Hello All, I'm currently using the Goertzal algorithm to find a couple frequencies in some audio samples. However, how am I supposed to deal with volume differences? On occasion, the tones are quieter and thus don't seem to be picked up by the decoder. Same thing with loud tones: they don't necessarily get picked up. Should I boost/lower volume on the fly (sounds real hard!) or tweak the algorithm depending upon the average magnitude of the incoming samples? Any ideas will be welcome! Thanks, Brett
Volume
Started by ●December 20, 2006
Reply by ●December 20, 20062006-12-20
brettccl...@gmail.com wrote:> Hello All, > I'm currently using the Goertzal algorithm to find a couple frequencies > in some audio samples. However, how am I supposed to deal with volume > differences? On occasion, the tones are quieter and thus don't seem to > be picked up by the decoder. Same thing with loud tones: they don't > necessarily get picked up. Should I boost/lower volume on the fly > (sounds real hard!) or tweak the algorithm depending upon the average > magnitude of the incoming samples? Any ideas will be welcome!is the application a DTMF decoder? i wouldn't AGC the thing, but i would compare the filter output (or the sum of the two filter outputs, if this is a 2-tone DTMF) to the broadbanded measure of power to make sure that they are close to each other. also, for DTMF, the two tones should be close to equal in magnitude. when both of those relative measures exceed some threshold that you determine, you might say that the decoder has a legitimate "hit". r b-j
Reply by ●December 21, 20062006-12-21
robert bristow-johnson wrote:> > i wouldn't AGC the thing, but i would compare the filter output (or the > sum of the two filter outputs, if this is a 2-tone DTMF) to the > broadbanded measure of power to make sure that they are close to each > other. also, for DTMF, the two tones should be close to equal in > magnitude. when both of those relative measures exceed some threshold > that you determine, you might say that the decoder has a legitimate > "hit".The "SNR" as well as the relative powers in the two frequency bins are prescribed by standards (ITU-T Q.24 IIRC) for DTMF tones. There is some variation across national boundaries, but the "you determine" aspect of it is limited. C
No, this is not DTMF. It is Baudot code (TTY) which consist of independant 1400 and 1800 Hz tones played end to end (i.e., no overlapping tones like in DTMF). What is the "broadbanded measure of power"? How can I implement this in my app? Whats the idea behind it? Thanks, Brett robert bristow-johnson wrote:> is the application a DTMF decoder? > > i wouldn't AGC the thing, but i would compare the filter output (or the > sum of the two filter outputs, if this is a 2-tone DTMF) to the > broadbanded measure of power to make sure that they are close to each > other. also, for DTMF, the two tones should be close to equal in > magnitude. when both of those relative measures exceed some threshold > that you determine, you might say that the decoder has a legitimate > "hit". > > r b-j
brettcclark@gmail.com wrote:> No, this is not DTMF. It is Baudot code (TTY) which consist of > independant 1400 and 1800 Hz tones played end to end (i.e., no > overlapping tones like in DTMF). > > What is the "broadbanded measure of power"? > ... What's the idea behind it?if x(t) is your signal, the power around time t0 is px(t0) = (1/tau)*integral{ |x(t)|^2 * w((t-t0)/tau) dt} where w((t-t0)/tau) >= 0 is a window centered around time t0 of width tau and scaled or normalized so that: integral{ w(t/tau) dt} = tau or integral{ w(u) du} = 1 this is "broadbanded" because it's the raw input, x(t), going into it without running x(t) through some filter and eliminating other frequency components. now, suppose you define some y(t) which is the output of some filter (with impulse response h(t)) that had x(t) going in. and let's also define the filter so that the gain in the middle of the passband of the filter is normalized to be 1 (or 0 dB): .------. x(t) ---->| h(t) |-----> y(t) = integral{ x(u)*h(t-u) du} '------' now suppose that output y(t) has its power measured in the same way that x(t) is: py(t0) = (1/tau)*integral{ |y(t)|^2 * w((t-t0)/tau) dt} even though it's was normalized, it's probably a good idea to have the same window, w(), and same width, tau. now, the ratio py(t0)/px(t0) is a measure of how much of the energy of x(t) there is that lives in the passband of the filter that outputs y(t). if that ratio is very close to one, then you can say that all of x(t) consists of frequency components tuned to whatever frequency the filter is tuned to. if that filter is tuned to 1400 Hz, that is a measure of how confident you are that x(t) is purely 1400 Hz. if the confidence of the 1800 Hz signal is higher than the confidence of the 1400 Hz signal, you might have a "1". if it's the other way around, you might have a "0". if you normalized things right (and if your filter bandwidths are small enough so that 1400 Hz stays the hell outa the 1800 Hz filter and vice-versa), there is no way that the confidence of *both* filter outputs can be close to one at the same time, t0. if the confidence for both filter outputs are low, you know you don't have a decent FSK signal to work with and you should inform the client program of such. so you might have 3 possible outputs: "0", "1", and too crappy to tell.> How can I implement this in my app?convert x(t) into x[n] (samples), w(t) to w[n], y(t) to y[n], and replace the integrals with summations and implement your filters with some decent passband filters or perhaps a scaled version of the audio peakingEQ. the center frequencies should be tuned to 1400 Hz and 1800 Hz and the gain at those center frequencies should be 1 (or 0 dB). the audio EQ cookbook might help you quickly design the filters. other than that, you're on your own or you gotta pay someone else to sweat the details. r b-j
Reply by ●December 22, 20062006-12-22
brettcclark@gmail.com wrote:> No, this is not DTMF. It is Baudot code (TTY) which consist of > independant 1400 and 1800 Hz tones played end to end (i.e., no > overlapping tones like in DTMF).I am not aware which standards (if any) drive TTY compliance. There must be an acceptable operating range for the tones and your tone detectors (yes, for a few independent tones Goertzel is a good choice) need to be designed for that range. Have you implemented this in a fixed-point machine? If so, the choice of size and Q formats for representing the coeffficients and intermediate values will determine the dynamic range that can be addressed. Also, what is the environment like? Is there an echo canceller or a non-linear processor (i.e. residual echo suppressor) anywhere in the system? C
