Hi! I am currently use FFTW to compute a two dimentional DFT of real data, I readed the FFTW documentation an proced as follow: /*** The fft.h file *** #include <fftw3.h> using namespace std; class fft { public: fft(); fft(int rows, int cols); ~fft(); fftw_complex * forward(double *); double * backward(fftw_complex *); fftw_complex * multiply(fftw_complex *, fftw_complex *); private: fftw_plan plan_backward; fftw_plan plan_forward; int nx; int ny; int n; double *out; fftw_complex * forward_result; fftw_complex* multiply_result; }; /*** the fft.C file ***/ #include <iostream> #include <rfftw.h> #include "fft.h" fft::fft(int rows, int cols) { nx = rows; ny = cols; n = nx*ny; } fft::~fft() { fftw_destroy_plan (plan_backward ); fftw_destroy_plan (plan_forward ); delete[](out); } fftw_complex * fft::forward(double * in) { int nc = (n/2)+1; forward_result = (fftw_complex *) fftw_malloc ( sizeof ( fftw_complex ) * nx *(ny/2+1) ); plan_forward = fftw_plan_dft_r2c_2d( nx, ny, in, forward_result, FFTW_ESTIMATE); fftw_execute ( plan_forward ); return(forward_result); } double * fft::backward(fftw_complex * in) { out = new double[nx*(ny/2+1)]; plan_backward = fftw_plan_dft_c2r_2d(nx, ny, in, out, FFTW_ESTIMATE); fftw_execute ( plan_backward ); /* normalization */ for(int i=0; i < nx*ny; i++) out[i] /= nx*ny; return(out); } fftw_complex * fft::multiply(fftw_complex * A, fftw_complex * B) { fftw_complex * R; double scale = 1.0 / (nx * ny); R = (fftw_complex*)fftw_malloc(sizeof(fftw_complex) *nx * ny); for(int i= 0; i < nx; i++) for(int j= 0; j < ny/2+1; j++){ int ij = i*(ny/2+1) + j; R[i][j].re = (A[ij].re * B[ij].re - A[ij].im * B[ij].im) * scale; R[i][j].im = (A[ij].re * B[ij].im + A[ij].im * B[ij].re) * scale; } return(R); } /** The matrix.h file **/ #include <iostream> #include <fstream> //#include "fft.h" using namespace std; //class fft; class Cmatrix { private: protected: double * arr; int m_nRows; int nCols; public: Cmatrix(); Cmatrix::Cmatrix(const Cmatrix& foo) { arr = foo.arr; m_nRows = foo.m_nRows; nCols = foo.nCols; } Cmatrix( int rows,int cols); Cmatrix(int rows, int cols, double * a); void setValue(int row,int col,double value); const double getValue( int row, int col)const; const int getRows() const ; const int getCols() const ; double * convolve(Cmatrix); Cmatrix * convolve(Cmatrix * pCmatrix_r); double * Cmatrix::getArray(); }; #endif /** matrix.C file **/ #include "matrix.h" #include <assert.h> //constructors, destructors Cmatrix::Cmatrix() { arr = NULL; m_nRows = 0; m_nCols = 0; arr = new double [rows*cols]; assert(arr!=0); /* Initialization */ for(int i=0;i<(rows*cols);i++) { arr[i]=0.0; } } Cmatrix::~Cmatrix() { if(arr!=NULL) { delete[](arr); arr=NULL; } } void Cmatrix::setValue(int row, int col, double value) { // check if access is legal if( (row>m_nRows) || (col>m_nCols) || (row<=0) || (col<=0)) { cerr<<"ERROR: MATRIX OUT OF BOUND ACCESS, VALUE NOT SET !"<<endl; return; } int l = (row-1)*m_nCols + col-1; arr[l] = value; } const double Cmatrix::getValue( int row, int col) const { /* check if access is legal */ const int ZERO=0; if( (row>m_nRows) || (col>m_nCols) || (row<=0) || (col<=0)) { cerr<<"ERROR: MATRIX OUT OF BOUND ACCESS, ZERO RETURNED !"