Frequency Filtering Algorithm
Started by pawan jadia June 9, 2004
Hello,
The requirements of a system to be designed are:
Transmitting frequency : 50 KHz
Received Echo Frequency to be detected : 45-55 KHz
Frequency Resolution : 90 hz
Sampling Rate : 250 KHz
We are transmitting 16 bursts of 50 KHz.
So the total time period of transmission will be only 320micro
seconds.
Therefore within the same time duration we have to collect the samples
and detect the frequency of echo. The measurement duration is around
3ms.
Could anybody suggest frequency filtering algorithm for this.
My first intuition says that solution lies in 'multirate digital
signal processing'. But you are also welcomed to give suggestion
independent of my intuition.
Thanks and Regards,
Pawan Jadia.
pawan_jadia@yahoo.com (pawan jadia) wrote in message news:<698534c.0406082221.3a67fd47@posting.google.com>...
> Hello, > The requirements of a system to be designed are: > > Transmitting frequency : 50 KHz > Received Echo Frequency to be detected : 45-55 KHz > Frequency Resolution : 90 hz > Sampling Rate : 250 KHz > > We are transmitting 16 bursts of 50 KHz. > So the total time period of transmission will be only 320micro > seconds. > Therefore within the same time duration we have to collect the samples > and detect the frequency of echo. The measurement duration is around > 3ms. > > Could anybody suggest frequency filtering algorithm for this. > > My first intuition says that solution lies in 'multirate digital > signal processing'. But you are also welcomed to give suggestion > independent of my intuition. > > Thanks and Regards, > Pawan Jadia.
Pawan, As an example, if you use selective-sampling you would synthesize 111 waveforms ( 10Khz/90 Hz) starting from 45 Khz and ending at 55 Khz in 90 Hz increments (45000, 45090, 45180, etc.) for a period each of twice the lowest frequency (45 KHz). The A/D would oversample by perhaps 6x55 KHz = 330 KHz (to get enough data points for resolution of formulas - see http://www.signaldisplay.com/sampling.html) and the total time to collect samples would be 2*111/45000 Hz = 4.9 msec. The processor would then solve for magnitude components to locate the peak frequency in the 45K - 55K band. With this you don't have to bandpass or downsample (the bandpass will also introduce a delay). Best regards, Mike
"pawan jadia" <pawan_jadia@yahoo.com> wrote in message
news:698534c.0406082221.3a67fd47@posting.google.com...
Pawan, No algorithm will make up for inadequate physics. I interpret your description as follows: You are transmitting 16 *cycles* of 50kHz for a total pulse length of 320usec. A pulse of this length will yield a frequency resolution of 1/0.000032 = 3,125Hz. This is not nearly the 90Hz you desire. To get 90 Hz resolution, you need a pulse length of around 1/90 = 11msec. Multirate really has nothing to do with it. Fred
mharney@signaldisplay.com (Michael Harney) wrote in message news:<ce8a7803.0406091715.55877670@posting.google.com>...
> pawan_jadia@yahoo.com (pawan jadia) wrote in message news:<698534c.0406082221.3a67fd47@posting.google.com>... > > Hello, > > The requirements of a system to be designed are: > > > > Transmitting frequency : 50 KHz > > Received Echo Frequency to be detected : 45-55 KHz > > Frequency Resolution : 90 hz > > Sampling Rate : 250 KHz > > > > We are transmitting 16 bursts of 50 KHz. > > So the total time period of transmission will be only 320micro > > seconds. > > Therefore within the same time duration we have to collect the samples > > and detect the frequency of echo. The measurement duration is around > > 3ms. > > > > Could anybody suggest frequency filtering algorithm for this. > > > > My first intuition says that solution lies in 'multirate digital > > signal processing'. But you are also welcomed to give suggestion > > independent of my intuition. > > > > Thanks and Regards, > > Pawan Jadia. > > Pawan, > > As an example, if you use selective-sampling you would synthesize 111 > waveforms ( 10Khz/90 Hz) starting from 45 Khz and ending at 55 Khz in > 90 Hz increments (45000, 45090, 45180, etc.) for a period each of > twice the lowest frequency (45 KHz). The A/D would oversample by > perhaps 6x55 KHz = 330 KHz (to get enough data points for resolution > of formulas - see http://www.signaldisplay.com/sampling.html) and the > total time to collect samples would be 2*111/45000 Hz = 4.9 msec. The > processor would then solve for magnitude components to locate the peak > frequency in the 45K - 55K band. With this you don't have to bandpass > or downsample (the bandpass will also introduce a delay). > > Best regards, > > Mike
----> Thanks Mike, I think this is what I wanted. Thanks a lot. But total time to collect the sample will be 111/45000 = 2.5 ms as described in the paper. am I right? and secondly bandpass filter is a part of the block diagram that you suggested. I am trying to understand the paper fully. I will get back to you very soon. Thanks and Regards, pawan jadia.
pawan_jadia@yahoo.com (pawan jadia) wrote in message news:<698534c.0406100137.2a94562c@posting.google.com>...
