dbell wrote:> John, > > Suppose you decide to increase the sample rate to much higher than the > signal BW, add wideband dither noise prior to sampling, wideband in > relation to the high sample rate, sample with very coarse resolution, > then digitally decimate the signal, removing most of the quantization > noise in the process. Would you expect the quality to go up? > > Dirk >Dirk, This thread has been educational to me and has clarified a few things. Randy in particular pointed out that dithering is helpful in reducing the grainy effect for signals down near the bottom of the range of a CD, so to answer your question I would say that the dithering in your example could improve the quality by removing granularity in those cases where the audio signal frequency happened to be a near-exact fraction of the sample rate. Apart from this I would expect the decimation to yield one extra bit of resolution and 3dB improvement in S/N ratio for every factor of 2 that the sample rate is reduced. This improvement would occur regardless of whether the dithering is turned on or off. Regards, John> > John Monro wrote: > > <snipped> > >> Thanks for the counterexample Jerry. Dithering clearly makes the signal >> detectable, and this has advantages for measurement where multi-sample >> averaging is carried out. You and Steve refer to this in later postings. >> >> The question is: in your counterexample, would dithering lead to a >> perceived improvement to the quality of the audio signal ? I can't see >> that it would, because the 0.5-bit amplitude signal which was previously >> undetected in the absence of dithering now gets sampled as a 1-bit noise >> signal. This is hardly an improvement! >> >> Regards, >> John >
Dithering for
Started by ●December 1, 2006
Reply by ●December 3, 20062006-12-03
John Monro wrote:> With music > like that, who cares if there are a few harmonically-related spurs > present? They may be an improvement! :=)The problem is the spurs are not just the harmonics, but all kinds of intermods between the sample rate and the input frequency. VLV
John Monro wrote:> Jerry Avins wrote: >> Jerry Avins wrote: >> >> ... >> >>> Noise would not be an improvement. Under conditions where external >>> noise sources don't mask it, the detected 1/5-bit signal can be >>> clearly audible with an evident pitch. >> > Interesting! I would not have expected that. > >> 1/5 --> 1/2. As a signal fades to silence, the quantizing becomes >> evident, and sometimes that is intrusive. Dithering makes it less >> intrusive. Perhaps because the low-level noise tends to mask some of >> the artifacts, but also because it suppressed them. If you want to >> explore the effects of dithering, quantize your audio to five bits or >> so, with and without dither, and with different depths of dither. I >> haven't done that myself, but I've heard the results and I'm a >> believer. It's much harder to hear a good signal made slightly better >> than it is to hear a bad one edge toward passable. >> >> Jerry > > Was speech or music being used, rather than a test tone?Both speech and music. 4-bit speech is intelligible if the speaker (or electronics) limits the dynamic range. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
John Monro wrote: ...> Apart from this I would expect the decimation to yield one extra bit of > resolution and 3dB improvement in S/N ratio for every factor of 2 that > the sample rate is reduced.Square root of number of samples. 3 dB is half a bit. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
John Monro wrote:> The question is: in your counterexample, would dithering lead to > a perceived improvement to the quality of the audio signal ?Dithering is an application of stochastic resonance which also occurs in the ear with beneficial effects. There was an article in Scientific American about that: F. Moss and K. Wiesenfeld, "The benefits of background noise", Scientific American 273, 66-69 (1995) Martin -- Quidquid latine scriptum sit, altum viditur.
Jerry Avins wrote:> John Monro wrote: > > ... > >> Apart from this I would expect the decimation to yield one extra bit >> of resolution and 3dB improvement in S/N ratio for every factor of 2 >> that the sample rate is reduced. > > Square root of number of samples. 3 dB is half a bit. > > JerryJerry, Thanks for the correction. It should be 1/2 bit resolution improvement. Regards, John
Vladimir Vassilevsky wrote:> > > John Monro wrote: > >> With music like that, who cares if there are a few >> harmonically-related spurs present? They may be an improvement! :=) > > The problem is the spurs are not just the harmonics, but all kinds of > intermods between the sample rate and the input frequency. > > VLVVladimir, Thanks for that. This thread is helping me clarify my thoughts on the subject. Regards, John
John Monro wrote:> Ron N. wrote: > > Yazz wrote: > >> Hopefully some of you guru's here can set me straight here. > >> > >> In an attempt to reduce quantization spurs, I have read about > >> dithering. I have seen wideband dithering and narrowband dithering. > >> All of this is done in the analog domain prior to the sampling. > >> > >> My question is: Why can we not simply add a random LSB (+/- 1) to each > >> of the samples AFTER sampling to reduce quantization spurs ? > > > > You can not regain information once you've thrown it away. > > > > If you add dither after rounding or truncating (which throws > > away any fractional information), then you just add noise. > > > > If you dither before rounding or truncation, then you spread > > out the fractional information (a +0.25 fraction could become > > from -n.75 to +n.25) into a probability distribution where > > the fractional information might be able to leak thru the > > quantization process, given a statistically large enough number > > of samples. The randomization of the dither noise actually > > prevents the information from being completely thrown away, > > but, in exchange, hides it in noise. > > > > In both cases you get noise, but in the pre-dither case, you > > get more information about the signal hidden in the noise. > > A patterned dither, or fraction saving process, instead of > > a random dither, allows one to deduce even more information > > about the signal as it was prior to rounding or truncation, > > by making some of the noise more removable. > > > > > > > > IMHO. YMMV. > > An interesting and instructive answer from the information / statistics > point of view. > > Another way of looking at the question is to examine what happens when a > repetitive, constant-amplitude test signal is applied. If its frequency > is a simple fraction of the sample frequency, the quantisation noise is > also repetitive, and repeats over a few cycles of the test signal. In > the frequency domain the effect is that 'spurs' appear, and these are > harmonically related to the test signal. If dithering is now applied to > the test signal it disrupts the regular nature of the quantisation > noise, spreading out the spurs in the frequency domain. > > This brings me to my main point. Is dithering have any other use apart > from improving the test-signal results? It seems to me that dithering > does not provide any benefit at all when 'real-life' audio or video > signals are being sampled, and I would be interested if anyone disagrees > with this.In real life, the ears and eyes of mammals use a process very much like dithering to improve sensitivity of certain kinds of inputs. (Eyeballs, unlike cameras with very slow film, don't work very well when clamped and aimed at still target images). IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-M
