Slightly O.T.: 90 degree phase shift of sinusoidal wave using analog components
Started by Unknown November 21, 2006
news:MImdndlYgs5EmPjYnZ2dnUVZ_vadnZ2d@rcn.net...
> Randy Yates wrote: > > Jerry Avins <jya@ieee.org> writes: > > > >> Randy Yates wrote: > >> > >> ... > >> > >>> If you're talking about a multiplier circuit in the phase detector, I > >>> agree. Since the filtered output of the multiplier with cos(wc*t+p1) > >>> and cos(wc*t+p2) as inputs is cos(p1-p2), and the loop drives this > >>> error to zero, and cos(x) = 0 when p1-p2 = 90, the resulting output is > >>> in phase quadrature. > >>> Thanks for bringing this up - I never thought about it. As you said, > >>> I would've thought a typical PLL locks direct, not in quadrature. > >> Think of the XOR or balanced modulator as a multiplier. If the > >> harmonics of a square wave don't hurt (in a PLL they actually increase > >> the gain by 4/pi) just multiplying the sine bits is enough. XORing the > >> analog signals does that. > > > > How in the HECK would you "XOR" analog signals? You don't seriously mean > > inputting analog signals into a digital device? > > Why not? With CMOS, make amplifiers out of inverters with resistive > feedback from output to input and a resistor and capacitor in the input, > and run the clipped signal into a gate. Inside, all circuits (except > maybe magnetic cores) are analog. >
AMEN to that ! M. -- Posted via a free Usenet account from http://www.teranews.com
Jerry Avins wrote:
> Why not? With CMOS, make amplifiers out of inverters with resistive > feedback from output to input and a resistor and capacitor in the input, > and run the clipped signal into a gate. Inside, all circuits (except > maybe magnetic cores) are analog. > > > +----\/\/\/\----+ > | | > | |\ | Gain ~= 23 dB > __| |_/\/\/\___|______| \______|___ > | | | / > |/ >
It works, it's a fact. You can demonstrate it however I would strongly not recommend using the tricks like that in the production.Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com The operation strongly depends on the series and on the particular part. The questient current will be high and it will eventually damage the CMOS gate. Many gates have a hysteresis at the input, so this thing will oscillate.
> Without too much fuss, this works with TTL, too, but you need to watch > the dissipation.
It may work with the classic 74LS and CD40xx, however the results with the other series are unpredictable. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Thanks a lot,
I think this may do, I just have to check the price here in South
Africa.
Kind Regards,
Jaco
Randy Yates wrote:
> Jaco, > > Why not just use something like the TRF 3701? > > http://focus.ti.com/paramsearch/docs/parametricsearch.tsp?family=analog&familyId=632&uiTemplateId=NODE_STRY_PGE_T&paramCriteria=no > -- > % Randy Yates % "She's sweet on Wagner-I think she'd die for Beethoven. > %% Fuquay-Varina, NC % She love the way Puccini lays down a tune, and > %%% 919-577-9882 % Verdi's always creepin' from her room." > %%%% <yates@ieee.org> % "Rockaria", *A New World Record*, ELO > http://home.earthlink.net/~yatescr
Hi,
I think you need the LO signal and the 90 degree shifted LO to multiply
with in QPSK.  But, I might have it wrong....
