Hi all, If input a step respond into a SDM with a 1 bit quantizer, the output would be a stream of '1' and '0' s. IS that stream PCM or PDM?? Can I tell the dynamic range form the bit stream?? For example a 50nA step input with a output bit strem of "101010111011" and repeat. what can I tell from these stream?? Say if I use a 1:12 decimation average =8/12 0.6667 Does that mean 75nA is the full scale??
Sigms Delta Modulator Question
Started by ●December 11, 2006
