Is it possible to reconstruct a narrowband, time domain signal from a subset of wideband FFT output coefficients ? Maybe a simple example will help explain: Let's suppose I sampled a wideband set of signals (at different carrier frequencies) and applied a 128K-pt FFT. I know that I can get the original wideband signal back out by taking the inverse FFT, howevever, is it possible to reconstruct JUST ONE of the narrowband signals by taking an IFFT of only a few of the output coefficients (eg, a signal that spans just 16 coefficients).
FFT Narrowband Reconstruction
Started by ●November 4, 2006
Reply by ●November 4, 20062006-11-04
>Is it possible to reconstruct a narrowband, time domain signal from a >subset of wideband FFT output coefficients ? > >Maybe a simple example will help explain: >Let's suppose I sampled a wideband set of signals (at different carrier >frequencies) and applied a 128K-pt FFT. I know that I can get the >original wideband signal back out by taking the inverse FFT, howevever, >is it possible to reconstruct JUST ONE of the narrowband signals by >taking an IFFT of only a few of the output coefficients (eg, a signal >that spans just 16 coefficients). >By just keeping the spectral complex pairs that comprise your narrowband signals, and setting all other pairs to zero, then performing the 128k IFFT, this should give you what you want. Jeff
Jeff Caunter wrote:> >Is it possible to reconstruct a narrowband, time domain signal from a > >subset of wideband FFT output coefficients ? > > > >Maybe a simple example will help explain: > >Let's suppose I sampled a wideband set of signals (at different carrier > >frequencies) and applied a 128K-pt FFT. I know that I can get the > >original wideband signal back out by taking the inverse FFT, howevever, > >is it possible to reconstruct JUST ONE of the narrowband signals by > >taking an IFFT of only a few of the output coefficients (eg, a signal > >that spans just 16 coefficients). > > > > By just keeping the spectral complex pairs that comprise your narrowband > signals, and setting all other pairs to zero, then performing the 128k > IFFT, this should give you what you want. > > JeffAlas, I was hoping to find a way such that I didn't have to do the full 128k-pt IFFT. Perhaps only the 16-pt IFFT. Maybe with some pre-twiddling or something ???
Reply by ●November 5, 20062006-11-05
On 4 Nov 2006 16:44:43 -0800, "yazz35@gmail.com" <yazz35@gmail.com> wrote:>Alas, I was hoping to find a way such that I didn't have to do the full >128k-pt IFFT. Perhaps only the 16-pt IFFT. Maybe with some >pre-twiddling or something ???Well, it depends on what you mean by "reconstruct the narrowband signal". If you know in advance that the signal is a single sine wave, then you can reconstruct it by finding the FFT bin with the highest power, interpolating the frequency, and then synthesizing a sine wave. Unless you need to know the phase too. I'm not sure how to combine bin interpolation and phase. But if you don't interpolate, then the phase is directly readable from the sine and cosine parts of the bin with the most power. Robert Scott Ypsilanti, Michigan
yazz35@gmail.com schrieb:> Is it possible to reconstruct a narrowband, time domain signal from a > subset of wideband FFT output coefficients ?Sure. Here is the DFT/IDFT defintion: N-1 DFT{ x[n] } = X[k] = SUM{ x[n] * exp(-j*2*pi*n*k/N) } n=0 N-1 iDFT{ x[n] } = x[n] = 1/N * SUM{ X[k] * exp(+j*2*pi*n*k/N) } k=0 To resynthesize the x[n] via IDFT from just a few (or a single) of the X[k], only compute the partial sum with the relevant coefficients. Regards, Andor
