Hi Clarification on "real-time system": A word processing system, if it is very slow to respond, say it takes 15mis or longer after typing each key for it to print to the document, would you consider it to be a "real-time system" ? Thanks
real-time system - a word processor
Started by ●December 1, 2006
Reply by ●December 1, 20062006-12-01
2005 wrote:> Hi > > Clarification on "real-time system": > > A word processing system, if it is very slow to respond, say it takes > 15mis or longer after typing each key for it to print to the document, > would you consider it to be a "real-time system" ? > > Thanks >Next homework question? -- Tauno Voipio tauno voipio (at) iki fi
2005 skrev:> Hi > > Clarification on "real-time system": > > A word processing system, if it is very slow to respond, say it takes > 15mis or longer after typing each key for it to print to the document, > would you consider it to be a "real-time system" ?What do you mean by "15mis"? 15 minutes? As for "real time" or not, the system is "real time" if all operations are completed "sufficiently fast". The hard part is, of course, to determine exactly what "sufficiently fast" means... Rune
> > Clarification on "real-time system": > As for "real time" or not, the system is "real time" if all > operations are completed "sufficiently fast". The hard part > is, of course, to determine exactly what "sufficiently fast" > means...An excellent answer! We all picked up on it quickly that 2005's questions gives away his age and experience. His perspective is limited by experience (or lack of it) and so the language he uses and his expecations from it are similarly limited. We were all inexperienced like 2005 is at one point in our lives. I'm not lecturing but just noting that language will bite you in the ass every time you fail to use it accurately. 2005 needs to understand that every word he writes is significant and weighty. It's my pet peeve with my colleagues who say one thing and mean another. That's why I'm writing this. JJS
On 2006-12-01, Rune Allnor <allnor@tele.ntnu.no> wrote:>> A word processing system, if it is very slow to respond, say it takes >> 15mis or longer after typing each key for it to print to the document, >> would you consider it to be a "real-time system" ? > > What do you mean by "15mis"? 15 minutes? > > As for "real time" or not, the system is "real time" if all > operations are completed "sufficiently fast". The hard part > is, of course, to determine exactly what "sufficiently fast" > means...I would say that a real time system is one where there are _requirements_ that things have to be completed within certain time limits. Even if they aren't completed sufficiently fast it's still a real-time system, it's just one that's broken. -- Grant Edwards grante Yow! A dwarf is passing at out somewhere in Detroit! visi.com
Reply by ●December 2, 20062006-12-02
johnspeth@yahoo.com skrev:> > > Clarification on "real-time system": > > As for "real time" or not, the system is "real time" if all > > operations are completed "sufficiently fast". The hard part > > is, of course, to determine exactly what "sufficiently fast" > > means... > > An excellent answer!If you say so... The answer was inspired by a request to contribute to a marine operations project a few years ago. The customer was about to deploy this piece of equipment at the sea floor, with very tight bounds on positions. Consequently, they needed to monitor the positions of the gear as it was deployed, keeping track of position beakons as they were lowered down the water column. In our brief the objective was to keep the beacon positions updated in "real time". A general procedure was outlined where all sorts of bells and whistles were included; orthogonal codes, signalling robust with respect to Doppler, you name it (I can't help thinking the spec was a cut'n paste of the GPS position system with some more constraints added...). As I looked into this, I never really figured out why "Doppler resistance" would be necessary. The laying vessel would travel at 1 knot at most, inducing insignificant Doppler. As for orthogonal code requirements, the deployment velocity would never exceed 2 m/s, meaning that the position could be triangulated to within 5 m in five seconds or so, by coordinating reference beacons. Even if such coordination should not be possible, using different frequency bands for different beacons ought to be possible. Real time? Marine operations work on a time scale a few orders slower than most other operations. One position update every minute would be plenty; one would not be able to react faster, and it would take at least five minutes from corrective actions were initiated onboard the vessel to effects would be observable in the path of the gear to be installed. Maybe not surprising, then, that the project was cancelled...> I'm not lecturing but just noting that language will bite you in the > ass every time you fail to use it accurately. 2005 needs to understand > that every word he writes is significant and weighty. It's my pet > peeve with my colleagues who say one thing and mean another.Heh, don't get me started along those sorts of lines... ;) Rune
Reply by ●December 3, 20062006-12-03
2005 wrote:> A word processing system, if it is very slow to respond, say it takes > 15mis or longer after typing each key for it to print to the document, > would you consider it to be a "real-time system" ?I used to know someone who supposedly (I never actually saw it) could type faster than the PDP-10 interrupt routine could process characters from the input port. In that case, it would not be a real time system. -- glen
glen herrmannsfeldt wrote:> 2005 wrote: > >> A word processing system, if it is very slow to respond, say it >> takes 15mis or longer after typing each key for it to print to >> the document, would you consider it to be a "real-time system"? > > I used to know someone who supposedly (I never actually saw it) > could type faster than the PDP-10 interrupt routine could process > characters from the input port. In that case, it would not be a > real time system.I can recall a system (Tymshare IIRC), which I believe was PDP10 based, and which echoed back char by char, on which there was a roughly 5 minute delay in echoing back anything. The system was unusable, and we rapidly dropped it. Our terminal was a Teletype at 110 baud. This was about 1971 or 72. -- Chuck F (cbfalconer at maineline dot net) Available for consulting/temporary embedded and systems. <http://cbfalconer.home.att.net>
glen herrmannsfeldt wrote:> > I used to know someone who supposedly (I never actually saw it) could > type faster than the PDP-10 interrupt routine could process characters > from the input port. In that case, it would not be a real time system. >I think you could still call it a real time system, it is just the operator that typed beyond specification. Regards Josep
Reply by ●December 6, 20062006-12-06
