Hi, Following this discussion http://groups-beta.google.com/group/comp.dsp/browse_frm/thread/ffc12437efe8= 4f92/73394dc71a49b15b?lnk=3Dst&q=3D&rnum=3D1&hl=3Den#73394dc71a49b15b about which kind of interpolation suits my needs, I chose to try and implement one-dimensional cubic B-spline interpolation. However I failed, the result is a long way off what's supposed to happen, and I'm afraid I understood something wrong about cubic B-spline interpolation. Here's how I understood it : between two original samples, you calculate new values by performing a cubic B=E9zier interpolation using the two original samples before where your new point is and the two other after, and in order to perform the cubic B=E9zier interpolation you perform a series of linear interpolations as depicted there http://en.wikipedia.org/wiki/Image:Bezier_cubic.png Here's how I tried to implement it. The t, pX, qX and rX variables are the same as those indicated in the link posted above. s2[i] is the equivalent of B. double *cubicBspline_interpolation(double *s1, int32_t n1, int32_t factor) { int32_t i, n2; double *s2, p0, p1, p2, p3, q0, q1, q2, r0, r1, t; n2 =3D n1 * factor; //calculation of the length of the interpolated signal s2 =3D malloc (n2 * sizeof(double)); //allocation of the interpolated signal for (i=3Dfactor; i<n2-(factor*2); i++) //loop going from after the two first original samples to before the two last, i'll take care of the particular cases once the general case will work correctly { t =3D fmod((float) i/factor, 1); //calculation of our position between p1 and p2 p0 =3D s1[(i/factor)-1]; //the four p values are all samples from the original signal p1 =3D s1[i/factor]; p2 =3D s1[(i/factor)+1]; p3 =3D s1[(i/factor)+2]; q0 =3D p0 * (1-t) + p1 * t; //the three q values are linearly interpolated from the p values q1 =3D p1 * (1-t) + p2 * t; q2 =3D p2 * (1-t) + p3 * t; r0 =3D q0 * (1-t) + q1 * t; //the two r values are linearly interpolated from the q values r1 =3D q1 * (1-t) + q2 * t; s2[i] =3D r0 * (1-t) + r1 * t; //the final value is linearly interpolated from the r values } return s2; } The result you get from that is very wrong, if we can put it this way. Filling the s2 array with either q value indicates that the linear interpolation is correctly performed so far, however doing the same with either r value gives a result that just doesn't look right, but I guess it's not supposed to at this point. I looked into documentation to make sure I understood the problem correctly but couldn't figure out what's wrong, so I'd appreciate if someone could explain me what I didn't get right. Thanks in advance.
1D cubic B-spline interpolation
Started by ●October 27, 2006
