Hi, I've designed a complete FM demodulator under Simulink, but I've got a problem. My FM IF is 70 MHz, 250 kHz deviation, 250 kHz message, so my bandpass signal is 1 MHz large (Carson BW =3D 2* (Delta F + Fmax message) =3D 1 MHz I first undersample the IF at 13.75 MHz so my FM signal is translated to 1.25 MHz, then I multiply with cosinus and sinus (1.25 MHz) to obtain I and Q signal which have 500 kHz bandwith, then I need to low pass filter at 500 kHz and it's here my problem... If I low pass filter at 500 kHz I've got an ondulation on I=B2+Q=B2 then if I filter at 2 MHz this ondulation is very low compared to a filter at 500 kHz ? So at what frequency do I need to filter after the downconversion ? 500 kHz or up ? Thanks...
FM demodulation problem
Started by ●November 6, 2006
Reply by ●November 6, 20062006-11-06
patrick.melet@dmradiocom.fr wrote:> Hi, > > I've designed a complete FM demodulator under Simulink, but I've got a > problem.Hi Patrick, I have written 2 private messages to you. I hope you will remember me. I have 4 FM demodulator designed in simulink, and related documentation.> > My FM IF is 70 MHz, 250 kHz deviation, 250 kHz message, so my bandpass > signal is 1 MHz large (Carson BW =3D 2* (Delta F + Fmax message) =3D 1 MHz > > I first undersample the IF at 13.75 MHz so my FM signal is translated > to 1.25 MHz,......=2E.........................Would you like explain how your FM signal is translated to 1.25 Mhz? then I multiply with cosinus and sinus (1.25 MHz) to> obtain I and Q signal which have 500 kHz bandwith, then I need to low > pass filter at 500 kHz and it's here my problem... > If I low pass filter at 500 kHz I've got an ondulation on I=B2+Q=B2 then > if I filter at 2 MHz this ondulation is very low compared to a filter > at 500 kHz ? > > So at what frequency do I need to filter after the downconversion ? 500 > kHz or up ?As I mentioned in private messege, when I try to modify FM demodulator designed for 10.7 MHz IF, I have same problem. I recommend you to record your undersampled data to Matlab workspace by using <To workspace> block of Simulink. So you can look at its spectrum by using FFT . The first biggest harmonic in symmetrical FM signal gives you low pass filter cut-off frequency.>=20 > Thanks...
