Hello all, I have to realize a Smart Antenna system using the LMS algorithm on an uniform linear array. Let's suppose that we know already the angles of arrival of the desired signal and of one or more interferers. How can I calculate the LMS weights if I don't know how exactly is the desired signal? I can compute the weights knowing the desired signal but then it would be useless to calculate the weights and to use this method since the desired signal is what I don't know and is what I'm looking to receive and filter for (I know only the angle of arrival). Thanks.
LMS for Smart Antennas
Started by ●November 3, 2006
Reply by ●November 4, 20062006-11-04
mrlius@yahoo.it skrev:> Hello all, > I have to realize a Smart Antenna system using the LMS algorithm on an > uniform linear array. > Let's suppose that we know already the angles of arrival of the desired > signal and of one or more interferers. > How can I calculate the LMS weights if I don't know how exactly is the > desired signal?You need to find a set of weights that maximizes the sensitivity in the direction of the desired signal, and suppresses everything else. This is a standard problem in adaptive beamforming, although I don't remember the exact term for it. Rune
mrlius@yahoo.it wrote:> Hello all, > I have to realize a Smart Antenna system using the LMS algorithm on an > uniform linear array. > Let's suppose that we know already the angles of arrival of the desired > signal and of one or more interferers. > How can I calculate the LMS weights if I don't know how exactly is the > desired signal? > I can compute the weights knowing the desired signal but then it would > be useless to calculate the weights and to use this method since the > desired signal is what I don't know and is what I'm looking to receive > and filter for (I know only the angle of arrival). > Thanks.You need to design the antenna in the way to maximize the ratio of the desired signal to the interferrence. This is a typical problem of numeric optimization. You can use LMS or any other multidimensional optimization algorithm. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
<mrlius@yahoo.it> wrote in message news:1162606389.804126.168890@m7g2000cwm.googlegroups.com...> Hello all, > I have to realize a Smart Antenna system using the LMS algorithm on an > uniform linear array. > Let's suppose that we know already the angles of arrival of the desired > signal and of one or more interferers. > How can I calculate the LMS weights if I don't know how exactly is the > desired signal? > I can compute the weights knowing the desired signal but then it would > be useless to calculate the weights and to use this method since the > desired signal is what I don't know and is what I'm looking to receive > and filter for (I know only the angle of arrival). > Thanks. >You didn't say if you know the frequency or frequency range of the "desired" signal. You did say you know the angle of arrival of the desired signal. If the desired signal is at a single frequency or if the desired signal is at least such that it's more or less in some frequency band then the beamforming weights should be determinable without adaptation. If you don't know the desired signal but *do* know the undesired signal then you might implement something like an adaptive line canceller. Maybe something like this would work:? 1) Steer fixed beams of the array in the direction of the desired signals and the interferers. 2) Use the output of the beams pointed at the interferers as a reference source in an adaptive line canceller - to remove remnants of the interferers in the beams pointed toward the desired signals. To the extent that the "interference" beams pick up the desired signals, this will also attenuate the desired signals to a degree. So, it will be necessary that there be some signal-to-interference or interference-to-signal gain in both beam sets. Fred
Reply by ●November 10, 20062006-11-10
> >mrlius@yahoo.it skrev: >> Hello all, >> I have to realize a Smart Antenna system using the LMS algorithm on an >> uniform linear array. >> Let's suppose that we know already the angles of arrival of thedesired>> signal and of one or more interferers. >> How can I calculate the LMS weights if I don't know how exactly is the >> desired signal? > >You need to find a set of weights that maximizes the sensitivity in the > >direction of the desired signal, and suppresses everything else. This >is >a standard problem in adaptive beamforming, although I don't remember >the exact term for it. > >Rune > >I think its called "null-steering". You place nulls in the direction of unwanted signals, and a beam in the direction of the desired signal.
mrlius@yahoo.it wrote:> Hello all, > I have to realize a Smart Antenna system using the LMS algorithm on an > uniform linear array. > Let's suppose that we know already the angles of arrival of the desired > signal and of one or more interferers. > How can I calculate the LMS weights if I don't know how exactly is the > desired signal? > I can compute the weights knowing the desired signal but then it would > be useless to calculate the weights and to use this method since the > desired signal is what I don't know and is what I'm looking to receive > and filter for (I know only the angle of arrival). > Thanks.I suggest you look at R. T. Compton, Jr.'s book "Adaptive Antennas - Conceots and Performance". The section on page 6 is titled "The LMS Adaptive Array". In my opinion, this is one of the best books on adaptive antennas. Maurice Givens
Reply by ●November 29, 20062006-11-29
> >mrlius@yahoo.it wrote: >> Hello all, >> I have to realize a Smart Antenna system using the LMS algorithm on an >> uniform linear array. >> Let's suppose that we know already the angles of arrival of thedesired>> signal and of one or more interferers. >> How can I calculate the LMS weights if I don't know how exactly is the >> desired signal?In this state u should decide that u want to use : 1) A blind method, or 2) A training-based method>> I can compute the weights knowing the desired signal but then it would >> be useless to calculate the weights and to use this method since the >> desired signal is what I don't know and is what I'm looking to receive >> and filter for (I know only the angle of arrival).If u use the 2nd method, u should consider training sequences between ur transmited signal ( that acts as ur DESIRED in the LMS algorithm) and after adapting the weights u will detect the unknown. If u want to set the weights blindly(without transmitting any data), tell me to explain more. regards Morteza
