Hi, I'm trying 2 realize the function "butter" as iin matlab, using scilab. So instead of [a, b]=butter(ord,[int1* 2/Freq int2*2/Freq]); I write the following: hz=iir(ord,'lp', 'butt', [int1/Freq int2/Freq], [0 0]); a=coeff(denom(hz));a=a($:-1:1); b=coeff(numer(hz));b=b($:-1:1); and I don't get the same results as in matlab. What do I do to get the same results? p.s. I've user the same 'ord' parameter in both environments. Also, I suspect the 4th parameter in the call 2 iir function. Please advice. Thank you, Rivka
converting Matlab's
Started by ●January 7, 2007
