Eric de Castro Lopo has a very useful page at http://mega-nerd.com/FPcast/ about fast float to integer conversion in C. However, I just realised it doesn't tell the whole story, and I'm a little puzzled. When I do what that web page says, conversions are fast inlined operations. That has been working fine for me for years. I've only just realised, however, that when I put "-std=c99" on the compiler command line, the inlined operations change to subroutine calls, and the speed nosedives. Can anyone tell me why? Steve
Started by ●November 20, 2006
Reply by ●November 20, 20062006-11-20
Hi Steve, Steve Underwood wrote:> > Eric de Castro Lopo has a very useful page atSorry, thats Erik with a 'k'.> http://mega-nerd.com/FPcast/ about fast float to integer conversion in > C. However, I just realised it doesn't tell the whole story, and I'm a > little puzzled. > > When I do what that web page says, conversions are fast inlined > operations. That has been working fine for me for years. I've only just > realised, however, that when I put "-std=c99" on the compiler command > line, the inlined operations change to subroutine calls, and the speed > nosedives. Can anyone tell me why?Hmm, thats strange. What optimisation level are you using? I'm pretty sure that -O0 removes inlinnig but inlining should still be there at -)2 and above. Another possibility to to try using -std=gnu99 instead of -std=c99. gnu99 is basically C99 with POSIX extensions. Please do report your findings. Cheers Erik (with a k, like the Viking) -- +-----------------------------------------------------------+ Erik de Castro Lopo +-----------------------------------------------------------+ Diana West for President of the United States http://www.washtimes.com/op-ed/20060817-091447-7758r.htm http://www.washtimes.com/op-ed/20060824-084015-5082r.htm
Erik de Castro Lopo <nospam@mega-nerd.com> writes:> Hi Steve, > > Steve Underwood wrote: >> >> Eric de Castro Lopo has a very useful page at > > Sorry, thats Erik with a 'k'. > > >> http://mega-nerd.com/FPcast/ about fast float to integer conversion in >> C. However, I just realised it doesn't tell the whole story, and I'm a >> little puzzled. >> >> When I do what that web page says, conversions are fast inlined >> operations. That has been working fine for me for years. I've only just >> realised, however, that when I put "-std=c99" on the compiler command >> line, the inlined operations change to subroutine calls, and the speed >> nosedives. Can anyone tell me why? > > Hmm, thats strange. What optimisation level are you using? > I'm pretty sure that -O0 removes inlinnig but inlining should > still be there at -)2 and above. > > Another possibility to to try using -std=gnu99 instead of > -std=c99. gnu99 is basically C99 with POSIX extensions. > > Please do report your findings.I'm curious how you know that enabling optimizations on a compiler with the lrint() function guarantees the functions will be inlined. Was it just by experimentation? In any case, a nice piece of work, Erik. Thanks for making this knowledge available. -- % Randy Yates % "Remember the good old 1980's, when %% Fuquay-Varina, NC % things were so uncomplicated?" %%% 919-577-9882 % 'Ticket To The Moon' %%%% <yates@ieee.org> % *Time*, Electric Light Orchestra http://home.earthlink.net/~yatescr
Erik de Castro Lopo wrote:> Hi Steve, > > Steve Underwood wrote: > >>Eric de Castro Lopo has a very useful page at > > > Sorry, thats Erik with a 'k'. > > > >>http://mega-nerd.com/FPcast/ about fast float to integer conversion in >>C. However, I just realised it doesn't tell the whole story, and I'm a >>little puzzled. >> >>When I do what that web page says, conversions are fast inlined >>operations. That has been working fine for me for years. I've only just >>realised, however, that when I put "-std=c99" on the compiler command >>line, the inlined operations change to subroutine calls, and the speed >>nosedives. Can anyone tell me why? > > > Hmm, thats strange. What optimisation level are you using? > I'm pretty sure that -O0 removes inlinnig but inlining should > still be there at -)2 and above. > > Another possibility to to try using -std=gnu99 instead of > -std=c99. gnu99 is basically C99 with POSIX extensions. > > Please do report your findings.I am using Fedora Core 4, which uses GCC 4.0.2. I tried various things, once I found the problem. The following: #define _ISOC9X_SOURCE 1 #define _ISOC99_SOURCE 1 #include <inttypes.h> #include <tgmath.h> #include <math.h> void f2i_array (float *fptr, int *buffer, int count) { while (count) { count--; buffer [count] = lrintf (fptr [count]); } } int main(int argc, char *argv[]) { return 0; } compiled with gcc -o2 -S -o test.S test.c or gcc -std=gnu99 -o2 -S -o test.S test.c the conversions are inlined. Compiled with gcc -std=c99 -o2 -S -o test.S test.c they are not, and the code looks considerable different. Regards, Steve