> mharney@signaldisplay.com (Michael Harney) wrote in message news:<ce8a7803.0406091715.55877670@posting.google.com>... > > pawan_jadia@yahoo.com (pawan jadia) wrote in message news:<698534c.0406082221.3a67fd47@posting.google.com>... > > > Hello, > > > The requirements of a system to be designed are: > > > > > > Transmitting frequency : 50 KHz > > > Received Echo Frequency to be detected : 45-55 KHz > > > Frequency Resolution : 90 hz > > > Sampling Rate : 250 KHz > > > > > > We are transmitting 16 bursts of 50 KHz. > > > So the total time period of transmission will be only 320micro > > > seconds. > > > Therefore within the same time duration we have to collect the samples > > > and detect the frequency of echo. The measurement duration is around > > > 3ms. > > > > > > Could anybody suggest frequency filtering algorithm for this. > > > > > > My first intuition says that solution lies in 'multirate digital > > > signal processing'. But you are also welcomed to give suggestion > > > independent of my intuition. > > > > > > Thanks and Regards, > > > Pawan Jadia. > > > > Pawan, > > > > As an example, if you use selective-sampling you would synthesize 111 > > waveforms ( 10Khz/90 Hz) starting from 45 Khz and ending at 55 Khz in > > 90 Hz increments (45000, 45090, 45180, etc.) for a period each of > > twice the lowest frequency (45 KHz). The A/D would oversample by > > perhaps 6x55 KHz = 330 KHz (to get enough data points for resolution > > of formulas - see http://www.signaldisplay.com/sampling.html) and the > > total time to collect samples would be 2*111/45000 Hz = 4.9 msec. The > > processor would then solve for magnitude components to locate the peak > > frequency in the 45K - 55K band. With this you don't have to bandpass > > or downsample (the bandpass will also introduce a delay). > > > > Best regards, > > > > Mike > > ----> Thanks Mike, I think this is what I wanted. Thanks a lot. But > total time to collect the sample will be 111/45000 = 2.5 ms as > described in the paper. am I right? and secondly bandpass filter is a > part of the block diagram that you suggested. I am trying to > understand the paper fully. I will get back to you very soon. > > Thanks and Regards, > pawan jadia.
Pawan, Yes - theoretically you can use only one period of each sinewave (one period is all that is required to satisfy the Fourier integral so that when you multiply two sines you get the sum and difference products). Two periods just makes it a little cleaner (one period gives you 2.5 msec and two periods each give you 5 msec). Yes you are right - the algorithm does use bandpass filtering on the front-end and there is about 100 usec delay (1/10Khz). This delay is hopefully OK but it is necessary to bandpass so the sum and difference products are limited to the low and high frequencies you are seeking components for. If you assume zero or constant phase, the matrix of equations that results for magnitude and phase (set equal to the A/D values) is easy to solve for by just inverting the matrix to find the magnitude components. Of course, the phase is usually not constant so the matrix will be quadratic equations which it is still easy to find a solution for (I have done this on MathCad and there are algorithms for solving for a system of quadratics that can be ported to code). You may need to increase the A/D sampling rate to generate more points as the more components you are solving for (in this case - 111 bins) the same number of equations you need. This is the trade off - high A/D oversampling for narrow resolution). Accurate mixers are also important - I recommend a straight multiplier like the MPY634 from Burr-Brown (now TI). I am working on developing a program that allows you to import data and it does all the math - of course it won't be in real time for most systems but it will make it easier to do data analysis after the data is captured. Let me know if you have more questions. Best regards, Mike
> > > > ----> Thanks Mike, I think this is what I wanted. Thanks a lot. But > > total time to collect the sample will be 111/45000 = 2.5 ms as > > described in the paper. am I right? and secondly bandpass filter is a > > part of the block diagram that you suggested. I am trying to > > understand the paper fully. I will get back to you very soon. > > > > Thanks and Regards, > > pawan jadia. >
"Fred Marshall" <fmarshallx@remove_the_x.acm.org> wrote in message news:<4fSdnWnhXpIre1rdRVn-jw@centurytel.net>...
> "pawan jadia" <pawan_jadia@yahoo.com> wrote in message > news:698534c.0406082221.3a67fd47@posting.google.com... > > Hello, > > The requirements of a system to be designed are: > > > > Transmitting frequency : 50 KHz > > Received Echo Frequency to be detected : 45-55 KHz > > Frequency Resolution : 90 hz > > Sampling Rate : 250 KHz > > > > We are transmitting 16 bursts of 50 KHz. > > So the total time period of transmission will be only 320micro > > seconds. > > Therefore within the same time duration we have to collect the samples > > and detect the frequency of echo. The measurement duration is around > > 3ms. > > > > Could anybody suggest frequency filtering algorithm for this. > > > > My first intuition says that solution lies in 'multirate digital > > signal processing'. But you are also welcomed to give suggestion > > independent of my intuition. > > Pawan, > > No algorithm will make up for inadequate physics. > > I interpret your description as follows: > > You are transmitting 16 *cycles* of 50kHz for a total pulse length of > 320usec. A pulse of this length will yield a frequency resolution of > 1/0.000032 = 3,125Hz. This is not nearly the 90Hz you desire. > > To get 90 Hz resolution, you need a pulse length of around 1/90 = 11msec. > > Multirate really has nothing to do with it. > > Fred
----->Fred, I am agree with you. I am new in the project so I am just getting the requirements. Actually i don't need 90 hz resolution at all. Now the problem is my transmission duration is 320 micro seconds. so receive duration will also be 320 usec. with 250 khz sample rate within this 320 usec i can collect only 80 samples. now how to detect the frequency with these 80 samples. Here the receiving frequency may change, if the object is moving, due to doppler effect. So the new problem is unknown frequency detection (estimation) of chirp signal. Thanks and regards, pawan jadia.
