MCU/DSP Combination
Started by fulan June 7, 2004
"Phil Martel" <p.martel@comcast.net> wrote in message news:<UcLCc.177199$Ly.42054@attbi_s01>...
> "Jaime Andres Aranguren Cardona" <jaime.aranguren@ieee.org> wrote in message > news:14a86f87.0406241401.2aa44b4b@posting.google.com... > > babs@eng.umd.edu (fulan) wrote in message > news:<e2bf6f14.0406230756.f020060@posting.google.com>... > > > Thank you for the many replies. > > > > > > My specs dictate that I have a 14-16bit ADC converter, this can be > > > internal to the processor or external. The requirement is the ability > > > to read at least 256 samples per second, ideally 512 samples per > > > second. We would repeat the reading for approximately 8 seconds and > > > perform some FFTs on the data. The philips LPC2106 seems like a good > > > option however it lacks an internal A/D. Furthermore, are their A/D > > > converters capable of acquiring that many points at that resolution > > > that quickly?(internal or external). > > > > > > Moussa
This may sound silly bit I ask if you need a full FFT. Do you want to find the magnitudes of ALL frequencies in your range or just a few frequencies of interest. If it's the latter then you don't need FFT just synchrronus demodulation and that's alot simpler. I can point you int that direction if it would help. George
Thanx for the reply George,
You are correct, the customer does not necessarily need a Full FFT, I
would be interested in finding out about synchronous demodulation.
Moussa.
P.S.: we will still give him the ability to perform a Full FFT,however
it should be interesting to finding out how that can be optmized.
george.martin@att.net (George) wrote in message news:<e9d879fa.0406250554.27d9bd17@posting.google.com>...
> "Phil Martel" <p.martel@comcast.net> wrote in message news:<UcLCc.177199$Ly.42054@attbi_s01>... > > "Jaime Andres Aranguren Cardona" <jaime.aranguren@ieee.org> wrote in message > > news:14a86f87.0406241401.2aa44b4b@posting.google.com... > > > babs@eng.umd.edu (fulan) wrote in message > news:<e2bf6f14.0406230756.f020060@posting.google.com>... > > > > Thank you for the many replies. > > > > > > > > My specs dictate that I have a 14-16bit ADC converter, this can be > > > > internal to the processor or external. The requirement is the ability > > > > to read at least 256 samples per second, ideally 512 samples per > > > > second. We would repeat the reading for approximately 8 seconds and > > > > perform some FFTs on the data. The philips LPC2106 seems like a good > > > > option however it lacks an internal A/D. Furthermore, are their A/D > > > > converters capable of acquiring that many points at that resolution > > > > that quickly?(internal or external). > > > > > > > > Moussa > > This may sound silly bit I ask if you need a full FFT. Do you want to > find the magnitudes of ALL frequencies in your range or just a few > frequencies of interest. If it's the latter then you don't need FFT > just synchrronus demodulation and that's alot simpler. > > I can point you int that direction if it would help. > > George
