newbie: spectral analysis on a single waveform
Started by d1camero ●November 4, 2006
Hi all,   I am playing with amplifier circuits for guitar amps and
evaluating a complex signal as it proceeds through the amplifier.  I am
able to capture the signal at various points with a DSO.  Then with the
DSO software I can do an FFT to see the freq spectrum of the signal.
Here is the problem.  The input signal is complex and decays both in
amplitude and somewhat in frequency.  So I want to do FFT just on a
single waveform.  I have been trying to brush up on FFT (it has been a
long time and many beers since then), and I read that FFT is not
accurate on a single waveform.
Any suggestions?
thanks
Don
d1camero wrote:
> Hi all, I am playing with amplifier circuits for guitar amps and > evaluating a complex signal as it proceeds through the amplifier. I am > able to capture the signal at various points with a DSO. Then with the > DSO software I can do an FFT to see the freq spectrum of the signal. > > Here is the problem. The input signal is complex and decays both in > amplitude and somewhat in frequency. So I want to do FFT just on a > single waveform. I have been trying to brush up on FFT (it has been a > long time and many beers since then), and I read that FFT is not > accurate on a single waveform.
Note that in this line of work, "complex" has a mathematical meaning that doesn't make sense when applied to a signal on a single wire. (Complex = real + imaginary.) I presume that you mean "complicated". It you were faces with a single frequency, you would know what it is. A Fourier transform picks apart complicated waveforms ans shows its spectrum. If that's not what you want, what do you want? Jerry -- "The rights of the best of men are secured only as the rights of the vilest and most abhorrent are protected." - Chief Justice Charles Evans Hughes, 1927 ���������������������������������������������������������������������
Jerry Avins wrote:
> It you were faces with a single frequency, you would know what it is. A > Fourier transform picks apart complicated waveforms ans shows its > spectrum. ...
Mt thingers are too fick. That should be: "It you were faced with a single frequency, you would know what it is. A Fourier transform picks apart a complicated waveform and shows its spectrum. ... Jerry -- "The rights of the best of men are secured only as the rights of the vilest and most abhorrent are protected." - Chief Justice Charles Evans Hughes, 1927 ���������������������������������������������������������������������
Hmmm...  "complex waveform" is a common term used in physics and
engineering. No imaginary numbers here...
I guess you did not understand my question, let me try again:  I have a
complex waveform I would like to apply FFT to get a spectral analysis.
I have read in a Agilent article that FFT does not work propely against
one cycle of a waveform, that it requires multiple cycles.  Is this
true?  If it is, any suggestions on how I can determine the spectral
analysis of a complex waveform that only has a single cycle?
"d1camero" <a8723@cameronsoftware.com> wrote in message
news:1162709038.334856.35720@f16g2000cwb.googlegroups.com...
> Hmmm... "complex waveform" is a common term used in physics and > engineering. No imaginary numbers here... > > I guess you did not understand my question, let me try again: I have a > complex waveform I would like to apply FFT to get a spectral analysis. > I have read in a Agilent article that FFT does not work propely against > one cycle of a waveform, that it requires multiple cycles. Is this > true? If it is, any suggestions on how I can determine the spectral > analysis of a complex waveform that only has a single cycle? >
You can average the FFT and overlap it. Something like S(i) = beta*S(i-1)+X(i)X*(i)*(1-beta) where beta is a forgetting factor and S is the Spectrum,X is the freq vector at index i. Let beta =0.98 or experiment with it. make it smaller for tracking purposes. Here X* mean complex conjugate. M. -- Posted via a free Usenet account from http://www.teranews.com
What do you mean by a single waveform? Do you mean that you want to capture the same time sequence at successive points in your amplifier, and then do an FFT on each capture? You could do that if you could store it in an arbitrary waveform generator and make it repeat, or just record it on a PC and use wave edit software to make it loop. If you're just looking for frequency response information, you could get it by putting white noise into the input and then doing an FFT on the noise at various points in the amplifier. If you're looking for spectrum evidence of distortion, you could get that by a repeating loop of signals strong enough to cause the distortion. What information do you expect to get from the FFTs? -- John
d1camero wrote:
> Hi all, I am playing with amplifier circuits for guitar amps and > evaluating a complex signal as it proceeds through the amplifier. I am > able to capture the signal at various points with a DSO. Then with the > DSO software I can do an FFT to see the freq spectrum of the signal. > > Here is the problem. The input signal is complex and decays both in > amplitude and somewhat in frequency. So I want to do FFT just on a > single waveform. I have been trying to brush up on FFT (it has been a > long time and many beers since then), and I read that FFT is not > accurate on a single waveform. > > Any suggestions? > > thanks > Don >
Suggestions? Yes :) You may be asking "wrong" question ;) [I've cheated by waiting for Jerry & "Major Misunderstanding" to reply] I suspect you want to look at *HOW* signal decays in time *&* frequency Try a SEQUENCE of FFT's If decay time constant is 1 second, look at 200 msec of data at 100 msec intervals Plot in pseudo 3-D (waterfall) Not sure how useful result will be. Should give hints about further questions to ask. YM*M*V Just remember -- advice may be worth what you paid
The problem with the FFT is that the first bin will be the fundamental (single cycle) and the next bin will be 2x that (2 cycles). If you only have one cycle your resolution is terrible. Try using the Chirp-Z transform, which will allow you to examine a narrow freq band. Tom
I'm not sure what you mean by a single cycle. The fundamental frequency of a repeating waveform is the reciprocal of the repetition rate; all other frequencies are multiples (harmonics) of that. The Fourier transform of one cycle of that needs no window and gives the same result as 2, 3, ..., n cycles of the same waveform. Signals that decay are not in general repetitive. Jerry -- "The rights of the best of men are secured only as the rights of the vilest and most abhorrent are protected." - Chief Justice Charles Evans Hughes, 1927 &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
Thanks all for the feedback.  Some of this will help.
Jerry,  I am not sure why you are confused, but no matter, as others
have helped out.
Don