<<endl; return 0; } return arr[(row-1)*m_nCols+col-1]; } /*inline*/ const int Cmatrix::getRows() const { return(m_nRows); } /*inline*/ const int Cmatrix::getCols() const { return(nCols); } /*inline*/ double * Cmatrix::getArray() { return(arr); } double * Cmatrix::convolve(Cmatrix Y) { fftw_real a[M][2*(N/2+1)], b[M][2*(N/2+1)], c[M][N]; fftw_complex *A, *B, C[M][N/2+1]; fftw_plan p, pinv, rhs; fftw_real scale = 1.0 / (M * N); int i, j; int M, N, nRowsZ, nColsZ; double * arrZ, * arrY; //h-- doublecomplex * pW; arrY = Y.getArray(); M = Y.getRows(); N = Y.getCols(); nRowsZ = M+m_nRows-1; nColsZ = N+m_nCols-1; arrZ = new double [nRowsZ*nColsZ]; /* aliases for accessing complex transform outputs: */ A = (fftw_complex*) &a[0][0]; B = (fftw_complex*) &b[0][0]; for (i = 0; i < M; ++i) for (j = 0; j < N; ++j) { a[i][j] = ... ; b[i][j] = ... ; } p = fftw_plan_dft_r2c_2d(M,N,&a[0][0],NULL,FFTW_ESTIMATE); pinv = fftw_plan_dft_r2c_2d(M,N,&b[0][0],NULL,FFTW_ESTIMATE); fftw_execute (p); fftw_execute (pinv); for (i = 0; i < M; ++i) for (j = 0; j < N/2+1; ++j) { int ij = i*(N/2+1) + j; C[i][j].re = (A[ij].re * B[ij].re - A[ij].im * B[ij].im) * scale; C[i][j].im = (A[ij].re * B[ij].im + A[ij].im * B[ij].re) * scale; } /* inverse transform to get c, the convolution of a and b; this has the side effect of overwriting C */ rhs = fftw_plan_dft_c2r_2d(M,N,&C[0][0],&c[0][0],FFTW_ESTIMATE); fftw_execute (rhs); for(int a=0; a < nRowsY; a++) for(int b=0; b < nColsY; b++) arrZ[a*nColsY+b] = c[a][b]; return(arrZ); } Cmatrix * Cmatrix::convolve(Cmatrix * pCmatrix_rhs) { fft F1(this->getRows(),this->getCols()); // perform forward FFT transform fftw_complex * f1 = F1.forward(this->getArray()); fftw_complex * gx = F1.forward(pCmatrix_rhs->getArray()); double * gy=F1.forward(m_pMatrixGreenY->getArray()); // multiply in complex variable domain fftw_complex * px = F1.multiply(f1,gx); fftw_complex * py = F1.multiply(f1,gy); // delete to avoid memory leakage delete []f1; delete []gx; delete []gy; //perform backward FFT transform double * rx = F1.backward(px); double * ry = F1.backward(py); // delete delete []px; // result matrices generated from result double arrays Cmatrix * pCmatrix_result =new Cmatrix(this->getRows(),this->getCols(),rx); return pCmatrix_result; } as you see my procedure convolve(Cmatrix Y) is imcomplete because I don't understand the convolve with FFTW, and I am not sure about the procedure multiply(fftw_complex * A, fftw_complex * B). pleased help me to correct my faults. Thanks
Complex Multiplication and convolution with FFTW
Started by ●December 13, 2006
Reply by ●December 13, 20062006-12-13
