FM SNR theory
Started by Unknown ●October 26, 2006
Eric Jacobsen wrote:
>>You may think of finding maximum of the Fourier transorm of the input >>signal. > > That seems like an incredibly inefficient way to demodulate FM.
This is just an example for those who believe the only ways to demodulate the FM is by a discriminator or PLL. There are many more algorithms for frequency estimation which trade the complexity for the performance.
>>This is the classical problem of the estimation of the frequency of the >>signal in the presence of noise. I beleive it is treated in many books >>on radars and statistical radiotechnics. > > > And there is the usual problem of the time-frequency uncertainty > principle.
Yes! Since the uncertainty is inverse proportional to log(SNR), it clearly explains why the FM SNR curve changes from the linear to the exponential. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Jerry Avins wrote:
(snip)
> But such subtleties aside, it is > possible to measure frequency directly without measuring phase. Indeed, > frequency is often much easier to measure than phase. A simple counter > may suffice.
You mean a phase integrator? -- glen
glen herrmannsfeldt wrote:
> Jerry Avins wrote: > > (snip) > >> But such subtleties aside, it is possible to measure frequency >> directly without measuring phase. Indeed, frequency is often much >> easier to measure than phase. A simple counter may suffice. > > You mean a phase integrator?
I was thinking of a a gated cycle counter. I suppose you could rename it. Jerry -- "The rights of the best of men are secured only as the rights of the vilest and most abhorrent are protected." - Chief Justice Charles Evans Hughes, 1927 ���������������������������������������������������������������������
