distributed arithmetic symmetry?
Started by dtsao November 14, 2006
Ok,
I think I understand now. My misunderstanding before was I thought the
summing was done AFTER the input went through the
parrallel-shift-register. But I guess you are saying the inputs are summed
together first, THEN that sum is serially sent into the LUT. Thanks a lot!
dtsao wrote:
> Ok, > > I think I understand now. My misunderstanding before was I thought the > summing was done AFTER the input went through the > parrallel-shift-register. But I guess you are saying the inputs are summed > together first, THEN that sum is serially sent into the LUT. Thanks a lot! >
Yup, The pre-adders and the LUT inputs are serial. The output of the LUTs are a sum of 1xN partial products, which are then shifted and summed in a scaling accumulator over the N clock cycles to arrive at the full sum of MxN products.
Yup, The pre-adders and the LUT inputs are serial. The output of the LUTs are a sum of 1xN partial products, which are then shifted and summed in a scaling accumulator over the N clock cycles to arrive at the full sum of MxN products. Oh, and I should add that I have a page on my website explaining distributed arithmetic. It doesn't go into the symmetry however, but it does go over the basics. http://www.andraka.com/distribu.htm
