Hi, I've designed a FM demodulator with (IdQ-QdI)/(I=B2+Q=B2). My FM modulator is center on 70 MHz with 250 kHz deviation. The demodultor works fine from 10 kHz to 250 kHz (message)... but under 10 kHz I lost a lot of amplitude in my IdQ-QdI signal... Is it because i made the derivative by x[n]-x[n-1] ? Is it working better with a FIR filter with 3 taps (-1,+1,0) ? If yes what are the location of the coeffcients ? (-1,+1,0) or (+1,-1,0) or( 0,-1,+1) ?? I think with lower rate (< 10kHz) my derivative is too small in amplitude that at higer rate (> 10 kHz) ? Thanks
FM demodulation problem
Started by ●November 3, 2006
Reply by ●November 3, 20062006-11-03
I found my stupid problem !!!!!!!!!! I forgot a capacitor on my DAC ouput, so the low frequency don't pass !!!!! Now it work fine from 1 Hz to 250 kHz with no problem SORRY
patrick.melet@dmradiocom.fr wrote:> I found my stupid problem !!!!!!!!!! > > I forgot a capacitor on my DAC ouput, so the low frequency don't pass > !!!!! > > Now it work fine from 1 Hz to 250 kHz with no problem > > SORRY >Sometimes it seems that the only way to find one of these obvious answers is to expose yourself to public embarrassment by asking for help. It certainly happens to me often enough. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Posting from Google? See http://cfaj.freeshell.org/google/ "Applied Control Theory for Embedded Systems" came out in April. See details at http://www.wescottdesign.com/actfes/actfes.html
