Hello, I found that it is believed that if we have an FM modulation then we can demodulate it by calculating (Q/I)' But why? How (sin/cos)' relates to frequency ? Regards
why is it working!
Started by ●November 23, 2006
Reply by ●November 23, 20062006-11-23
ma wrote:> Hello, > I found that it is believed that if we have an FM modulation then we can > demodulate it by calculating (Q/I)' But why? How (sin/cos)' relates to > frequency ? > > RegardsIt's actually d/dt {atan(Q/I)} ie the rate of change of phase which is being calculated. Naebad
ma:> I found that it is believed that if we have an FM modulation then we can > demodulate it by calculating (Q/I)' But why? How (sin/cos)' relates to > frequency ?You need (arctan(Q/I))' to demodulate FM signals. Since (arctan(x))' = 1/(1+x^2) you get: (arctan(Q/I))' = 1/(1+(Q/I)^2) * (Q/I)' If you can make sure that Q/I < 0.1 then 1/(1+(Q/I)^2) < 0.990. So replacing (arctan(Q/I))' with (Q/I)' causes an error of <1%. And that's no big deal.
ma:> I found that it is believed that if we have an FM modulation then we can > demodulate it by calculating (Q/I)' But why? How (sin/cos)' relates to > frequency ?You need (arctan(Q/I))' to demodulate FM signals. Since (arctan(x))' = 1/(1+x^2) you get: (arctan(Q/I))' = 1/(1+(Q/I)^2) * (Q/I)' If you can make sure that Q/I < 0.1 then 1/(1+(Q/I)^2) > 0.990. So replacing (arctan(Q/I))' with (Q/I)' causes an error of <1%. And that's no big deal.
Reply by ●November 24, 20062006-11-24
"Mirko Liss" <mirko.liss@web.de> wrote in message news:20061124012401.354.4.NOFFLE@mliss.myfqdn.de...> ma: >> I found that it is believed that if we have an FM modulation then we can >> demodulate it by calculating (Q/I)' But why? How (sin/cos)' relates to >> frequency ? > > You need (arctan(Q/I))' to demodulate FM signals. > > Since (arctan(x))' = 1/(1+x^2) > you get: > (arctan(Q/I))' = 1/(1+(Q/I)^2) * (Q/I)' > > > If you can make sure that Q/I < 0.1 then 1/(1+(Q/I)^2) > 0.990. > > So replacing (arctan(Q/I))' with (Q/I)' causes an error of <1%. > And that's no big deal.When can I asssume that Q/I are small? It is not small if there is a carrier frequncy and it is not small if I bring the signal to base band or anywhere in between. Regards
ma wrote:> > When can I asssume that Q/I are small?it's not the smallness of Q/I that you need to worry about but the smallness in the rate of change of omega[n] = arg{ I[n] + j*Q[n] } - arg{ I[n-1] + j*Q[n-1] } that needs to be small. if |omega[n] - omega[n-1]| is less than pi/2, you can use a trig identity: arctan(y) - arctan(x) = arctan( (y-x)/(1 + y*x) ) as long as |arctan(y) - arctan(x)| <= pi/2 and get: omega[n] = arctan( Q[n]/I[n] ) - arctan( Q[n-1]/I[n-1] ) omega[n] = arctan( (Q[n]*I[n-1] - I[n]*Q[n-1]) / (I[n]*I[n-1] + Q[n]*Q[n-1]) ) that's how to do FM demod (or group delay if n is frequency, not time) without having to worry about quadrants and discontinuities and such. r b-j> It is not small if there is a carrier > frequncy and it is not small if I bring the signal to base band or anywhere > in between. > > Regards
