Hi all !! I would like to use the LMS Filter in Simulink !! Any Suggestions !! How to connect the desired input with the output and error !! I get some errors !! Don't understand !! Also there is problem with double and unsigned integers !! when i used the "Sum Block "in simulink !! Appreciate if somebody can draw it or show it more clearly !! Thanking you Ali
Started by ●December 17, 2006
Reply by ●December 17, 20062006-12-17
MuhammadAli.AA@gmail.com wrote:> Hi all !! > > I would like to use the LMS Filter in Simulink !! > > Any Suggestions !! How to connect the desired input with the output and > error !! > > I get some errors !! > > Don't understand !! > > Also there is problem with double and unsigned integers !! when i used > the "Sum Block "in simulink !! > > Appreciate if somebody can draw it or show it more clearly !!Did you read the manual ?? try it !! Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
