Hi all, I heard we can obtain the phase difference between two signal from cross power spectrum. If someone knew, could you show me how to obtain the phase difference ? I mean the algorithm. I read the cross power spectrum is defined as FFT (A) FFT*(B) / N^2, so we have real and imaginary components. Thanks, Titi
Phase difference from cross power spectrum
Started by ●January 11, 2007
Reply by ●January 11, 20072007-01-11
Ordinary student skrev:> Hi all, > > I heard we can obtain the phase difference between two signal from > cross power spectrum. > If someone knew, could you show me how to obtain the phase difference ? > I mean the algorithm. > I read the cross power spectrum is defined as FFT (A) FFT*(B) / N^2, so > we have real and imaginary components.Do you know about the polar form of complex numbers? Rune
Rune Allnor wrote:> Ordinary student skrev: > > Hi all, > > > > I heard we can obtain the phase difference between two signal from > > cross power spectrum. > > If someone knew, could you show me how to obtain the phase difference ? > > I mean the algorithm. > > I read the cross power spectrum is defined as FFT (A) FFT*(B) / N^2, so > > we have real and imaginary components. > > Do you know about the polar form of complex numbers? > > RuneYes. If I am not wrong, for example we have x+iy then we can write it as r cos (theta) + i r sin (theta), r^2 = (x^2 + y^2) arctan(theta) = y/x Titi
Ordinary student skrev:> Rune Allnor wrote: > > Ordinary student skrev: > > > Hi all, > > > > > > I heard we can obtain the phase difference between two signal from > > > cross power spectrum. > > > If someone knew, could you show me how to obtain the phase difference ? > > > I mean the algorithm. > > > I read the cross power spectrum is defined as FFT (A) FFT*(B) / N^2, so > > > we have real and imaginary components. > > > > Do you know about the polar form of complex numbers? > > > > Rune > > Yes. > If I am not wrong, for example we have x+iy > then we can write it as r cos (theta) + i r sin (theta), > r^2 = (x^2 + y^2)Right> arctan(theta) = y/xWrong. I am sure you spot the flaw if you take a second to look the expression over once more. After correcting it, the phase angle theta is computed as...? Rune
Rune Allnor wrote:> Ordinary student skrev: > > Rune Allnor wrote: > > > Ordinary student skrev: > > > > Hi all, > > > > > > > > I heard we can obtain the phase difference between two signal from > > > > cross power spectrum. > > > > If someone knew, could you show me how to obtain the phase difference ? > > > > I mean the algorithm. > > > > I read the cross power spectrum is defined as FFT (A) FFT*(B) / N^2, so > > > > we have real and imaginary components. > > > > > > Do you know about the polar form of complex numbers? > > > > > > Rune > > > > Yes. > > If I am not wrong, for example we have x+iy > > then we can write it as r cos (theta) + i r sin (theta), > > r^2 = (x^2 + y^2) > > Right > > > arctan(theta) = y/x > > Wrong. I am sure you spot the flaw if you take a second to > look the expression over once more. After correcting it, the > phase angle theta is computed as...? > > RuneSorry lol, phase = arctan(y/x), this equation equals to phase spectrum in radians. Titi
