Subject states the question. Any information is appreciated. -- % Randy Yates % "And all that I can do %% Fuquay-Varina, NC % is say I'm sorry, %%% 919-577-9882 % that's the way it goes..." %%%% <yates@ieee.org> % Getting To The Point', *Balance of Power*, ELO http://home.earthlink.net/~yatescr
Has The peak-to-average ratio problem of OFDM been solved?
Started by ●December 1, 2006
Reply by ●December 1, 20062006-12-01
Randy Yates wrote:> Subject states the question. Any information is appreciated. > -- > % Randy Yates % "And all that I can do > %% Fuquay-Varina, NC % is say I'm sorry, > %%% 919-577-9882 % that's the way it goes..." > %%%% <yates@ieee.org> % Getting To The Point', *Balance of Power*, ELO > http://home.earthlink.net/~yatescrRandy, It depends on what you mean by solved. If you mean that the PAR can be reduced to 0 dB or even 3 dB then no, it hasn't been solved. If you can live with 6 dB then I'd say yes. There are a bunch of papers on this, but IMO the foremost authority is a guy named Jose Tellado, formerly of Stanford. He has written a book on PAR reduction, which is hard to find and expensive but worth it. The technique that Tellado advocates is called Tone Reservation. John
sampson164@gmail.com writes:> Randy Yates wrote: >> Subject states the question. Any information is appreciated. >> -- >> % Randy Yates % "And all that I can do >> %% Fuquay-Varina, NC % is say I'm sorry, >> %%% 919-577-9882 % that's the way it goes..." >> %%%% <yates@ieee.org> % Getting To The Point', *Balance of Power*, ELO >> http://home.earthlink.net/~yatescr > > Randy, > > It depends on what you mean by solved. If you mean that the PAR can be > reduced to 0 dB or even 3 dB then no, it hasn't been solved. If you can > live with 6 dB then I'd say yes. > > There are a bunch of papers on this, but IMO the foremost authority is > a guy named Jose Tellado, formerly of Stanford. He has written a book > on PAR reduction, which is hard to find and expensive but worth it. The > technique that Tellado advocates is called Tone Reservation.Thanks for the info, John. Now I'm wondering just exactly how this is measured. When they say "peak,," do they really mean the instantaneous peak power? Or is it an average power over some relatively short interval? What is the PAR of a single-carrier system (say, BPSK) with a white input stream? -- % Randy Yates % "The dreamer, the unwoken fool - %% Fuquay-Varina, NC % in dreams, no pain will kiss the brow..." %%% 919-577-9882 % %%%% <yates@ieee.org> % 'Eldorado Overture', *Eldorado*, ELO http://home.earthlink.net/~yatescr
Randy Yates wrote:> sampson164@gmail.com writes: > >> Randy Yates wrote: >>> Subject states the question. Any information is appreciated. >>> -- >>> % Randy Yates % "And all that I can do >>> %% Fuquay-Varina, NC % is say I'm sorry, >>> %%% 919-577-9882 % that's the way it goes..." >>> %%%% <yates@ieee.org> % Getting To The Point', *Balance of Power*, ELO >>> http://home.earthlink.net/~yatescr >> Randy, >> >> It depends on what you mean by solved. If you mean that the PAR can be >> reduced to 0 dB or even 3 dB then no, it hasn't been solved. If you can >> live with 6 dB then I'd say yes. >> >> There are a bunch of papers on this, but IMO the foremost authority is >> a guy named Jose Tellado, formerly of Stanford. He has written a book >> on PAR reduction, which is hard to find and expensive but worth it. The >> technique that Tellado advocates is called Tone Reservation. > > Thanks for the info, John. > > Now I'm wondering just exactly how this is measured. When they say > "peak,," do they really mean the instantaneous peak power? Or is > it an average power over some relatively short interval? > > What is the PAR of a single-carrier system (say, BPSK) with a > white input stream?Instantaneous. PAR is usually defined in the literature over one OFDM symbol (IFFT) as 20*log10(max(abs(x))/mean(abs(x))). This is difficult to measure in a lab though. Analyzers look at a sample stream of concatenated symbols without regard to boundaries and measure the ratio of each sample magnitude to the mean without looking for peaks. In either case the results are presented on a semilog CCDF plot indicating probability on the y-axis vs PAR on the x-axis. The PAR of an ideal BPSK signal with instantaneous transitions would be 0 dB, just like an unmodulated carrier. John
Randy Yates wrote:> Subject states the question. Any information is appreciated.The problem is insolvable in the general. However there is a number of tricks that can reduce the PAR to acceptable level or alleviate the effects of clipping on the signal. The approaches fall into two categories (or a combination of two): 1. Using dummy carriers modulated in the way to reduce PAR. To be efficient, the tradeoff has to be as much as 20~30% of the available bandwidth. 2. Using a FEC scheme which is designed for clipping distortion. The main problem is that the overhead required to reduce PAR also reduces the energy efficiency, and in most practical cases there is very little gain or no gain at all. So the systems that I know of are designed to operate at the compromise PAR ~ 12..14dB with no explicit attempts to reduce it. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
<snipped>> Instantaneous. PAR is usually defined in the literature over one OFDM > symbol (IFFT) as 20*log10(max(abs(x))/mean(abs(x))). This is difficult > to measure in a lab though. Analyzers look at a sample stream of > concatenated symbols without regard to boundaries and measure the ratio > of each sample magnitude to the mean without looking for peaks. In > either case the results are presented on a semilog CCDF plot indicating > probability on the y-axis vs PAR on the x-axis. > > The PAR of an ideal BPSK signal with instantaneous transitions would be > 0 dB, just like an unmodulated carrier. >John, I have to disagree with the last statement. It surely depends on the response of the bandlimiting filter does it not? I know you say instantaneous transitions, but the signal doesn't flip from +/- 1 in a real system and when we're talking about PAPR (PAR) then you're really getting into the nuts and bolts of the transmitter. col
