Is a voltage controlled oscillator system time invariant?
Started by faust_o ●November 17, 2006
Hi,
Is the following system time invariant?
y(t)=T_VCO[x(t)]=cos[wt+a(t)]
where
a(t)=\int_{-\infty}^{t}x(tau) d tau
My answer:
No it is not because:
y1(t)=T_VCO[x(t-t1)]=cos[wt+a(t)]
where
a(t)=\int_{-\infty}^{t}x(tau-t1) d tau
Therefore
y1(t) is not equal y(t-t1)
Oliver Faust
faust_o wrote:
> Hi, > Is the following system time invariant? > y(t)=T_VCO[x(t)]=cos[wt+a(t)] > where > a(t)=\int_{-\infty}^{t}x(tau) d tau > > My answer: > No it is not because: > y1(t)=T_VCO[x(t-t1)]=cos[wt+a(t)] > where > a(t)=\int_{-\infty}^{t}x(tau-t1) d tau > Therefore > y1(t) is not equal y(t-t1)
Good question. Homework? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
> > Good question. Homework? > > Jerry
Dear Jerry, I quite agree that we should not do or even discuss the homework of students in the forum. However, this is a 'real' question which came up after we discussed the PLL system. I just want to make sure that my answer is correct. Sincerely, Oliver Faust
faust_o wrote:
>> Good question. Homework? >> >> Jerry > > Dear Jerry, > I quite agree that we should not do or even discuss the homework of > students in the forum. However, this is a 'real' question which came up > after we discussed the PLL system. I just want to make sure that my > answer is correct.
Faust, We discuss homework, even giving hints; we just don't give blind answers. Your answer seems reasonable to me, but I won't say so definitely. I've too often been wrong about such distinctions. Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
faust_o wrote:
> Hi, > Is the following system time invariant? > y(t)=T_VCO[x(t)]=cos[wt+a(t)] > where > a(t)=\int_{-\infty}^{t}x(tau) d tau > > My answer: > No it is not because: > y1(t)=T_VCO[x(t-t1)]=cos[wt+a(t)] > where > a(t)=\int_{-\infty}^{t}x(tau-t1) d tau > Therefore > y1(t) is not equal y(t-t1) > > > Oliver Faust >
By your reasoning it is, indeed, time varying. Furthermore it should be pretty easy to show that y(t) = T_VCO[x(t)] is also not linear. Given any real system (not a mathematical model), you should never have to ask "Is this system a linear time invariant system". Why? Because all real systems are nonlinear and time varying (see the "Nonlinear Systems" chapter of my book for the rational). So if you're presented with a system that you want to analyze, such as a VCO, you shouldn't ask the above question. What you _can_ and _should_ ask, however, is "how can I pretend that this system is linear and time invariant, and will the model be good enough for me to proceed". In the case of a VCO, if you can accurately measure the deviation of the phase from wt, then you will find that y(t) = phase(T_VCO[x(t)]) is pretty darn close to a linear time-invariant system. This is, in fact, exactly what you do for most PLL analysis, then you treat any artifacts of the phase measurement as noise that's magically injected into your system. From this point of view, then, you can treat the VCO as linear and time invariant enough (but never absolutely linear and time invariant). -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Posting from Google? See http://cfaj.freeshell.org/google/ "Applied Control Theory for Embedded Systems" came out in April. See details at http://www.wescottdesign.com/actfes/actfes.html
Dear Tim Wescott,
Thank you for your reply.
Thank you very much. That helped me a lot, I will update my notes.
> Given any real system (not a mathematical model), you should never have > to ask "Is this system a linear time invariant system". Why? Because > all real systems are nonlinear and time varying (see the "Nonlinear > Systems" chapter of my book for the rational).
I don't agree with your reasoning. In my opinion the only thing each of us has is a model of the world around. The model in our brain is similar to a computer model and therefore similar to a mathematical model. All models are used to make predictions about certain events around us. Say, a 'real world' signal processing system takes input and produces output. A model predicts the output from a given input. Therefore, one can judge a model based on the precision of prediction, i.e. we observe the output of the 'real system' and compare it with the predicted output from our model. To follow your reasoning, nonlinear and time-variant models are able to predict certain events with a higher precision compared with linear time-invariant models. However, I strongly disagree that 'a real system' is non-linear and time variant, because in my opinion only models can have such properties.
