Hi, I have just started off with Kalman implementation. My aim is to estimate state vectors from the obseravtions (Z). I have doubt regarding estimation of process noise variance matrix, Quoting the state update eqtn Xhat = XPred + K_G ( Z - H * Xpred ) Where K_G is the Kalman Gain This eq follows the input model : X_n = Phi * X_n-1 + W_n 1) Am I right stating, the co-variance matrix Q = E[ W_n * W_n Trnspose] should follow the last term (P) of the prediction eq if my guess of Q was right. (i.e) P =E[ ( K_G ( Z - H * Xpred ) ) * (K_G ( Z - H * Xpred )Trnspose )] 2) If tht is true, can I update my Q value as a function of P. 3) Can I use the same tactic to update my measurement noise variance matrix from the estimate of ( Z - H * Xpred) value.
Kalman
Started by ●November 24, 2006
Reply by ●November 24, 20062006-11-24
"hurry" <hurrynarain@gmail.com> wrote in message news:1164370322.076073.36470@f16g2000cwb.googlegroups.com...> Hi, > > I have just started off with Kalman implementation. My aim is to > estimate state vectors from the obseravtions (Z). > > I have doubt regarding estimation of process noise variance matrix, > Quoting the state update eqtn > > Xhat = XPred + K_G ( Z - H * Xpred ) > > Where K_G is the Kalman Gain > > This eq follows the input model : > > X_n = Phi * X_n-1 + W_n > > 1) Am I right stating, the co-variance matrix Q = E[ W_n * W_n > Trnspose] should follow the last term (P) of the prediction eq if my > guess of Q was right. (i.e) > > P =E[ ( K_G ( Z - H * Xpred ) ) * (K_G ( Z - H * Xpred > )Trnspose )] > > > 2) If tht is true, can I update my Q value as a function of P. > > 3) Can I use the same tactic to update my measurement noise variance > matrix from the estimate of > > ( Z - H * Xpred) value. >You normally need to know what Q and R are apriori or make a good guess. Tam -- Posted via a free Usenet account from http://www.teranews.com
Reply by ●November 27, 20062006-11-27
If instead of Q if we misjudge it as Q1 then is there suggestion for that. What I expected was, if this were true.> > 1) Am I right stating, the co-variance matrix Q = E[ W_n * W_n > > Trnspose] should follow the last term (P) of the prediction eq (i.e) > > > > P =E[ ( K_G ( Z - H * Xpred ) ) * (K_G ( Z - H * Xpred > > )Trnspose )] > > if my guess of Q was right.then I can re-estimate the Q value. Please suggest if the theory is inconsistent. bye, Hurry. Heid the baw - goal!! wrote:> "hurry" <hurrynarain@gmail.com> wrote in message > news:1164370322.076073.36470@f16g2000cwb.googlegroups.com... > > Hi, > > > > I have just started off with Kalman implementation. My aim is to > > estimate state vectors from the obseravtions (Z). > > > > I have doubt regarding estimation of process noise variance matrix, > > Quoting the state update eqtn > > > > Xhat = XPred + K_G ( Z - H * Xpred ) > > > > Where K_G is the Kalman Gain > > > > This eq follows the input model : > > > > X_n = Phi * X_n-1 + W_n > > > > 1) Am I right stating, the co-variance matrix Q = E[ W_n * W_n > > Trnspose] should follow the last term (P) of the prediction eq if my > > guess of Q was right. (i.e) > > > > P =E[ ( K_G ( Z - H * Xpred ) ) * (K_G ( Z - H * Xpred > > )Trnspose )] > > > > > > 2) If tht is true, can I update my Q value as a function of P. > > > > 3) Can I use the same tactic to update my measurement noise variance > > matrix from the estimate of > > > > ( Z - H * Xpred) value. > > > > You normally need to know what Q and R are apriori or make a good guess. > > Tam > > > > -- > Posted via a free Usenet account from http://www.teranews.com
