Hi guys, I need to fing plots (or equations) for the theoretical BER for some error correction codes: Reed-Solomon, Turbo Codes, Viterbi, CRC-8. Could someone please point me out where can I find this. Michael B.
Theoretical BER
Started by ●November 21, 2006
Reply by ●November 25, 20062006-11-25
Hi, Exact theoretical expression for error correction codes is not possible. Because for that you need to know the weight specturm of the code. It is still an active research topic. One way you can solve that problem is giving union bound (upper, sometimes lower). HTH, -SaiRamesh. Michael B. wrote:> Hi guys, > > I need to fing plots (or equations) for the theoretical BER for some error > correction codes: Reed-Solomon, Turbo Codes, Viterbi, CRC-8. > > Could someone please point me out where can I find this. > > Michael B.
Michael B. wrote:> Hi guys, > > I need to fing plots (or equations) for the theoretical BER for some error > correction codes: Reed-Solomon, Turbo Codes, Viterbi, CRC-8. > > Could someone please point me out where can I find this. > > Michael B.If you have Matlab Comms Toolbox, check out the 'bertool' utility which has some of this. There is a good set of plots in a book that I can't remember the title of (it's at work now). The book is white with a colorful pyramid on the cover, and one of the authors is either W. Lindsey or M. Simon. John
