike at the output of the demodulator). > > LMVladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
FM SNR theory
Started by ●October 26, 2006
Reply by ●October 27, 20062006-10-27
Tim Wescott wrote:> Vladimir Vassilevsky wrote: >>> I think that we should distinguish the theoretical performance of the >> FM from the inefficiency of the particular demodulator. >> Indeed, the "ideal case" performance of the FM can be derived.> Is there such a derivation on the web?For the ideal FM demodulator, it appears to be fairly straightforward. For the discriminators, it looks much more complex. I am too lazy to derive the estimates. I'd be interested in reading it> -- IIRC my Van Trees just gives some upper & lower bounds, not a > theoretical best performance.This has to do with a classical problem of the frequency estimation of the noisy signal. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Reply by ●October 28, 20062006-10-28
glen herrmannsfeldt wrote:> Vladimir Vassilevsky wrote: > >> The approximation quoted by John is valid on the two assumptions: >> 1. SNR is high. 2. The detector is a simple discriminator. > > I used to read about TV satellite signals, the big dish ones, not the > small dish ones now popular for home use. If I remember, they broadcast > something like six watts/channel spread over most of the US, and > probably some of the ocean. They depend on what I believe is called > the "FM advantage" to get a reasonable SNR out. Something like 25dB > better than they would otherwise get.Now about the "FM advantage": Suppose the FM is operating at the SNR well above the so-called "treshold". In this case, the absolute error in the frq. estimate is directly proportional to the SNR. However voltage error at the output of the demodulator is relative to the deviation. Therefore: (-Fd,+Fd) SNR at the output = SNR at the input --------- (0, Fs) Consider the FM broadcast: Fd ~ 75kHz, Fs ~ 15kHz, SNRout ~ 60dB. According to my coarse estimates: Threshold SNR at the input: ~ 30dB (in the bandwidth of Fs = 15kHz). FM advantage in SNR: ~20dB if operating at the SNR much higher then the threshold. The required SNR at the input ~ 40dB. So, the great ancient engineers definitely knew what they were doing... Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
"Vladimir Vassilevsky" <antispam_bogus@hotmail.com> wrote in message news:Bw30h.1287$s6.764@newssvr11.news.prodigy.com...> > > Randy Yates wrote: > > > John Sampson <johns@3db-labs.com> writes: > > > > > >>patrick.melet@dmradiocom.fr wrote: > >> > >>>>Pt = transmit carrier power A^2/2 > >>>>W = output LPF bandwidth > >>>>Fd = peak deviation > >>>>No = input noise density > >>>>m = modulating signal > >>>> > >>>>SNRo = 3 * mean(m^2) * (Fd / W)^2 * Pt / (No * W) > >>> > >>>so if my m signal is a sinus at 250 kHz with 1 V rms then mean(m^2) = > >>>0.5 > >>>if my Fd = 250 kHz and W = 250 kHz then (Fd / W)^2 = 1 > >>>if Pt / (No * W) = SNR input, at the input at the modulator I simulate > >>>the SNR (measure it) > >>>then SNRo = 3 * 0.5 * 1 * SNRi = 1.5 * SNRi > >>>is it exact ? > >>> > >> > >>You should see SNRo > SNRi when the discriminator operates above > >>threshold (no clicks). This is called FM improvement. I've obtained > >>good agreement with the theory in the past. > > > > > > Hi John, > > > > If the discriminator is just dtheta/dt where theta is the phase of the > > analytic baseband signal, then what is the thing you call the > > "threshold?" Just curious. > > Hello Randy, > > The approximation quoted by John is valid on the two assumptions: > 1. SNR is high. 2. The detector is a dumb discriminator. > > We should distinguish the properties of the FM signal itself from the > inefficiency of the particular demodulator. > > The discriminator goofs up when the normalized SNR falls below ~10dB. > The amateurs call this a "threshold".Not just amateurs! It's called the threshold effect in any text book on FM. You will see a graph of SNRo vs SNRin for various values of beta (FM modulation index). M. -- Posted via a free Usenet account from http://www.teranews.com
Reply by ●October 29, 20062006-10-29
"Vladimir Vassilevsky" <antispam_bogus@hotmail.com> wrote in message news:eOo0h.1676$s6.580@newssvr11.news.prodigy.com...> > > L. M. wrote: > > > The threshold of FM demodulator is for every type of demodulator > > implementation. > > A kind of. > > > To demodulate an FM signal you need to differentiate the > > phase over time. > > This is not right. The task is to measure the frequency. You don't have > to differentiate the phase to do that. > > >You are confusing phase modulation with FM. You need a differentiator of sorts. Even a PLL does this - it has an integrator (VCO) in its feedback path. M. -- Posted via a free Usenet account from http://www.teranews.com
