Does anyone know the Mathematical Definition of Even Symmetric Filter?
Started by junoexpress ●December 13, 2006
Hi,
Can anyone give me a rigorous math definition of the term "even
symmetric filter"?
TIA,
Matt
"junoexpress" <MTBrenneman@gmail.com> wrote in
news:1166038177.991529.323410@t46g2000cwa.googlegroups.com:
> Hi, > > Can anyone give me a rigorous math definition of the term "even > symmetric filter"? > > TIA, > > Matt > >
For some value of j, x[j+k]=x[j-k] for every k -- Scott Reverse name to reply
Back up a bit. Do you know the meanings of "even symmetry" and "odd symmetry"? A cosine has even symmetry about the origin, while a sine has odd symmetry. Can you take it from there? Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
Nope. Doesn't work.
For [1 2 2 1], what is j if k is an integer?
Dirk
Scott Seidman wrote:
> "junoexpress" <MTBrenneman@gmail.com> wrote in > news:1166038177.991529.323410@t46g2000cwa.googlegroups.com: > > > Hi, > > > > Can anyone give me a rigorous math definition of the term "even > > symmetric filter"? > > > > TIA, > > > > Matt > > > > > > For some value of j, x[j+k]=x[j-k] for every k > > -- > Scott > Reverse name to reply
"dbell" <bellda2005@cox.net> wrote in news:1166039602.604314.83630
> Nope. Doesn't work. > > For [1 2 2 1], what is j if k is an integer? > > Dirk > > Scott Seidman wrote: >> "junoexpress" <MTBrenneman@gmail.com> wrote in >> news:1166038177.991529.323410@t46g2000cwa.googlegroups.com: >> >> > Hi, >> > >> > Can anyone give me a rigorous math definition of the term "even >> > symmetric filter"? >> > >> > TIA, >> > >> > Matt >> > >> > >> >> For some value of j, x[j+k]=x[j-k] for every k >> >> -- >> Scott >> Reverse name to reply > >
OK, one of either the above or x[j+.5 +(k+.5)] = x[j+.5 -(k+.5)] must be true -- Scott Reverse name to reply
I'm a mathematician working on a problem with a colleague. She's trying
to find the center freq of the FFT of a discrete BPSK signal. The
problem is that the PSD at the center freq (i.e. your estimate for the
"true" signal freq) is often not the local max: instead what often
happens is that the FFT gets "split" about the true center freq, with
the max FFT values occuring on both sides of the center freq. So using
the max PSD value is not a good method for finding the center
frequency. The one thing that struck me when she showed me the FFT
about the center freq (for a simulated BPSK signal), was how symmetric
it was.
When I used some Monte-Carlo simulations and played around with
different measures of "symmetry" for some window (of say n pts) around
the center freq, like skewness, odd moments, etc. , what I found was
that the following function ALWAYS performed superior ro any other
function. This function always located the true center freq _exactly_.
The function was:
S(k) = Sum on k from k=1 to n of [F(k-j) - F(j+k)]^2
where F(*) = PSD at pt (*)
So this function is essentially minimizing the rms deviation of the PSD
and its image inverted about pt k.
I am wondering if in DSP this is a type of "even symmetric filter",
which was what motivated my original question.
TA,
Matt
> "dbell" <bellda2005@cox.net> wrote in news:1166039602.604314.83630 > @t46g2000cwa.googlegroups.com: > > > Nope. Doesn't work. > > > > For [1 2 2 1], what is j if k is an integer? > > > > Dirk > > > > Scott Seidman wrote: > >> "junoexpress" <MTBrenneman@gmail.com> wrote in > >> news:1166038177.991529.323410@t46g2000cwa.googlegroups.com: > >> > >> > Hi, > >> > > >> > Can anyone give me a rigorous math definition of the term "even > >> > symmetric filter"? > >> > > >> > TIA, > >> > > >> > Matt > >> > > >> > > >> > >> For some value of j, x[j+k]=x[j-k] for every k > >> > >> -- > >> Scott > >> Reverse name to reply > > > > > > OK, one of either the above or > x[j+.5 +(k+.5)] = x[j+.5 -(k+.5)] must be true > > > -- > Scott > Reverse name to reply
Should read with the summation index being j not k, so the correct eqn is: S(k) = Sum on j from j=1 to n of [F(k-j) - F(j+k)]^2 Sorry, Matt
Matt wrote:
> I am wondering if in DSP this is a type of "even symmetric filter", > which was what motivated my original question.
The symmetry property is w.r.t. the impulse response of the filter, and has (almost) nothing to do with the shape of the frequency response. Regards, Andor
junoexpress wrote:
> I'm a mathematician working on a problem with a colleague. She's trying > to find the center freq of the FFT of a discrete BPSK signal. The > problem is that the PSD at the center freq (i.e. your estimate for the > "true" signal freq) is often not the local max: instead what often > happens is that the FFT gets "split" about the true center freq, with > the max FFT values occuring on both sides of the center freq. So using > the max PSD value is not a good method for finding the center > frequency.
Since you seem to be running into FFT resolution issues, is zero-padding the time domain signal to generate more points in the FFT an option? If your frequency bins are more finely spaced, you're more likely to get a good estimate for the peak. Jason
Andor wrote:
> Matt wrote: > > > I am wondering if in DSP this is a type of "even symmetric filter", > > which was what motivated my original question. > > The symmetry property is w.r.t. the impulse response of the filter, and > has (almost) nothing to do with the shape of the frequency response. > > Regards, > Andor
Thank you. That defintely answers my question. Matt