Reply by ●November 21, 20062006-11-21
Steve Underwood wrote:> > I am using Fedora Core 4, which uses GCC 4.0.2. I tried various things, > once I found the problem.Thanks Steve. If using -std=c99 or -std=gnu99 then I suspect that these lines are not needed:> #define _ISOC9X_SOURCE 1 > #define _ISOC99_SOURCE 1> compiled with > gcc -o2 -S -o test.S test.c > or > gcc -std=gnu99 -o2 -S -o test.S test.c > the conversions are inlined. Compiled with > gcc -std=c99 -o2 -S -o test.S test.c > they are not, and the code looks considerable different.I also suspect that once using -O2 the -S (smallest binary) won't affect the issue either way. Cheers, Erik -- +-----------------------------------------------------------+ Erik de Castro Lopo +-----------------------------------------------------------+ http://en.wikipedia.org/wiki/Why_I_Am_Not_a_Christian http://en.wikipedia.org/wiki/Why_I_Am_Not_a_Muslim http://en.wikipedia.org/wiki/Strong_atheism
Randy Yates wrote:> > I'm curious how you know that enabling optimizations on a compiler > with the lrint() function guarantees the functions will be > inlined.I read it somewhere. Sotty, I'm not sure where. This inlining actually applies to many of the maths functions. Erik -- +-----------------------------------------------------------+ Erik de Castro Lopo +-----------------------------------------------------------+ Turks embrace novelist's war on EU http://www.iht.com/articles/2005/10/12/news/novel.php
Steve Underwood wrote:> > When I do what that web page says, conversions are fast inlined > operations. That has been working fine for me for years. I've only just > realised, however, that when I put "-std=c99" on the compiler command > line, the inlined operations change to subroutine calls, and the speed > nosedives. Can anyone tell me why? > > SteveC99, as far as I remember, places stricter limits on the way the compiler is allowed to do floating point conversions. I don't have a copy of the standard nearby, but I remember some changes in that direction. Have you tried asking this question on one of the gcc mailing lists? The developers are (like comp.dsp) friendly enough if you obey the basic rules of netiquette. It is very possible that a change in the standard made the inline conversions obselete and nobody has written new ones yet.
Erik de Castro Lopo wrote:> Steve Underwood wrote: > >>I am using Fedora Core 4, which uses GCC 4.0.2. I tried various things, >>once I found the problem. > > > > Thanks Steve. If using -std=c99 or -std=gnu99 then I suspect that > these lines are not needed:They aren't needed. I put those in during some experimenting. I found the information about what gets inlined in GCC 4.0.2 now. That says lrintf will be inlined unless strict C89 is selected. That doesn't seem to be the case. -std=c99 stops it being inlined.> > >>#define _ISOC9X_SOURCE 1 >>#define _ISOC99_SOURCE 1 > > > >>compiled with >> gcc -o2 -S -o test.S test.c >>or >> gcc -std=gnu99 -O2 -S -o test.S test.c >>the conversions are inlined. Compiled with >> gcc -std=c99 -O2 -S -o test.S test.c >>they are not, and the code looks considerable different. > > > I also suspect that once using -O2 the -S (smallest binary) > won't affect the issue either way.-S means "output assembly language source code, and stop", not make the smallest binary. Steve
Steve Underwood wrote:>> I also suspect that once using -O2 the -S (smallest binary) won't >> affect the issue either way. > > -S means "output assembly language source code, and stop", not make the > smallest binary.He probably meant -s, which means "Remove all symbol table and relocation information from the executable" (if memory serves, this cut down the size of the executable to about a third of the size for one particular application I had --- not sure what would be the typical fraction for arbitrary executables). Also if memory serves, this option is referred to as "strip binary" (which is why I think that's what Erik meant in his previous post) Carlos --
Reply by ●November 22, 20062006-11-22
Carlos Moreno wrote:> > He probably meant -s, which means "Remove all symbol table andYou're assuming he (ie me) wasn't babbling :-).> Also if memory serves, this option is referred to as "strip binary" > (which is why I think that's what Erik meant in his previous post)At this time I think we need to agree that gcc has way too many options for a normal person to remember. Erik -- +-----------------------------------------------------------+ Erik de Castro Lopo +-----------------------------------------------------------+ I call C++ a curse on programmers everywhere; the language that has enabled and encouraged more stupidity and bad software design than any other programming language ever.
