this fft code doesn't make sense
Started by BillJosephson November 26, 2006
BillJosephson skrev:
> Rune Allnor wrote: > > BillJosephson skrev: > > > % What do I fail to understand, when I expect this code to produce two > > > % waveforms of the same frequency, and identical fft peaks? > > .... > > > % but the second one shows the peak at 121 Hz (which is 120). > > > > No, it doesn't. The peak shows up in bin 121 which still is at 12 Hz. > > Look at the exponential term in your DFT. There you will find > > > > 2*pi*k*n/N > > > > These factors seem thrown together at random, but they are not: > > > > - The 2*pi factor is there because the DFT is defined in terms of > > angular > > frequencies. The n is a running index over samples in the input data > > sequence. > > - The N is the number of samples in the input data sequence. > > - The k is the bin index, and the factor you have trouble with > > understanding. > > > > To see how the k fits in the big bicture, we need first to draw the > > big picture. > > > > The DFT takes a signal that consist of N samples that are > > regularly sampled in time as input, and transform them to > > a signal that is regularly sampled in frequency. In time domain > > we have the sampling interval T, and the signal lasts for > > (N-1)T seconds. The signal duration changes as N changes. > > > > In frequency domain, we have the sampling frequency Fs = 1/T > > and the bin width dF = Fs/N. The spectrum is (N-1)*dF wide, > > or (N-1)/N*Fs. > > > > Here is the key point: The sampling frequency is fixed when > > N changes. The bin width dF changes when N changes. > > > > The question now is: At what frequency does coefficient X_k > > fall, given N and T? > > > > The k'th frequency occur at F_k = k*dF = k*Fs/N =k/(N*T). > > > > Looking at that expression, one might ask why the T factor > > is important or even necessary; and the answer is that it is > > neither.
******************************************************************** Forget about this for now! One can get rid of it by normalizing the frequency
> > scale with respect to the sampling frequency: > > > > f_k = F_k/Fs = (k/N*T)/(1/T) = k/N > > > > And now we recognize the exonential term in the DFT: > > > > 2*pi*n*F_k -> 2*pi*n*k/N > > > > when the T factors are "distilled" away.
> > To find out in what bin a certain frequency falls, you need > > to reverse this whole excercise: > > > > Given N and T, in what bin (indexed by k) contains the > > frequency f? > > > > First, find Fs and dF: > > > > Fs = 1/T > > dF = 1/(NT) > > > > Next, k is found by comparing ratios: > > > > f/Fs = k*dF/Fs > > f*T = (k/N*T)/(1/T) > > f*T = kT/NT > > f*T = k/N > > > > which, at last, gives > > > > k = f*T*N > > ======= > > > > and that's it. Just remember that k has to be an integer > > while the ratio f*T needs not be an integer. > > > > Rune > > > Rune, > > If you knew how much this message is helping me you'd know how much I > appreciate your most kind help. I've been struggling with this off and > on for the last year, and gotten help here and there, but this is the > first message that is clear and complete enough that I think I have a > chance of thorougly "getting it." Actually, I'm still working my way > through it and implementing a function as I go. I may come back with a > question, but at the moment am feeling like for once I have all the > parts together with the plan all at the same time. > > Many, many thanks.
Y're welcome. Seems like you would benefit from reading Rick Lyons' "Undertsanding Digital Signal Processing", Prentice Hall, 2004. After I posted yesterday I realized that one section does not fit in the overall post. I have outlined it above. The T factor needst to be preserved in the DFT all the way through, it can not be "distilled away" by mere arithmetics. The FFT is, however, a generic maths tool that is used in many applications where similar factors need not appear. Besides, leaving the T factor out also saves some precious FLOPs in computation-expensive applications. So by convention, everybody knows that the T factor ought to be present in the exponential term. I'm sorry for confusing you, but these conventions are second nature to me. I very seldom thing through the details about how things work. Rune