"Vladimir Vassilevsky" <antispam_bogus@hotmail.com> wrote in message news:XdL0h.819$wX.56@newssvr12.news.prodigy.com...> > > glen herrmannsfeldt wrote: > > > Vladimir Vassilevsky wrote: > > > >> The approximation quoted by John is valid on the two assumptions: > >> 1. SNR is high. 2. The detector is a simple discriminator. > > > > I used to read about TV satellite signals, the big dish ones, not the > > small dish ones now popular for home use. If I remember, they broadcast > > something like six watts/channel spread over most of the US, and > > probably some of the ocean. They depend on what I believe is called > > the "FM advantage" to get a reasonable SNR out. Something like 25dB > > better than they would otherwise get. > > Now about the "FM advantage": > > Suppose the FM is operating at the SNR well above the so-called > "treshold". In this case, the absolute error in the frq. estimate is > directly proportional to the SNR. However voltage error at the output of > the demodulator is relative to the deviation. Therefore: > > (-Fd,+Fd) > SNR at the output = SNR at the input --------- > (0, Fs) > > > Consider the FM broadcast: Fd ~ 75kHz, Fs ~ 15kHz, SNRout ~ 60dB. > > According to my coarse estimates: > > Threshold SNR at the input: ~ 30dB (in the bandwidth of Fs = 15kHz). > FM advantage in SNR: ~20dB if operating at the SNR much higher then the > threshold. The required SNR at the input ~ 40dB. > > So, the great ancient engineers definitely knew what they were doing... >Now repeat the above with narrowband FM! FM has it's advantages at the expense of bandwidth. It's more power efficient than AM though - good for space travel.Let's face it - all modulation, digital or analogue is a variation on AM or FM. M. -- Posted via a free Usenet account from http://www.teranews.com
Major Misunderstanding wrote:> "Vladimir Vassilevsky" <antispam_bogus@hotmail.com> wrote in message > news:Bw30h.1287$s6.764@newssvr11.news.prodigy.com......>> The discriminator goofs up when the normalized SNR falls below ~10dB. >> The amateurs call this a "threshold". > > > > Not just amateurs! It's called the threshold effect in any text book on FM. > You will see a graph of SNRo vs SNRin for various values of beta (FM > modulation index).One aspect I'd like explained: the S/R improvement depends on beta, but how is beta defined for an unmodulated carrier? Jerry -- "The rights of the best of men are secured only as the rights of the vilest and most abhorrent are protected." - Chief Justice Charles Evans Hughes, 1927 ���������������������������������������������������������������������
Major Misunderstanding wrote:>>>To demodulate an FM signal you need to differentiate the >>>phase over time. >> >>This is not right. The task is to measure the frequency. You don't have >>to differentiate the phase to do that. >> >> > You are confusing phase modulation with FM. You need a differentiator of > sorts.No. There is absolutely no need for the differentiator. Even a PLL does this - it has an integrator (VCO) in its feedback> path.How about demodulating FM directly with a frequency counter? Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Major Misunderstanding wrote:>>Now about the "FM advantage": >>[...]> > Now repeat the above with narrowband FM! FM has it's advantages at the > expense of bandwidth.Narrowband FM may have the advantage over the AM because the AM transmitter is waisting ~90% power for the useless transmission of the carrier. Considering the same spectral densities of the sidebands, there is no advantage at all.> It's more power efficient than AM though - good for space travel.Let's face > it - all modulation, digital or analogue is a variation on AM or FM.It is much more usefull to think in the terms of Euclidean distances and correlation functions. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Vladimir Vassilevsky <antispam_bogus@hotmail.com> writes:> Major Misunderstanding wrote: > >>>>To demodulate an FM signal you need to differentiate the >>>>phase over time. >>> >>>This is not right. The task is to measure the frequency. You don't have >>>to differentiate the phase to do that. >>> >>> >> You are confusing phase modulation with FM. You need a differentiator of >> sorts. > > No. There is absolutely no need for the differentiator.Vladimir, Since f = d\theta / dt, and how can you say there is no need for a differentiator? How else would you recover an estimate of the original information signal if you didn't somehow determine the frequency of the modulated signal? -- % Randy Yates % "...the answer lies within your soul %% Fuquay-Varina, NC % 'cause no one knows which side %%% 919-577-9882 % the coin will fall." %%%% <yates@ieee.org> % 'Big Wheels', *Out of the Blue*, ELO http://home.earthlink.net/~yatescr