Randy Yates wrote:> Now I'm wondering just exactly how this is measured. When they say > "peak,," do they really mean the instantaneous peak power?Exactly. This is a maximum instantaneous peak power in the baseband.> > What is the PAR of a single-carrier system (say, BPSK) with a > white input stream?Good question. If the BPSK is not band limited, then PAR = 1. If it is bandlimited, then PAR depends on the how much of bandlimiting do you have. The interesting thing is that more narrow is the bandwidth, more Gaussian is the PDF of the signal. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
cb135@hotmail.com wrote:> <snipped> > > Instantaneous. PAR is usually defined in the literature over one OFDM > > symbol (IFFT) as 20*log10(max(abs(x))/mean(abs(x))). This is difficult > > to measure in a lab though. Analyzers look at a sample stream of > > concatenated symbols without regard to boundaries and measure the ratio > > of each sample magnitude to the mean without looking for peaks. In > > either case the results are presented on a semilog CCDF plot indicating > > probability on the y-axis vs PAR on the x-axis. > > > > The PAR of an ideal BPSK signal with instantaneous transitions would be > > 0 dB, just like an unmodulated carrier. > > > > John, I have to disagree with the last statement. It surely depends on > the response of the bandlimiting filter does it not? I know you say > instantaneous transitions, but the signal doesn't flip from +/- 1 in a > real system and when we're talking about PAPR (PAR) then you're really > getting into the nuts and bolts of the transmitter. > > colI said *ideal*. You are right that the statement isn't true for *real* signals. John
sampson164@gmail.com writes:> cb135@hotmail.com wrote: >> <snipped> >> > Instantaneous. PAR is usually defined in the literature over one OFDM >> > symbol (IFFT) as 20*log10(max(abs(x))/mean(abs(x))). This is difficult >> > to measure in a lab though. Analyzers look at a sample stream of >> > concatenated symbols without regard to boundaries and measure the ratio >> > of each sample magnitude to the mean without looking for peaks. In >> > either case the results are presented on a semilog CCDF plot indicating >> > probability on the y-axis vs PAR on the x-axis. >> > >> > The PAR of an ideal BPSK signal with instantaneous transitions would be >> > 0 dB, just like an unmodulated carrier. >> > >> >> John, I have to disagree with the last statement. It surely depends on >> the response of the bandlimiting filter does it not? I know you say >> instantaneous transitions, but the signal doesn't flip from +/- 1 in a >> real system and when we're talking about PAPR (PAR) then you're really >> getting into the nuts and bolts of the transmitter. >> >> col > > I said *ideal*. You are right that the statement isn't true for *real* > signals.By the way, John, that's how I took it. I assumed you were referring to the theoretical ideal of a rectangular pulse-shape, and that a real system would have a PAR that was dependent on (20*log of) the ratio of the peak to the RMS of the actual pulse shape. -- % Randy Yates % "She has an IQ of 1001, she has a jumpsuit %% Fuquay-Varina, NC % on, and she's also a telephone." %%% 919-577-9882 % %%%% <yates@ieee.org> % 'Yours Truly, 2095', *Time*, ELO http://home.earthlink.net/~yatescr
On Fri, 01 Dec 2006 04:15:52 GMT, Randy Yates <yates@ieee.org> wrote:>Subject states the question. Any information is appreciated.To add a tiny bit to what's tranpired so far (dang, you guys move quickly): The problem has been "solved" to the extent that there are quite a few practical OFDM systems in common use, so it's definitely workable. My experience matches Vladimir's a bit in that for the most part whitening alone goes a long, long way to PAPR reduction in OFDM, and people just generally live with what's left. Other than reasonably simple linearizing or pre-distortion technique for the PAs many systems don't rely on highly sophisticaed tricks to mitigate PAPR in OFDM. e.g., 802.11a/g uses OFDM with 48 subcarriers, and the PAPR management techniques are pretty straightforward (whitening, etc). It's not really specified in the standard how to manage it, just that the transmit mask and EVM have to meet certain specs, but herculean efforts are not needed to get there. FWIW, as the number of subcarriers goes up the problem stabilizes due mostly to the central limit theorem (whitening gets easier). Beyond FFT sizes of 64-128 points the PAPR is increasing very slowly, so it's not hard to bound the problem. I did a short study a long time ago and made this comparison: 64-QAM single-carrier with 20% RRC filtering gets a PAPR of about 5.5dB (at about the 90% spot of the cdf). OFDM with 48 subcarriers and _only whitening applied to mitigate PAPR_ was about 7.5dB PAPR at 90% and OFDM with 240 subcarriers (something I was proposing at the time) was about 8.5dB. So even for an OFDM system with a fair number of subcarriers (240) the difference to a practical single-carrier system was 3dB, without doing anything special to reduce PAPR in the OFDM system. 3dB can be a big deal in the rf, but it's not at all insurmountable or impractical to deal with. Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