Hi! little corrections /*** The fft_l.h file *** #include <fftw3.h> using namespace std; class fft { public: fft(); fft(int rows, int cols); ~fft(); fftw_complex * forward(double *); double * backward(fftw_complex *); fftw_complex * multiply(fftw_complex *, fftw_complex *); private: fftw_plan plan_backward; fftw_plan plan_forward; int nx; int ny; int n; double *out; fftw_complex * forward_result; fftw_complex* multiply_result; }; /*** the fft_l.C file ***/ #include <iostream> #include <rfftw.h> #include "fft.h" fft::fft(int rows, int cols) { nx = rows; ny = cols; n = nx*ny; } fft::~fft() { fftw_destroy_plan (plan_backward ); fftw_destroy_plan (plan_forward ); delete[](out); } fftw_complex * fft::forward(double * in) { int nc = (n/2)+1; forward_result = (fftw_complex *) fftw_malloc ( sizeof ( fftw_complex ) * nx *(ny/2+1) ); plan_forward = fftw_plan_dft_r2c_2d( nx, ny, in, forward_result, FFTW_ESTIMATE); fftw_execute ( plan_forward ); return(forward_result); } double * fft::backward(fftw_complex * in) { out = new double[nx*(ny/2+1)]; plan_backward = fftw_plan_dft_c2r_2d(nx, ny, in, out, FFTW_ESTIMATE); fftw_execute ( plan_backward ); /* normalization */ for(int i=0; i < nx*ny; i++) out[i] /= nx*ny; return(out); } fftw_complex * fft::multiply(fftw_complex * A, fftw_complex * B) { fftw_complex * R; double scale = 1.0 / (nx * ny); R = (fftw_complex*)fftw_malloc(sizeof(fftw_complex) *nx * ny); for(int i= 0; i < nx; i++) for(int j= 0; j < ny/2+1; j++){ int ij = i*(ny/2+1) + j; R[i][j].re = (A[ij].re * B[ij].re - A[ij].im * B[ij].im) * scale; R[i][j].im = (A[ij].re * B[ij].im + A[ij].im * B[ij].re) * scale; } return(R); } /** The matrix.h file **/ #include <iostream> #include <fstream> #include "fft_l.h" using namespace std; class fft; class Cmatrix { private: protected: double * arr; int m_nRows; int nCols; public: Cmatrix(); Cmatrix::Cmatrix(const Cmatrix& foo) { arr = foo.arr; m_nRows = foo.m_nRows; m_nCols = foo.m_nCols; } Cmatrix( int rows,int cols); Cmatrix(int rows, int cols, double * a); void setValue(int row,int col,double value); const double getValue( int row, int col)const; const int getRows() const ; const int getCols() const ; double * convolve(Cmatrix); Cmatrix * convolve(Cmatrix * pCmatrix_r); double * Cmatrix::getArray(); }; #endif /** matrix.C file **/ #include "matrix.h" #include <assert.h> //constructors, destructors Cmatrix::Cmatrix() { arr = NULL; m_nRows = 0; m_nCols = 0; arr = new double [rows*cols]; assert(arr!=0); /* Initialization */ for(int i=0;i<(rows*cols);i++) { arr[i]=0.0; } } Cmatrix::~Cmatrix() { if(arr!=NULL) { delete[](arr); arr=NULL; } } void Cmatrix::setValue(int row, int col, double value) { // check if access is legal if( (row>m_nRows) || (col>m_nCols) || (row<=0) || (col<=0)) { cerr<<"ERROR: MATRIX OUT OF BOUND ACCESS, VALUE NOT SET !"<<endl; return; } int l = (row-1)*m_nCols + col-1; arr[l] = value; } const double Cmatrix::getValue( int row, int col) const { /* check if access is legal */ const int ZERO=0; if( (row>m_nRows) || (col>m_nCols) || (row<=0) || (col<=0)) { cerr<<"ERROR: MATRIX OUT OF BOUND ACCESS, ZERO RETURNED !"<<endl; return 0; } return arr[(row-1)*m_nCols+col-1]; } /*inline*/ const int Cmatrix::getRows() const { return(m_nRows); } /*inline*/ const int Cmatrix::getCols() const { return(nCols); } /*inline*/ double * Cmatrix::getArray() { return(arr); } double * Cmatrix::convolve(Cmatrix Y) { fftw_real a[M][2*(N/2+1)], b[M][2*(N/2+1)], c[M][N]; fftw_complex *A, *B, C[M][N/2+1]; fftw_plan p, pinv, rhs; fftw_real scale = 1.0 / (M * N); int i, j; int M, N, nRowsZ, nColsZ; double * arrZ, * arrY; //h-- doublecomplex * pW; arrY = Y.getArray(); M = Y.getRows(); N = Y.getCols(); nRowsZ = M+m_nRows-1; nColsZ = N+m_nCols-1; arrZ = new double [nRowsZ*nColsZ]; /* aliases for accessing complex transform outputs: */ A = (fftw_complex*) &a[0][0]; B = (fftw_complex*) &b[0][0]; for (i = 0; i < M; ++i) for (j = 0; j < N; ++j) { a[i][j] = ?? ; b[i][j] = ?? ; } p = fftw_plan_dft_r2c_2d(M,N,&a[0][0],NULL,FFTW_ESTIMATE); pinv = fftw_plan_dft_r2c_2d(M,N,&b[0][0],NULL,FFTW_ESTIMATE); fftw_execute (p); fftw_execute (pinv); for (i = 0; i < M; ++i) for (j = 0; j < N/2+1; ++j) { int ij = i*(N/2+1) + j; C[i][j].re = (A[ij].re * B[ij].re - A[ij].im * B[ij].im) * scale; C[i][j].im = (A[ij].re * B[ij].im + A[ij].im * B[ij].re) * scale; } /* inverse transform to get c, the convolution of a and b; this has the side effect of overwriting C */ rhs = fftw_plan_dft_c2r_2d(M,N,&C[0][0],&c[0][0],FFTW_ESTIMATE); fftw_execute (rhs); for(int a=0; a < nRowsY; a++) for(int b=0; b < nColsY; b++) arrZ[a*nColsY+b] = c[a][b]; return(arrZ); } Cmatrix * Cmatrix::convolve(Cmatrix * pCmatrix_rhs) { fft F1(this->getRows(),this->getCols()); // perform forward FFT transform fftw_complex * f1 = F1.forward(this->getArray()); fftw_complex * gx = F1.forward(pCmatrix_rhs->getArray()); double * gy=F1.forward(m_pMatrixGreenY->getArray()); // multiply in complex variable domain fftw_complex * px = F1.multiply(f1,gx); fftw_complex * py = F1.multiply(f1,gy); // delete to avoid memory leakage fftw_free(f1); fftw_free(gx); fftw_freeg(y); //perform backward FFT transform double * rx = F1.backward(px); double * ry = F1.backward(py); // delete fftw_free(px); // result matrices generated from result double arrays Cmatrix * pCmatrix_result =new Cmatrix(this->getRows(),this->getCols(),rx); return pCmatrix_result; } The function multiply(fftw_complex * A, fftw_complex * B) to Perform pointwise multiplication of A and B give me lot of faults like: fft_l.C:118: request for member `re' in `*((((i * 2) + j) * 8) + R)', which is of non-aggregate type `double' fft_l.C:118: request for member `re' in `*(A + (+(ij * 16)))', which is of non-aggregate type `double[2]' fft_l.C:119: request for member `re' in `*(B + (+(ij * 16)))', which is of non-aggregate type `double[2]' fft_l.C:119: request for member `im' in `*(A + (+(ij * 16)))', which is of non-aggregate type `double[2]' the second point is to perform the two dimentional convolution of a Matrix with the function convolve(Cmatrix Y), I have learned that is possible to perfom it using the two dimentional fft routines to compute the two-dimensional convolutions of the two-dimensional arrays A and B as follow: 1. Compute the two-dimensional FFT of A. 2. Compute the two-dimensional FFT of B. 3. Perform pointwise multiplication of A and B. 4. Compute the inverse two-dimensional FFT of the previous result. my problem is to define the two dimentional arrays A and B throught the matrix and used the methode in the documantation of FFTW http://www.fftw.org/fftw2_doc/fftw_2.html as I tried to do it in function convolve(Cmatrix Y) I'll like to know how can I compute the convolution of a matrix. Pleased help me. Thanks