Kind Regards,
Jaco
Jerry Avins wrote:
> jaco.versfeld@gmail.com wrote: > > Hi, > > > > I apologise if this is not strictly DSP related, but it is still signal > > processing related. > > > > Basically my question is how one can get a 90 degree phase shifted > > version of a sinusoidal wave using analog components. The only > > challenge is that the frequency will not be fixed. > > The legalistic answer is "no", but it can be done well enough. There are > circuits that accept an audio input and produce a pair of outputs that > are nearly 90 degrees apart from one another. Such circuits become very > difficult to trim if the bandwidth much exceeds a decade or if > quadrature must be maintained to better than a few tenth of a degree. > The phase response of either output relative to the input is well > defined, but not very interesting. The one I built used six op-amps. > > > For a fixed frequency, one could use an all-pass filter. (Are there > > any other solutions for a fixed frequency.) > > > > Basically, I am trying to build a QPSK modulator, and would like to > > implement frequency hopping as well. > > > > Is there a way that this could be done digitally at say 433 MHz? > > > > Any thoughts, suggestions and/or pointers to literature would be > > greatly appreciated. > > What signal do you need to shift? The RF oscillator can have a pair of > quadrature outputs at all frequencies. > > Jerry > -- > Engineering is the art of making what you want from things you can get. > =AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=
=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF= =AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF
Hi,
I think the 433MHz band is an unlicensed band, or at least here in
South Africa...
Kind Regards,
Jaco
Vladimir Vassilevsky wrote:
> jaco.versfeld@gmail.com wrote: > > > Basically my question is how one can get a 90 degree phase shifted > > version of a sinusoidal wave using analog components. The only > > challenge is that the frequency will not be fixed. > > This is indeed possible. However it all depends on how accurate should > be the phase shift over the bandwidth of interest. > > > > > For a fixed frequency, one could use an all-pass filter. (Are there > > any other solutions for a fixed frequency.) > > There are many possible solutions depending on the application. Perhaps, > the simplest is to make a Chebyshev approximation of the desired phase > shift using a bunch of allpass filters. > > > > > > Basically, I am trying to build a QPSK modulator, and would like to > > implement frequency hopping as well. > > I see. Basically, you want to suppress the unwanted sideband. > > > > > Is there a way that this could be done digitally at say 433 MHz? > > It is possible, however why would you need to do it at 433 MHz? > > > Vladimir Vassilevsky > > DSP and Mixed Signal Design Consultant > > http://www.abvolt.com
Thanks a lot for the answers.  I certainly learned a lot.
I hope that one day I can also be as knowledgable...
Kind Regards,
Jaco
jaco.versfeld@gmail.com writes:
> Thanks a lot for the answers. I certainly learned a lot. > > I hope that one day I can also be as knowledgable...
Hi Jaco, I have observed your postings to this group for a few years and from my perspective you appear to be one of the most knowledgable and polite people here. You are definitely an asset to this group, and I would love to meet you in person some day. Good luck in your work and studies! -- % Randy Yates % "And all that I can do %% Fuquay-Varina, NC % is say I'm sorry, %%% 919-577-9882 % that's the way it goes..." %%%% <yates@ieee.org> % Getting To The Point', *Balance of Power*, ELO http://home.earthlink.net/~yatescr
> > > Jerry Avins wrote: > >> Why not? With CMOS, make amplifiers out of inverters with resistive >> feedback from output to input and a resistor and capacitor in the >> input, and run the clipped signal into a gate. Inside, all circuits >> (except maybe magnetic cores) are analog. >> >> >> +----\/\/\/\----+ >> | | >> | |\ | Gain ~= 23 dB >> __| |_/\/\/\___|______| \______|___ >> | | | / >> |/ >> > > > It works, it's a fact. You can demonstrate it however I would strongly > not recommend using the tricks like that in the production.Vladimir > Vassilevsky > > DSP and Mixed Signal Design Consultant > > http://www.abvolt.com The operation strongly depends on the series and > on the particular part. The questient current will be high and it will > eventually damage the CMOS gate. Many gates have a hysteresis at the > input, so this thing will oscillate.
You would not want to use B (buffered output) series CMOS. The A series withstands continuous shorts to ground or +5. They get warm, but survive, at +12.
>> Without too much fuss, this works with TTL, too, but you need to watch >> the dissipation. > > It may work with the classic 74LS and CD40xx, however the results with > the other series are unpredictable.
So don't use other series. As with all other crafts, understanding how the materials work helps engineers immensely. Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
