Hi all, I am basically a software person, am new to this DSP hardware things. I have Innovative Integration's: Conejo Baseboard with Four Analog I/O Channels, Upto 10MHz input/50Mhz output 900 MFLOPS Floating point DSP TMS320C6711 150MHz. The Software tools provided by II include: Pismo toolset, Armada toolset and TI code composer studio. I am able to understand the code given in the examples.But my question is where should I develop/run all this stuff?. As far as I understand, I have to use the CCS and generated a .out file(called COFF file) and download this in the DSP and then write a host PC program(using Borland C++) for further processing.Am I right in my understanding?. Assuming above, I set out to write a target program using CCS. I ran the SetUp Code Composer Studio and configured as specified in the instruction manual. But when I run CCS, I get the following error: CPU_1-DSP Device Driver: "Cant initialise Target CPU Error 0x80000200/-155 Fatal Error during:OCS, This error was generated by TI's USCIF driver. SC_ERR_POD_NO_LIBRARY <-155> This utility cannot find the adaptor for a custom emulator. The adaptor was named in a board description file. I/O Port=0 Board Name:C62XX,C67xx XDS510 Emulator CPU Name:CPU_1" Can someone help?. Another question I have is, Is CCS going to act as Simulator/Emulator of the board?.If so why should it when I have the actual board connected to the PC? Thanks a lot, Dhivya
DSP newbie :struck up in CCS setup
Started by ●November 17, 2006