> So if you're presented with a system that you want to analyze, such as a > VCO, you shouldn't ask the above question. What you _can_ and _should_ > ask, however, is "how can I pretend that this system is linear and time > invariant, and will the model be good enough for me to proceed".
In general I agree with you, however I consider this as a second question. Before, I can pretend that a model (system) is linear and time invariant I need to know that it is not. In case of the PLL I need to show that a multiplication system is non-linear but time invariant and a VCO is non-linear and time variant. Only after this step, I can introduce the simplifications which lead to a linear time invariant model. Oliver Faust
faust_o wrote:
> ... In my opinion the only thing each > of us has is a model of the world around. The model in our brain is > similar to a computer model and therefore similar to a mathematical > model. All models are used to make predictions about certain events > around us. ...
I doesn't matter whether our model of a nail bends or not. The real nails that we hit with hammers tell the whole story. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
faust_o wrote:
> Dear Tim Wescott, > > Thank you for your reply. > > > >>By your reasoning it is, indeed, time varying. > > > Thank you very much. That helped me a lot, I will update my notes. > > > >>Given any real system (not a mathematical model), you should never have >>to ask "Is this system a linear time invariant system". Why? Because >>all real systems are nonlinear and time varying (see the "Nonlinear >>Systems" chapter of my book for the rational). > > > I don't agree with your reasoning. In my opinion the only thing each > of us has is a model of the world around. The model in our brain is > similar to a computer model and therefore similar to a mathematical > model. All models are used to make predictions about certain events > around us. Say, a 'real world' signal processing system takes input > and produces output. A model predicts the output from a given input. > Therefore, one can judge a model based on the precision of prediction, > i.e. we observe the output of the 'real system' and compare it with > the predicted output from our model. To follow your reasoning, > nonlinear and time-variant models are able to predict certain events > with a higher precision compared with linear time-invariant models. > However, I strongly disagree that 'a real system' is non-linear and > time variant, because in my opinion only models can have such > properties.
Then your original question is deeply flawed, and the answer to it is "a VCO can't be time invariant, only a model thereof can be". However, I say that you can choose any physical system to define as a 'system' in the mathematical sense, with any input/output pair relating to that system that you choose to choose. You will find that _in reality_, without recourse to any math higher than that necessary to measure the inputs and outputs, a great enough input will find a nonlinearity in the output. If nothing else you'll concentrate so much energy into such a small area that space will bend. For most problems, long before you see relativistic effects you'll see some measurable nonlinear effect. End of story. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Posting from Google? See http://cfaj.freeshell.org/google/ "Applied Control Theory for Embedded Systems" came out in April. See details at http://www.wescottdesign.com/actfes/actfes.html
Jerry Avins <jya@ieee.org> writes:
> faust_o wrote: > > >> ... In my opinion the only thing each >> of us has is a model of the world around. The model in our brain is >> similar to a computer model and therefore similar to a mathematical >> model. All models are used to make predictions about certain events >> around us. ... > > I doesn't matter whether our model of a nail bends or not. The real > nails that we hit with hammers tell the whole story.
I was just reading today in Popular Mechanics that a chief reason for delay of the Airbus 380 is that the software modeling the cable assemblies was faulty. It's important to get these models to match reality. -- % Randy Yates % "Though you ride on the wheels of tomorrow, %% Fuquay-Varina, NC % you still wander the fields of your %%% 919-577-9882 % sorrow." %%%% <yates@ieee.org> % '21st Century Man', *Time*, ELO http://home.earthlink.net/~yatescr
Randy Yates wrote:
> Jerry Avins <jya@ieee.org> writes: > > >>faust_o wrote: >> >> >> >>> ... In my opinion the only thing each >>>of us has is a model of the world around. The model in our brain is >>>similar to a computer model and therefore similar to a mathematical >>>model. All models are used to make predictions about certain events >>>around us. ... >> >>I doesn't matter whether our model of a nail bends or not. The real >>nails that we hit with hammers tell the whole story. > > > I was just reading today in Popular Mechanics that a chief reason > for delay of the Airbus 380 is that the software modeling the > cable assemblies was faulty. > > It's important to get these models to match reality.
They should probably avoid the Naomi Campbell style of model. :-) Steve
